Old 11-20-2008, 04:10 PM   #1
stage2??
Member#: 192590
2007 STI
Default What rpm's do i shift at?
Hey ive got an 04 sti fully stage 2 + cobb short ram and bigger tmic.
I was just wondering what rpms you shift at when doing aggressive driving or racing if you will. and where your setting your rev limiter. thanks.
stage2?? is offline   Reply With Quote
Old 11-20-2008, 04:13 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
I've found the sweet spot to be between 3650 and 7180 when driving aggressively. And YOU don't set the rev limiter, it's there for a reason.
For a Stage2 STi, drag racing, I'd say 6-6500, depending. Your power falls off up top with the baby turbo, and with shorter gear ratios you'll stay in the meat of your powerband there. Some may even prefer a little higher, but it's just that- preference. I shift at redline but I have a bigger turbo and smaller motor.
Audiosavvy is offline   Reply With Quote
Old 11-20-2008, 04:15 PM   #3
brumby
Member#: 162631
03 subaru wrx
rev it intel it goes boooooom!..then shift...or just listen to audiosavvy
brumby is offline   Reply With Quote
Old 11-20-2008, 04:24 PM   #4
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
I'm thinking he was referring to the shift light on the tach. Otherwise, yeah, just listen to post #2. I'd shift at redline when drag racing.
ThreeEleven is offline   Reply With Quote
Old 11-20-2008, 04:35 PM   #5
VSG
Member#: 19435
It won't go boom, but it will feel like you hit a wall when you hit the rev limiter!
VSG is offline   Reply With Quote
Old 11-20-2008, 04:41 PM   #6
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
about 2000 rpms for me, but that's when im flooring it.
AbACUZ is offline   Reply With Quote
Old 11-20-2008, 04:43 PM   #7
stage2??
Member#: 192590
2007 STI
alright. yeah i was talkin about the shift light sorry. so at redline? i was reading up that max hp is at 6k rpms. is that just for stock though?
Old 11-20-2008, 04:45 PM   #8
Jncominco2
Member#: 170212
depending upon your mods, your powerband will change
you can feel when it cuts out...you should shift right at that or just barely before it
Jncominco2 is offline   Reply With Quote
Old 11-20-2008, 06:17 PM   #9
Web Foot STi
Member#: 39086
2004 STi
Web Foot STi is offline   Reply With Quote
Old 11-20-2008, 07:08 PM   #10
thejordan
Member#: 185374
2-3k to avoid the oinkers ^o^
thejordan is offline   Reply With Quote
Old 11-20-2008, 11:52 PM   #11
Spooky
Member#: 58864
I like attracting oinkers going 120mph on the freeway
Spooky is offline   Reply With Quote
what RPM do you shift at? dabigmooish Newbies & FAQs 66 03-11-2005 05:46 PM
What rpm's do you set your shift light buzzer? Undepelo General Community 43 11-18-2004 04:45 PM
what do i shift at before i lose boost/power 03boxer4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-24-2004 08:59 AM
When you shift 1->2 at redline, what RPM do you "land" at? Butt Dyno Proven Power Bragging 2 08-12-2003 04:10 PM
At about what RPM's do MY01 RS's have the most torque/powerband? IMPRZME Normally Aspirated Powertrain 6 04-22-2001 07:27 PM
