Old 11-20-2008, 04:39 PM   #1
nerdydorkus
Member#: 67062
Default Question about tire plugging
I ran over a screw about 3/8 in diameter that went completely through my tire and rim. I need to buy a new rim, but will the tire be repairable if it went through both sides of the tire?
Thanks!
nerdydorkus is offline   Reply With Quote
Old 11-20-2008, 05:10 PM   #2
evokilla07
Member#: 164052
05 STI
donno dude post a pic of the actual hole and i bet you will get a better answer
evokilla07 is offline   Reply With Quote
Old 11-20-2008, 05:30 PM   #3
yzer
Member#: 89291
03 WRXSedan+SSR/XS
mbp
Please post pics. I've got to see this. Went through the tire and wheel?
I've had plugs put into low profile tires several times with perfect results. It depends on the damage to the tire and where the damage is on the tire.
yzer is offline   Reply With Quote
Old 11-20-2008, 05:30 PM   #4
nerdydorkus
Member#: 67062
sorry i have no camera, but to illustrate it went through my rim which means it had to go through the outer wall AND the inner wall to the rim.
i will try to find a camera
Old 11-20-2008, 07:57 PM   #5
MattPersman
Member#: 139385
tire place will tell you if they can plug it or patch-plug it, some places might, some may not want to chance it
MattPersman is offline   Reply With Quote
Old 11-21-2008, 12:52 PM   #6
fiveoh88
Member#: 125600
2005 STi perrin stg2
World Rally Blue
i've plugged a few tires using these temporary type plugs...never had any issues afterwards and always left them in as a permanent fix, hell i even did a sidewall hole with one (not safe) until i could get another tire
it's not the safest way to do it; you should have a tire shop patch it
fiveoh88 is offline   Reply With Quote
Old 11-21-2008, 02:39 PM   #7
fliz
Member#: 30342
Inner wall?
What sort of crazy tire was it?
fliz is offline   Reply With Quote
Old 11-21-2008, 02:53 PM   #8
Subieblue02
Member#: 143330
2002 Impreza WRX
Damn it went through the rim too? Wow, ive seen some crazy stuff in stuck in tires before, but damn. Um if its 3/8's it will be easy to get it patched. The big patch that that most tire shops carry is about the diameter of a dime. So no issues there. FYI, i work at a sears autocenter part time, so i patch tires all the time.
Subieblue02 is offline   Reply With Quote
Old 11-21-2008, 03:03 PM   #9
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
Originally Posted by fliz View Post
Inner wall?
+1 did it go throw the tread portion of the tire then into the rim? If so depending on what the hole looks like after the screw (sounds more like a rail road spike) discount tires (as well as others im sure) can patch it from the inside.
06AZREX is offline   Reply With Quote
Old 11-21-2008, 03:59 PM   #10
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Thanks!
....both "sides" of the tire (as in sidewalls)? Plugging/patching is only possible (safe) when the puncture is through the tread portion of the tire. ....and at a far enough distance away from the sidewall. If it is too close or actually though one or both sidewalls, you're SOL. Either way, take pics. ....I've got to see this.
Kean is offline   Reply With Quote
Old 11-21-2008, 04:38 PM   #11
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
i would take it to a tire repair shop and have them patch it. (not plug it)
They will dismount the tire and put a patch inside.
Usually if it's within reasonable amount distance away from sidewall most shops can do it
I like taking it to those mom and pop shop instead of big retail chain tire place, because the retail chain most of the time will tell u it's bad and they can't patch it cuz they want to sell you new tires.
Kenji815 is offline   Reply With Quote
Old 11-21-2008, 06:58 PM   #12
nerdydorkus
Member#: 67062
thanks guys, sounds like i will be able to get it patched from what you guys are saying. it went through the tread to the rip, so not the sidewalls. sorry for the confusion.
Car problems (continued) and question about spark plugs f1anatic Mid West Subaru Owners Club Forum -- MWSOC 53 10-22-2009 03:12 PM
E85 heads question about spark plugs downsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-21-2009 05:44 AM
Question about spark plugs for MY05 S2kVer02 Texas Impreza Club Forum -- TXIC 4 08-14-2005 05:21 PM
Audiophiles/electronics guys: question about speaker plug problems Kaiser Off-Topic 19 03-01-2004 04:24 PM
Question about spark plugs (yes I searched :P) Fido Normally Aspirated Powertrain 1 01-23-2001 11:16 PM
