Old 11-20-2008, 07:12 PM   #1
fnlyfnd
Member#: 100247
2015 Outback Premium
Carbide Gray
Default rpm spike when coming to a stop
my rpms will shoot up from 700ish to 1200ish when I am coming to a stop...then fall back down to the 700 idle...??
No other spikes ever which rules out a vacuum leak right?
fnlyfnd is offline   Reply With Quote
Old 11-20-2008, 11:18 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
my old wrx did this as well. no idea why.
i'm a great help huh
Justin
GrimmSpeed is offline   Reply With Quote
Old 11-20-2008, 11:21 PM   #3
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
My 06 WRX did that sometimes.
gabedude is offline   Reply With Quote
Old 11-21-2008, 08:02 AM   #4
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
hahahahaha, my car does this. I had a brake booster leak, and fixed that. But it still does it, just less.
I assumed it was due to my MAF being down behind the foglight for my rotated setup.
xrocket21 is offline   Reply With Quote
Old 12-02-2008, 10:27 PM   #5
tripz1196
Member#: 178451
2008 STi
Gray
What is it? Auto or stick?
If it's auto it might do that every once in awhile. My prelude did that.
Other possibility is a bad torque convertor if you launch the car while pressing the brake pedal.
I don't have a clue what it is if its a stick.
tripz1196 is offline   Reply With Quote
Old 12-02-2008, 10:45 PM   #6
my02turboWRX
Member#: 68448
2008 WRX STi
Cobb tunned by Surgeline
Sure seeing a lot of threads about this. Maybe there should be a sticky on it
Its normal
every subaru (manual) I have owned did this.
my02turboWRX is offline   Reply With Quote
Old 12-03-2008, 12:25 PM   #7
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
My 07 wrx didn't do this and my 08 sti does...
Not a big deal
geddesk2 is offline   Reply With Quote
Old 12-03-2008, 12:28 PM   #8
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Not a big deal
Same here man, my STi does this as well. Nothing of concern.
STi Mikey is offline   Reply With Quote
Old 12-03-2008, 07:13 PM   #9
Hot Wheels
Member#: 195102
04 & イン
アスペ&
my sti does the same but a tad bit higher than yours since my idle has also been set higher
Hot Wheels is offline   Reply With Quote
Old 12-04-2008, 03:49 PM   #10
GullyWagon07
Member#: 164171
08 EvoX <3 Wagon
rear prodrive plate frame
mines does this also, never really worried, just drove my friends xrunner tacoma, does something similar to what you described.
GullyWagon07 is offline   Reply With Quote
Old 12-04-2008, 06:20 PM   #11
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
my 06 wrx does the same.
bhhamblin is offline   Reply With Quote
car doesnt want to idle when coming to a stop dukeduster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 01-22-2009 04:00 PM
Stalling when coming to a stop Just of Spades Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-10-2008 07:37 PM
car stalls when coming to a stop light switchn2aWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 11-10-2007 01:40 AM
Front end creaking when coming to a stop rdy4flt Brakes, Steering & Suspension 20 06-11-2007 03:24 PM
clunk from the front when coming to a stop kettsupp Brakes, Steering & Suspension 8 06-05-2006 12:43 AM
