Old 03-26-2002, 12:36 AM   #1
TinyIvan
Member#: 7995
2002 WRX Wagon
Question What's the most serious condition that will cause a constant CEL (non-flashing)?
Everyone knows that if it's flashing your next stop better be the dealer, but if it's steady it can be anything from a gas cap to a bad EGT sensor. The gas cap won't do squat and will go away but the sensor will cause reduced performance and should be fixed. It also probably won't go away on its own
Soooo, the question is: I had my third CEL go on, but need the car starting Wed for a weekend trip. Since it's a steady light, am I OK to drive a couple hundred miles and hit the dealer on Monday? It really torques me that I have to deal with these but I think I will have to spend my money, give up my hope of a CEL-Free existence and buy an OBD-II scanning tool.
BTW, my car is bone-stock.
Thanks!
Notes: Two prior CELs: P0546, twice, turned out to be an intermittent short in the wiring harness somewhere in the firewall. Replaced EGT and fixed harness.
TinyIvan is offline   Reply With Quote
Old 03-26-2002, 11:07 AM   #2
Julian
Member#: 1182
MY00 RS
BRP
The answer: Who knows? Say its another short, but this one happens to contact a ground, then bzzzzzzt!, you let out the magic smoke, and...
Sure constant-CE light codes aren't as serious, and you could probably drive and be fine, but until the code is pulled there's no way to tell what it is.
With scan tools going for $73 in the various GBs, and a laptop for $100-150 or so, it's totally worth it. With my CE-throwing MRT header, it's nice to be able to check that the only code I'm throwing is P0420.
Julian is offline   Reply With Quote
Old 08-07-2002, 10:04 PM   #3
gusman21
Member#: 13767
2k5 MCS
Jet Black
do you know where your short was?
i have a similar problem and i have replaced the EGT sensor once already and i have the 0546 AGAIN.
-=GuS=-
gusman21 is offline   Reply With Quote
Old 08-08-2002, 02:02 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
Speaking of Exhaust Gas Temperature sensor failures, they frequently first manifest themselves as a benign solid CEL. However, they can quickly morph (in a matter of hours or days) into a failure in which the ECU believes there is a fire in the exhaust destroying the catalytic converters. In this situation the ECU has been known to panic and actually shut the engine down completely.
Jon [in CT] is offline   Reply With Quote
Old 08-12-2002, 10:33 PM   #5
TinyIvan
Member#: 7995
2002 WRX Wagon
Default Reason for Code
Check out this post for the reasons behind my code:
http://forums.nasioc.com/forums/show...ighlight=short
Text:
TinyIvan PM'd me that his P0546 problem has been fixed. I thought that the resolution ought to be appended to his original thread so that whenever someone searches the forums for that trouble code, they'll find how it was cured for one person. I hope TinyIvan doesn't mind.
quote:
TinyIvan wrote on 04-11-2002 11:54 AM:
Thanks for your suggestion on not letting the CEL on P0546 just keep bothering me. I wrote a letter to SOA, then called when I never got response (still bothers me actually, no written response). Eventually I got in touch with someone with their head on straight and receieved a case number.
Turns out they must have known about the lemon law as well because they brought in a factory rep and he found the problem in ONE day. There was a disconnected ground on a bus board under the passenger footwell.
The thing that ticks me off is how they found it (my conjecture based on conversation):
1) Drive around with computer hooked up.
2) No EGT reading (steady).
3) Look for reason its steady.
4) Must be ground since it's a high output.
5) Trace ALL ground paths (not just harness).
6) Find disconnect.
How this took three attempts (maybe two b/c I am convinced the first time was just a reset and go) I will never know. Maybe I should buy the service manuals.... BUT I don't think I should be fixing a stock car under warranty. Anyway thanks and keep up the good advice!
-TI
What's the most amazing place you've ever been to? A place that blew your mind. Mud Pig Off-Topic 231 02-15-2010 08:12 PM
what's the most powerful battery that will fit the oem 93-01 battery tray? 2slofouru Electrical & Lighting 1 01-23-2010 09:41 PM
What's the widest wheels/tires that will fit a 2008 WRX without any modifications? GodWhomIsMike Tire & Wheel 12 05-07-2008 09:53 AM
What's the most that you've towed with your WRX Wagon/Sedan? 24 General Community 21 08-30-2006 02:52 PM
What's the most interesting thing that's ever crossed the rod in front of you? Impreza Rider Mid Atlantic Impreza Club -- MAIC 12 04-29-2002 09:12 PM
Message Board Statistics All times are GMT -4. The time now is 11:30 PM.
