Old 11-20-2008, 10:18 PM   #1
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Arrow how do i install new bearings ej22t
so i have my ej22t all the way apart i split the block and took the crank shaft out. I my main bearings look fine but my rod bearings look bad so i was thinking about replacing them. Is there a way Im to measure the new bearings out before they go into the engine do crush them tougher with plastic gauge or something?? sorry im a noob when it come to rebiulding subaru engins. Not to say that i havent done engines before.
91turbosedaan is offline   Reply With Quote
Old 11-21-2008, 09:20 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The first thing you want to do is have your crank magged and polished, and talk to the machinist whether or not what they are seeing suggests that you take it first under.
Old 11-21-2008, 03:26 PM   #3
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Cool
magged and polished you mean "magnafluxed" to check for cranks right, ok well what will polishing do and will my local machine shop beable to send it out to do this?
I was reading some of your older posts on the bbs.legacy centeral by the infomous matt monson and it sais i can just drop the bearings in no need to plastic gauge them as long as i dont have it macined out. I think im just going to use ACL race bearins from ebay.
One of my friends told me to look into something called "rock pistons" dose anyone have any info on them?
Or
what will i need to make this into a ej22t stroker engine??
Going to try and make that bottem end power
Old 11-21-2008, 08:36 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
Taking things I have said in the past out of context can be a dangerous practice. The difference between my remarks and your situation is that you clearly said that your rod bearings looked pretty bad. That would have me measuring the rod journals for wear. I did assume that you would find them worn and at the bare minimum requiring a fresh polishing. There's also a chance that you will need to cut them first under, and your opening post makes it sound like you might not be able to make that judgment on your own, and thus the suggestion that you consult with a machinist.
Yes, Magged = magnafluxxed. There's no point in skipping that step if you have gone to the trouble of taking a crank to a machine shop. And they will do the polishing in house. That's what they do. They don't send it out or they aren't in fact a machine shop, or at least not a full service one...
Old 11-22-2008, 03:01 AM   #5
91turbosedaan
Member#: 135144
1991 legacy turbo
white
cool i am taking my crank and rods to my local machine shop tomorrow, can you provide me with the plastic gauge spec's and sequence please?
I'm also going to have my block half's cleaned up in the parts washer.
thank you matt
Old 11-22-2008, 09:36 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
You need to get a manual if you are going to do this. The best option is to Subscribe to SOA's tech site and dump the manuals. If that's too much money for you get a Hayne's. It's an acceptable second source for the information you are going to need to do this properly.
Old 11-22-2008, 03:03 PM   #7
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Cool
do u have a link to this "SOA's tech site" and what Haynes manual exactly i don't see that they have one for my 92 turbo legacy
Old 11-22-2008, 03:59 PM   #8
RallyColtTurbo
Member#: 16819
RallyColtTurbo is offline   Reply With Quote
Old 11-23-2008, 02:57 AM   #9
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Arrow
Try what there is no link..
Old 11-23-2008, 03:01 AM   #10
madmax718
Member#: 172501
be sure to price a new crank before you do anything else. A new crank may cost you about the same as the machine shop work.
madmax718 is offline   Reply With Quote
Old 11-23-2008, 03:06 AM   #11
aigochamaloh
Member#: 188167
2016 WRX LBP
2009 Legacy DGM
That is a link, click it.
aigochamaloh is offline   Reply With Quote
Old 11-23-2008, 03:55 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
What kind of rates are you paying at the machine shop? I've never seen one come even close to the $375+ a new crank would cost you. Or did you mean a good used crank?
Old 11-23-2008, 05:35 PM   #13
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
My shop charges $80 to turn a crank, $150 if they have to bend it back into shape.
Old 11-24-2008, 03:38 AM   #14
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Cool
hmm my local machine shop told me apx 50 bucks to do it + i know someone who works there. so possibly cheaper
how do i install new headlight bulbs rally_on Electrical & Lighting 3 09-09-2005 12:58 AM
How do i install a new strut without replacing the spring? jefersun Brakes, Steering & Suspension 12 01-13-2005 11:57 AM
How do I install WinXP on my new internal 2nd hard drive? skuttledude Off-Topic 16 08-05-2004 06:28 PM
how do u install new bulbs? oooggss Interior & Exterior Modification 1 09-21-2002 11:34 AM
How do I install my new shifter knob? StickyFinguz Interior & Exterior Modification 2 09-17-2002 03:58 PM
