Old 11-21-2008, 12:52 AM   #1
rice or die
Member#: 191034
1992 legacy turbo
Default psi and injection
i got two questions:
whats the max psi i can run on my ej22t with the stock internals and ecu?
can i put water/alchy injection on my 92 ss?
rice or die is offline   Reply With Quote
Old 11-21-2008, 01:01 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
#1 about 10 psi safely
#2 Yes
If you get piggyback, bigger injectors, bigger turbo, an actual intercooler, the you can run close to 20 psi.....
Old 11-21-2008, 08:43 PM   #3
rice or die
Member#: 191034
1992 legacy turbo
well see i already have these things done:
fcd defender from bbs forums
td04 turbo
intake
and im about to get exhaust done (3 inch tbe)
i have a wrx tmic installed too
nxs boost controller (kinda like the halman)
im running 14 psi right now (btw engine runs great)
FS Cooling Mist 150 PSI Water Injection Kit coyoteyz13 Engine/Power/Exhaust 19 11-19-2006 05:46 PM
What is STi stock boost in psi, and what max safe psi before you'd rec' head studs? JRock Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-05-2004 05:56 AM
T3/T04 psi and hp potencial DJIMPREZA Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-08-2002 08:13 PM
Misfiring When at 17.5 psi and 20 F mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-04-2002 08:05 PM
('93-'01) Check my math? re CFM, PSI, and so forth... Daveish Impreza Forum 0 10-23-2001 10:18 PM
