Old 11-21-2008, 01:40 AM   #1
akeric
Member#: 122954
2006 Evo IX
My car is black not
Default 18in rims and cobb springs will they rub?
So I've got the cobb springs on my 07sti and I'm looking at getting some new rims. I'd like to go with 18s but I'm not sure they will fit without rubbing. My geographical location makes it kind of hard to find any place that will test fit them.
Anyone know what the deal is or run a similar setup?
If I run the same width tire will I be ok or can I go a little wider?
akeric is offline   Reply With Quote
Old 11-21-2008, 02:14 AM   #2
Drifting Away
Member#: 70165
2006 WRX STi
Teh Wineberry Legend
You wont rub depending on the size and offset of the wheel.
What size of rim are u thinking about getting? Im running 18X9 +35 with a 235 tire.... I have to roll the rear or else id be rubbing bad.
Drifting Away is offline   Reply With Quote
Old 11-21-2008, 07:02 AM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
First I'd say to get rid of the Cobb springs. They're too low.
We need to know a few things first:
- What size wheel? 18x8?18x8.5?18x9?
- What offset?
- What size tire are you thinking to run?
Old 11-21-2008, 01:24 PM   #4
akeric
Member#: 122954
2006 Evo IX
My car is black not
- What offset?
What would you suggest as far as replacement springs? I really enjoy the improved handling of the cobbs.... although they might be a little bouncier than stock its nothing I can't live with. Prodrive? Crucial?
I was looking at the 18x8.5 with a 235/40 tire on it. not sure about the offset.
Old 11-21-2008, 01:52 PM   #5
mav1c
Hoodbridge!
Member#: 560
Stick with a +40 or higher offset and you'll be fine with a 235/40-18.
Old 11-21-2008, 03:56 PM   #6
akeric
Member#: 122954
2006 Evo IX
My car is black not
even with the cobb springs? alright sounds good....
Old 11-21-2008, 10:57 PM   #7
pnutbutta
Member#: 192572
2007 Impreza
CGM
8.5x18 +48 and a 2254018 wont rub
pnutbutta is offline   Reply With Quote
Old 11-22-2008, 08:25 AM   #8
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
225/40-18 on a 8.5 in rim is stretched, and is going to make your speedometer off a littlebit. If thats the look you going for. Pretty hard on the sidewalls IMO. I actually run 18x8.5 +38 rims on cobb springs in my 07 STi. You can have your fenders pulled or what not, but its easier to tactfully grind out the metal from your fender to match up to the plastic lip the goes over the top of th fender. That give me enough clearance for my rims with 255/35 tires. I agree with better springs though, if you want a good drop without bad ride, go with some coilovers.. otherwise you'll just waste some money in the long run.
Louie is offline   Reply With Quote
Old 11-22-2008, 11:49 PM   #9
hipower
Member#: 155756
369 tribeca 7 pass
vf34wrx,06 sti,08cbr600rr
I run 245 on rota pf45 in 18x8.5 with 48offset with no fender mods at all on cobbs springs
hipower is offline   Reply With Quote
Rubbing Issues with Stock Rims and Perrin Springs? persian prince Brakes, Steering & Suspension 3 06-19-2007 06:12 PM
prodrive springs and these rims? Will they rub? tacomaprime Brakes, Steering & Suspension 6 11-25-2004 06:53 PM
235/40/18 will they rub? revelation Tire & Wheel 3 06-10-2003 03:17 AM
225 50 16 on RS rims, will they rub with eibach springs and kyb? WRxednEffect Brakes, Steering & Suspension 2 04-13-2002 05:16 PM
prodrive wr suspension and 215/45ZR17....will they RUB? spt_impreza Brakes, Steering & Suspension 11 12-16-2000 10:49 AM
