Old 11-21-2008, 01:40 AM   #1
CRAIG MERRILL
Member#: 122237
2006 WRX STI
Default will a 245 fit an 06 STI with no mods?
I'm looking to fit the widest tire on my 06 STI that I can that doesnt rub!! without having to roll the fenders or change the camber. do I have room in there for a 245/--/17 or 18. Sorry, I had a sheet with overall diameter's written down but I cant find it. I think the 245/40/17 was like .2 in shorter than the stock 2254017 and the 245/40/18 was about .5 in taller than stock. A little taller wouldnt be that bad, since the STI's gearing is already a little low for me. Suspension is all stock and the tires will be going on a set of 8in wide wheels.
CRAIG MERRILL is offline   Reply With Quote
Old 11-21-2008, 01:55 AM   #2
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
245 tire is the widest you can go on an 8" wheel. I'm sure there's someone out there running wider tires on Sti wheels but its not recommended.
http://www.miata.net/garage/tirecalc.html
the 245/40 tire would be 0.3in smaller than stock diamater.
rexman2002 is offline   Reply With Quote
Old 11-21-2008, 09:07 AM   #3
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
You will fit fine.
Guys are lowering and going to 255/265, so stock at 245 is no problem.
DiscoGsus is offline   Reply With Quote
Will 245/40/17 Star Specs fit an 05' STi with Tein S-Techs? NaiveRapture Tire & Wheel 28 01-26-2011 08:09 PM
quick question: will 04 rs side skirt fit an 05 sti with no problem ??? MRSTI28 Interior & Exterior Modification 7 12-21-2009 01:32 PM
will an 02 wrx exhaust fit an 06 sti??? All4bSpinnin Newbies & FAQs 5 05-25-2009 08:18 PM
will an 02 wrx exhaust fit an 06 sti??? All4bSpinnin Newbies & FAQs 1 07-13-2006 09:40 PM
Auto Body guys: Will an 04 STi rear window fit an 06 Sti? AspenGC8 Interior & Exterior Modification 9 04-20-2006 07:48 PM
