Old 04-30-2010, 10:25 AM   #326
Nuke209
Member#: 108089
2003 WRX
NF Performance
Originally Posted by TDagen View Post
^From e70 to e85 my wot lambda changed very little... I guess I could just have potent E85 in my area....You really have to keep changing the tune even between different gas stations? Also are you changing you whole fuel map to run e85? Maybe your ecu is set up differently but with the subarus we just make the injector scaler about 28% smaller than the Injectors actually are... so you would take your injector size let's say 850cc multiply it by 0.72 = 612cc , if you use 612cc for your injector scaler it will automatically adjust your fuel maps for E85 ... The only thing E85 needs different than gasoline is 25-30% more fuel per combustion event..So the scaler will make your cars afr's running E85, match with your gasoline fuel map .then if you need to lean it out a bit just take and make your injector scaler a little larger, too richen it up make the injector scaler smaller... Also if you need to fill up with gas you can just change your injector scaler back to you regular size... Makes everything convenient...Is this how you are doing it geoff ?
Yup
All my guys just run on the same tune on different batches of gas without issues at all. Log it and everything is still running great.
If you really want to get anal, you can adjust your scalar to match your fuel map on each tank.
Nuke209 is offline   Reply With Quote
Old 04-30-2010, 10:28 AM   #327
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Originally Posted by modaddict View Post
interesting.....
There are of course the cold start enrichment tables that need to be played with a bit but that's only if you live in colder areas and it's a very minor issue to tune out , I had Mine starting last fall at 25 degree weather in the first try first crank!
TDagen is offline   Reply With Quote
Old 04-30-2010, 10:31 AM   #328
modaddict
Member#: 95840
sold to a good bud
awaiting next car
what did you do? Just throw some fuel at it?
modaddict is offline   Reply With Quote
Old 04-30-2010, 12:45 PM   #329
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Yeah there are a couple different areas to richen up a bit , mainly the cranking enrichment table needs a little more fuel @ about 45 degrees(temperature) and below and good to go...The other table is cold start enrichment iirc, I may be forgeting a start up table ,I'm on the I phone now ( sadly no body has made a romraider Iphone app ) so I can't open up romraider to check it but I think that's about it for cold start....But of course if on E85 you can crank the boost up a bit and add a little timing if wanted too
Old 04-30-2010, 01:02 PM   #330
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
here in az the fuel quality is _really_ bad. we have huge inconsistencies, heck even our "91 octane" is truly 87 octane, buffered with ~15% ethanol content to raise the octane to 91. There was a car we recently tuned in NJ on 93 octane, shipped it to AZ and on the 91 octane it took ~28% more fuel, across the board. same exact setup, same boost level, just the fuel changed. that car is a daily driver here.
i would kill for some of the E85 you guys get in the midwest! hell if i could get E98 out here i would in a second. That stuff just doesnt exist out here
Full-Race Geoff is offline   Reply With Quote
Old 04-30-2010, 02:11 PM   #331
Nuke209
Member#: 108089
2003 WRX
NF Performance
There is a thread @ RomRaider's forum, JSarv had some info on what to do.
Old 04-30-2010, 07:07 PM   #332
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Thanks.
I'll look it up.
Old 05-30-2010, 07:43 AM   #333
Shabib67
Member#: 61749
any updates Geoff? Hows PPhilthy GT40R build coming along?
Shabib67 is offline   Reply With Quote
Old 06-04-2010, 05:51 PM   #334
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
philthy's twinscroll 40R evo is now his focus of attention... since it makes high 600whp on pump gas and high 700whp on race gas (with room to go) .
Now that he is daily driving the Evo, he doesnt need to daily drive the twinscroll 40R STI so hell be tweaking it over the next few weeks and will finally get it strapped down at Evans Tuning's Dyno and we'll certainly post any updates here
Old 06-07-2010, 10:20 PM   #335
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
For the guys looking for crazy obscene power, BW just produced a small batch of 67mm S400SX's easily the most powerful 67mm turbocharger on the planet.
Old 09-15-2010, 11:11 PM   #336
vr4_rider
Member#: 62963
1984 Pair of feet
Tan
Does anyone know the part number for the s300p? I've never heard of it til now, and I like the sound of it. How much?
vr4_rider is offline   Reply With Quote
Old 09-16-2010, 11:36 AM   #337
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
the "S300P" was never sold to the public because the turbine housing is not available for purchase - even though the center sections are available. For each of the S300P's that ive had or sold, the turbine housings required to be custom machined and welded by us. There is no other option becuase of the 74mm turbine wheel's geometry. Full-Race has a close relationship with BorgWarner which allows us access to turbochargers that are not available through the normal airwerks catalog, and this is one of those instances
My personal car has been running this turbo with (2) custom housings for time attack use. it generated the best powerband of any turbo thats ever been on my RB26 which is why i ran it at the modified magazine shootout.
Old 09-16-2010, 07:56 PM   #338
vr4_rider
Member#: 62963
1984 Pair of feet
Tan
How much? I couldn't find this on ur site.
Thanks!
Old 09-22-2010, 08:44 PM   #339
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
^^we do not sell that turbo becuase the turbine housing requires so much machining, it would cost too much. I am selling the one off of my car if you are interested http://forums.nasioc.com/forums/show....php?t=2059687
Old 09-22-2010, 10:15 PM   #340
garageGT
Member#: 80524
So Geoff, why are you selling it if you dont mind me asking..
and looking at the powerband, something wasnt happy at 4600rpms, any idea?
thank you
cenk
garageGT is offline   Reply With Quote
Old 09-22-2010, 11:03 PM   #341
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
I'm selling my old turbo because Borgwarner is releasing the EFR series... and the technology in those turbos is going to "change the game" - mark my words
The dip and inconsistent tq curve was due to the boost controller I was using was not performing well... so I'm changing that this time also
Old 09-22-2010, 11:14 PM   #342
vr4_rider
Member#: 62963
1984 Pair of feet
Tan
I think I am going to hold out for the new turbos.
Man, all the time I've spent researching what turbo to go with (nearly 3 weeks and I am still not done--I'm very thorough) is in vain..lol.
Geoff, is the EFR turbos going to be in the 2011 Airwerks catalog? If so, when is the catalog being released?
Thanks, senor.
Old 09-23-2010, 11:30 AM   #343
garageGT
Member#: 80524
cool, are those single or twin scroll? post up some comparison when you can please..
catch you later
Old 09-23-2010, 12:01 PM   #344
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
they are both. you can just switch the housings from singlescroll T3 or twinscroll T4. will start posting up info as I am allowed
Old 09-24-2010, 02:28 AM   #345
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Geoff, am I close? Check out my prediction in the Borg Warner Registry thread in Proven Power Bragging section, post #706.
Now I've got to sell my brand new divided T4 Garrett GT3582R 1.06 a/r I was about to put on my car.
methaddict is online now   Reply With Quote
Old 09-24-2010, 12:14 PM   #346
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
^^yes to post 704
HTA GT35R vs normal GT35r. Questions? D Money Built Motor Discussion 99 03-03-2010 05:07 PM
twin scroll vs sigle gt35r both .82 housing acssa Built Motor Discussion 8 01-28-2010 03:14 PM
fullrace GT3076 1.5 Scroll vs Blouch DOM III vs FullRace Twinscroll GT35R azn_ryder02 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 58 04-06-2009 10:29 PM
Singlescroll Gt30 vs. Twinscroll Gt35 Results Inside [email protected] Proven Power Bragging 20 03-28-2009 02:01 AM
kingpin vs godsped gt35r. Please no flames!! NORCAL STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 45 10-27-2005 04:23 PM
