Alaskan Impreza Club
Old 03-26-2002, 04:27 AM   #1
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Question flutter
hey guys
i have had the Forge bov in my car for a day now
but it flutters sometimes before it actually blows off.
it would sound like this , pst pst pst then a quick pshh.
i have done a lot of searching some people say its the turbo stalling or its turbo backspin.
other people say its the BOV's valve not opening all the way, they say taht the valve only opens only a little since not that much boost was made.
Hey Ofrder, what kinda spring was in it? some people say taht the forge comes with a red spring(really stiff) and that I need a blue or a green spring.
Did the forge behave like this on your car?
How bout everyone else, do your BOVs flutter?
i'm kinda worried about my turbo now
AK_2002_WRX is offline   Reply With Quote
Old 03-26-2002, 04:54 AM   #2
WRXnFX
Alaskan Mafia
Member#: 10398
Hahahaha, Mike you're killing me. I thought you did all your research. Let me guess. It only happens at part throttle and not under WOT conditions.
Winslow
WRXnFX is offline   Reply With Quote
Old 03-26-2002, 05:10 AM   #3
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
well, i think i know what it is, i just want everyone elses input
i just want to know if it is the turbo makin the noise, or the BOV itself makin the noise. i know turbo backspin would make a noticeable flutter noise, but the one i hear sort sounds like a "giggle." it will make its noise then do a quick pshh. this is at part throttle at aroun 3500-4000 rpms.
Old 03-26-2002, 05:15 AM   #4
WRXnFX
Alaskan Mafia
Member#: 10398
I don't think it's the spring. Have you done any other intake mods? My BOV makes the same sound and I've heard it on other cars too. Does the Forge recirc? I think it is the turbo making noise. That is what I've read in past posts. It is a pretty common sound with cars with BOVs.
Winslow
Old 03-26-2002, 05:22 AM   #5
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Talking
well if Rob isn't having any problems with his car then i guess mine should be fine too. we'll have to hear what he has to say about it.
its just that noise it makes. it kind sounds like it comes from the BOV side of the engine and not the turbo.
Old 03-26-2002, 05:32 AM   #6
WRXnFX
Alaskan Mafia
Member#: 10398
Really? I hear the flutter on the turbo side. Where is everybody? Oh yeah, its 130 in the morning. I see Rob on line around 6-7am.
Winslow
Old 03-26-2002, 07:12 AM   #7
brokeawd
Member#: 15796
2003 Cobra 10.40@135
09 Titan Crew Cab LE
This flutter that you are hearing is air bouncing off the throttle body plate and turbine wheel exit side. As you would call it...air has no where to go or escape, this may be accompanied by a small jolt. Basically since its a aftermarket BOV the spring on the inside is heavier tension, unlike the stock one, so therefore it doesnt blow off like the stock one with small boost inputs i.e. get in throttle shortly then get out....probably sounds like a choking sound. You are backspinning the turbo a tad but nothing to be concerned with.
All in all you are gonna have to put up with this unless the bov has a soft/hard adjustment on it. If you set the spring to soft, boost pressure will blow off under WOT resulting in lost boost. So yes in a way stiffer is better.
DSM guys take the stock ones and crush them, which puts more tension on the spring, and cuts down on boost leaks. I still run a stock BOV on my car.....hope this helped some.
brokeawd is offline   Reply With Quote
Old 03-27-2002, 05:05 AM   #8
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Angry
i got a check engine light today. i'm not sure if its related to the BOV or not, but it went on right after the bov vented during a shift
Old 03-27-2002, 05:39 AM   #9
WRXnFX
Alaskan Mafia
Member#: 10398
I can't help but laugh. You put so much into the research of BOVs and look what happened. Sorry, but the light will probably go away after 50 miles. I can pull the code when I get back if it makes you feel better.
Winslow
Old 03-27-2002, 06:55 AM   #10
R-RATED
Member#: 16875
Infomous racing crew
Default ?
Only in a high gear an low rpm when you dont produce that much boost and lay off the gas but problems with my bov not a sing thing thought.
R-RATED is offline   Reply With Quote
Old 03-27-2002, 09:15 AM   #11
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
just reset the ecu...
SQUAD_907 is offline   Reply With Quote
Old 03-27-2002, 12:04 PM   #12
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Wink
yeh i reset the ECU again, 2nd time this week
first after Rob put it on, and yesterday.
i've never waited for a CE light to go off before, does it actually turn off on its own with out reseting it?
Old 03-27-2002, 05:48 PM   #13
R-RATED
Member#: 16875
Default ce light
Yeah it turns off by it's self dont worry.
Old 03-27-2002, 06:40 PM   #14
WRXnFX
Alaskan Mafia
Member#: 10398
Yup, usually after so many miles. The ECU runs continuous monitor tests and after so many good results it will turn off the light.
Winslow
Old 03-27-2002, 11:05 PM   #15
R-RATED
Member#: 16875
Or if your worried reset the ECU.
Old 03-28-2002, 02:32 AM   #16
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Angry
i got another ******* check engine light again
maybe it is the bov i dunno what the hell it is, but 2 CE lights in a row really ****ing sucks.
i checked everything in the engine bay, nothing seems wrong, i think i need to invest in a scan tool. i bet its the damn BOV.
Old 03-28-2002, 04:55 AM   #17
WRXnFX
Alaskan Mafia
Member#: 10398
Damn OFRDER. Maybe he'll swap BOVs with you. Hmmm HKS huh? Sounds like a good deal. I'll be back Friday. I need to hook that software up to my car so I can pull the last code. I can do your too.
Winslow
Old 03-28-2002, 05:30 AM   #18
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
ofrder never got a cel with that bov...maybe it's something else? u never know til u bring up the code...
Old 03-28-2002, 05:45 AM   #19
WRXnFX
Alaskan Mafia
Member#: 10398
Does the forge recirc? Or is it 100% blow off?
Winslow
Old 03-28-2002, 05:50 AM   #20
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
it's 100%...it comes with a plug...
Old 03-28-2002, 10:36 AM   #21
Sokudo
Member#: 11162
MY98 A4 Avant
Unhappy
Hmmm,never had cel issues when i had it in my car.Let's wait for Winslow so he can pull the codes and check what's the cause of the cel.
Sokudo is offline   Reply With Quote
Old 03-28-2002, 10:38 AM   #22
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Have a Nice Day?
i had my ecu unplugged all night. hopefully it wont light up again.
yeah i think i need mine scanned too.
Old 03-28-2002, 03:45 PM   #23
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
To fix Check Engine Light, do the following:
1. Get a roll of Electrical Tape
2. Open drivers side door and get in seat.
3. Pull off a few small strips of tape.
4. Put tape on plastic gauge housing cover in the area of the offensive "Check Engine" light. Do not be afraid to use as much tape as you like.
5. Mod your car to your hearts content, without the little red light to bug you.
Kris
RallyX13 is offline   Reply With Quote
Old 03-28-2002, 06:44 PM   #24
WRXnFX
Alaskan Mafia
Member#: 10398
The light is yellow. Go figure. Color blind people. Good fix though.
Winslow
Old 03-29-2002, 12:37 AM   #25
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
Colors all the same....make no matter, make light go away!
Kris
wastegate flutter or bov flutter-help!?!? odin1 Factory 2.5L Turbo Powertrain 5 02-08-2004 06:25 PM
I think I have turbo flutter now with my GFB BOV ezatnova Factory 2.0L Turbo Powertrain 6 07-15-2002 12:15 PM
fluttering sound coming from intake after throttle lift? pbnj9786 Factory 2.0L Turbo Powertrain 18 03-21-2002 03:20 PM
Fluttering sound in the rear bumper? Daios Car Audio, Video & Security 1 10-02-2000 01:34 PM
Message Board Statistics All times are GMT -4. The time now is 04:03 PM.
