Old 11-21-2008, 05:12 PM   #1
franzd
Member#: 118669
1997 Volvo 850r
Default EJ25 Dyno
Been mapping an engine at Justice Racing Engines...
http://www.youtube.com/watch?v=4GPygaRMMGw
-franz
franzd is offline   Reply With Quote
Old 11-21-2008, 05:39 PM   #2
xsblack
Member#: 26530
2004 Sti
JBP
Thumbs up
sweet vid. You do not see too many EJ's on engine dynos
Are the headers coated? I always love seeing a manifold glow from the heat
xsblack is offline   Reply With Quote
Old 11-21-2008, 06:20 PM   #3
franzd
Member#: 118669
1997 Volvo 850r
yes, headers are coated... uppipe is not...
this was shorter time load than we have been doing... just for some video... having issues with camera turning off thinking that it is overheating...
typical static loads have been 45+ seconds... longest being a few minutes...
should be fun on maximal.
Old 11-21-2008, 07:19 PM   #4
xsblack
Member#: 26530
2004 Sti
JBP
That makes sense, you can see th up pipe glowing brighter then the manifold itself. I would really like to see what the up pipe/manifold looks like under heavy load and full boost for 45 sec +. You don't happen to have an laser thermometer to see the difference between coated and uncoated temps do you? What is this motor being used for? It is great to be able to perfect the motor before it ever enters the chassis.
Old 11-21-2008, 08:13 PM   #5
franzd
Member#: 118669
1997 Volvo 850r
i'm not a big fan of going in the dyno room when we are running an engine at higher loads.... we sheared a driveshaft once and it flew across the room, don't really want to be caught out by that...
i have full data with multiple EGTs, as well as EBP and a few air temp sensors... this is for a street car, so i'm not using all the sensors that i have available to keep costs down.
-franz
Old 11-21-2008, 10:40 PM   #6
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Very cool Mr.Franz!!
What kinda power is it making?
Junior2JZ is offline   Reply With Quote
Old 11-22-2008, 04:41 PM   #7
franzd
Member#: 118669
1997 Volvo 850r
not done with pump gas yet... so power is still climbing...
found an interesting core issue with subaru engines that do extended periods with higher power levels... so that was worthwhile.
i'm going on vacation for a week, so i'll finish mapping when i get back... be a good xmas present for the owner...
-f
ej18 ej25 SWAP Dyno Results, HEADS UP! maxim Normally Aspirated Powertrain 6 03-18-2005 08:34 PM
ej18 ej25 SWAP Dyno Results, HEADS UP! maxim Subaru Conversions 8 03-18-2005 08:22 PM
EJ18-> EJ25 Dyno results Hawk296 Normally Aspirated Powertrain 10 09-21-2004 09:30 PM
Anyone Dynoed A Built EJ25? smacksube Normally Aspirated Powertrain 10 12-04-2003 03:13 AM
