Old 03-26-2002, 07:57 AM   #1
WRXnFX
Alaskan Mafia
Member#: 10398
Default What size bolt is on the crank pulley?
What size bolt is on the crank pulley and what is the torque value?
Winslow
WRXnFX is offline   Reply With Quote
Old 03-26-2002, 08:02 AM   #2
dandbest
Member#: 1885
2015 Evo
It's 22mm, and you should torque it down to 90ft/lbs
Danny
dandbest is offline   Reply With Quote
Old 03-26-2002, 08:25 AM   #3
WRXnFX
Alaskan Mafia
Member#: 10398
Five minute reply. Isn't this place wonderful. Thanks
Winslow
Old 03-26-2002, 09:04 AM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
i agree with dandbeast. that's what i recall from my underdrive pulley install. IMPORTANT: it's a DEEP socket. it's recessed enough so that you need a long socket to get to it with a breaker bar. I just went to Ace hardware and bought a $10 set of deep sockets. I tried doing it with a regular 22mm socket but i couldn't get to it.
nhluhr is offline   Reply With Quote
Old 03-26-2002, 10:48 PM   #5
dandbest
Member#: 1885
2015 Evo
You're welcome. And make sure you DO torque it properly, cause at first I didnt, and just used a really long breaker bar to tighten it, and I got it so tight, that the pulley was wobbling at idle It took a two foot pipe and that same breaker bar to get it loose, and once I did it right, all was good.
Danny
Old 03-27-2002, 08:01 PM   #6
relayer66
Member#: 14614
Platinum Silver
I used a regular Craftsman 22mm socket and it was plenty deep enough. And yes, you'll need a nice long breaker bar and maybe a pipe. By the way the alternator bolt is 24mm, if you are changing that at the same time (I have the GFB pulley kit). That one is a PITA to get off but I used the old belt as padding and put channel locks on it.
relayer66 is offline   Reply With Quote
Old 03-28-2002, 05:18 AM   #7
WRXnFX
Alaskan Mafia
Member#: 10398
Thanks for the tips.
Winslow
Old 04-20-2002, 01:44 AM   #8
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
So the channel locks hold the alternator pulley still so you can losen the bolt?(i dont know what channel locks are, but i guess i will buy them at store before i install my GFB set)- ok one more question, how do i know how tight i am torquing bolt down, is there an attachment or something i have to buy? (i never used to do work on my last car cause it was a POS, so everything i do on subaru is for the first time) thanks in advance for helping me out..
paul
PaulRex is offline   Reply With Quote
Old 04-20-2002, 11:28 AM   #9
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Yes, you'll probably need an extra person, Be sure to use an old piece of belting on the alternator pulley so you don't tear it up too much. The alternator pulley is a real pain in the ass to remove. They put a 22mm bolt on the crankshaft but a 24 mm bolt on the alternator
You'll need a torque wrench. A good one runs $90-$150. You want a good "click-type" torque wrench. If you can't or don't want to buy one, borrow one off of a friend or rent one from a hardware store for a day.
Corn-Picker is offline   Reply With Quote
Old 04-20-2002, 12:04 PM   #10
relayer66
Member#: 14614
Platinum Silver
i used a large set of channel locks (sort of like an adjustable pliers) to hold the alternator pulley while i loosened the bolt. i cushioned the pulley with the old belt to prevent it from tearing up the pulley. this is a two-person job, one to hold the channel locks and one to loosen the bolt. it is on very tight. you will need to get a torque wrench, it is an investment you will use often if you work on your car a lot. get the click-set type, not the type with the needle and gauge. also get the 1/2" drive type, not the 3/8". you can then use a 3/8" adaptor for smaller jobs, and you will have a sturdier wrench. craftsman is a good brand and easy to get (any sears), or you may be able to rent one. you dial in the correct torque and when you tighten the bolt you will hear or feel a click when the correct torque is reached. do not overtighten or you may deform or damage the soft aluminum of the pulley. don't bother torquing the alternator pulley, just get it on nice and tight (again don't overtighten). make sure your belt tensions are set nice and tight when you are done...if you go too tight however the belts won't last long.
Old 04-23-2002, 02:17 AM   #11
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
THANKS!! thank you for the info. - I also emailed Dale Teague(the vendor i bought my GFB kit from) and he gave me similar advice, said that the alt. pulley is hard to hold still and that it would be much easier with airtools or a rattle gun and such.. also said put the car in 5th and have someone step on the brake to remove crank bolt.
Now about the belt tensions.. i was reading the Owners manual before and it has specifications for how tight the belts are supposed to be, so i figured i would just go by that(they just say how much it should give when you push down on it at a certain point)
Dumb question. What size thread is on a 10mm (socket) bolt? GooseMan Off-Topic 35 03-06-2014 04:07 PM
What size exhaust is on my '02 NerdyAlaska Newbies & FAQs 13 01-16-2007 10:33 AM
What size bolts are on the Uppipe heatshield? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-31-2004 08:27 AM
what size bolt is the drain plug?? jmott Texas Impreza Club Forum -- TXIC 4 11-16-2002 04:42 PM
