Old 11-22-2008, 01:45 AM   #1
Outback Jack
Member#: 120999
Default Bad wheel bearing - how long can I drive on it
I got a bad wheel bearing, the left front wheel has a little play moving it at 12-6. There's a little noise, but not very loud yet. Problem is I don't have time to fix for about a week, and no other car to drive.
So what I'm wondering is, even if a wheel bearing completely fails, your wheel doesn't just fall off, right? Isn't the bearing captive inside the spindle, and the axle is bolted to the hub?
Thanks.
Outback Jack is offline   Reply With Quote
Old 11-22-2008, 02:16 AM   #2
SHARP_DAL
Member#: 183247
2005 WRX
no. your wheel WILL completely fall off.
SHARP_DAL is offline   Reply With Quote
Old 11-22-2008, 02:25 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if you let it go too long, it may kill the hub and knuckle
Old 11-22-2008, 03:14 AM   #4
davetsbass
Member#: 169729
2002 a6 2.7t
how;s your luck?
davetsbass is offline   Reply With Quote
Old 11-22-2008, 06:32 AM   #5
Outback Jack
Member#: 120999
Here's the thing. The axle is attached to the hub with the big nut, wouldn't that keep the wheel on if a bearing fails, and if not, why?
Old 11-22-2008, 09:51 AM   #6
MasterKwan
Member#: 98961
2003 WRX
I'm doubtful it'll fall off. The bearing is held into place with a big C-clip. If it gets really bad it could strand you and you might end up overheating everything on the knuckle. I'm not sure a week matters though. Lots of people drive on bad wheel bearings for months because they don't know any better.
Old 11-22-2008, 11:05 AM   #7
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
My guess, is that if you just noticed it, youre fine for a week. If you noticed it last year, thats another story...
Just an fyi, the longer you drive on a bad wheel bearing, the higher risk you have of damaging the hub and knuckle = more money...
gto7419 is offline   Reply With Quote
Old 11-22-2008, 12:54 PM   #8
Gonz
Member#: 18642
2005 Impreza WRX STi
drive easy/slow for the week and don't put loads on the bearing by cornering fast, especially when the loud wheel is at the outside of the turn.
The wheel isn't going to fall off because the axle nut secures the hub to the axle, whether or not there is a bearing there.
Once the bearing fails you will get stuck (requiring a tow) and you are possibly going to damage the CV joint/boot/abs ring/abs sensor and the brake rotor as it can now drag against the caliper bracket so don't wait too long.
Gonz is offline   Reply With Quote
Old 12-03-2008, 09:50 PM   #9
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Little bump...but my LF wheel bearing has 'collapsed' according to a grease monkey. I took to a trackday, did many roadtrips and even shifted to a different city with the wheelbearing approaching failure.
It's getting booked in for replacement next week.
i_c_the_light is offline   Reply With Quote
Old 12-03-2008, 09:54 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
expect to replace the hub and knuckle as well as the bearing
now that ya waited
Old 05-23-2009, 03:20 AM   #11
cmarin21
Member#: 189747
2002 Wrx PSM
VF48 EWG EJ257 Hybrid
back from the dead... I my FR wheel bearing has also went out on my 02 wrx. I am wondering if I were to buy an 04 sti hub (that has the same bolt pattern) can I still use my wrx axle?
cmarin21 is offline   Reply With Quote
Old 05-23-2009, 09:51 AM   #12
MasterKwan
Member#: 98961
2003 WRX
My impression is that the 04 STI hubs are identical to the WRX hubs.
Old 05-23-2009, 11:33 AM   #13
Back Road Runner
Member#: 60082
2004 Forester STI
The wheel falling off the car does happen. It's not a coming apart sort of thing, it's a I'm causing so much heat I'm melting steel sort of thing. Can it happen on our cars? I have no clue. The assembly may simply weld itself together and seize instead which would also suck and probably send you off the road into the ditch somewhere at 65mph. That might be nice too.
Old 05-24-2009, 12:17 AM   #14
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Yes it can as experienced by a guy at an autocross out here a couple of years ago.
Old 05-24-2009, 12:23 AM   #15
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Yup, their the same.
scby rex is offline   Reply With Quote
Torn CV boot, how long can you drive on it? styng88 Mid Atlantic Impreza Club -- MAIC 6 05-07-2006 09:57 PM
Failed wheel bearing - how long do I have?? newscooby South East Region Forum 38 08-10-2004 04:38 PM
How long can you drive with a spare tire on? WRXVII Service & Maintenance 9 06-18-2003 12:39 AM
Bad Wheel Bearing...How DO I Know? JasonRan Normally Aspirated Powertrain 3 07-13-2001 05:58 PM
Ques: MAF = toasted; how long can i drive in limp mode? Orbiter Technical Forum Archive 6 06-12-2000 02:38 PM
