![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 180513
RMIC
Vehicle:Baby Baby C'mon! Looka Bomba! 99 JDM GM8 |
So the car i have is a swapped gc with the wrx brake conversion, lowered 1.5" F 1.6" back on prodrive springs with KYB AGX. Im looking for a wheel setup that would be good preferably without rolling, but i could if need be. One setup someone said that would be good is 17x8+48 245/40/17 rolled or 17x7.5+48 225/45/17 unrolled
help? i'd be using direzza Z1 star specs. This is mainly a tire thread, as ive pretty much decided to get the MB weapons or Drag Dr-21's.
#2 |
Member#: 48377
Vehicle:1996 Gutted, built XP class Impreza L |
The 245's will be faster, but you will have to roll the fenders. The Z1's are a street tire, and for SM you will be giving up a lot of ground on the R-compounds.
If I were in your shoes, I'd get the 17 x 8's and the 245's, as if you decide to get serious and go with R's, you will be able to fit a 275/40/17 on them and still be able to use most of the tire. ![]() |
#3 |
Member#: 180513
RMIC
how much are r comps, like 250 a piece?
#4 |
Member#: 21118
what an underprepped car...how streetable do u want teh car to be? what do u want to spend money on first?
what wheels do u have now? if u still have the oem 16s, throw entry level Rcomps on that. skip Z1SS if u have not bought them yet. if u still want a new wheel set, make that for the Rcomps. then go to work on ur suspension. |
#5 |
Member#: 48377
Completely depends on the size. 225/50R16 V710's were $210 each last set I bought. The 275/35R15 A6's I'm going to run next year are $244 each. Compare that to star specs at $127 each for the 225's and $235 each for comparably wide 275's. You are getting a cheaper tire that is not nearly as fast.
On a SM car the suspension is pretty free. You can setup the car to really take advantage of the higher grip of an R-comp. A well setup car will be around 3 seconds a lap faster on R-comps than street tires. It's definitely a trade off between $$$ and time. ![]() |
#6 |
Member#: 180513
RMIC
I kind of forgot about just sticking R comps on what i already have.
Here is my full suspension setup 24 FSB, 18mm RSB Spring/strut combo Front and rear strut towers Kartboy Endlinks wrx brake conversion Am i really just better off throwing r comps on the WRX stockers? |
#7 |
Member#: 48377
#8 |
Member#: 180513
RMIC
alright in that case, im thinking of buying either a cheap used set of WRX stockers, or just a slightly wider 16x7 with R comps
thanks for hte help |
#9 |
Member#: 115154
Vehicle:2003 Legacy L Turbo silver |
ah dammit, I have some 16x7 2.5RS wheels (5 spoke) with some Hoosier A6's (225/50) that I've been planning to sell, but I'm away on vacation until January...
#10 |
Member#: 180513
RMIC
that works for me
#11 |
Member#: 58865
RMIC
Vehicle:2004 WRX 99ESP - Drew =) |
like i said on pirates... learn on street tires, be even better on race tires... You'll likely save money on tires in the end...
| Thread Tools | |
| Display Modes | |
| AutoX SM class 04 STi build...Discussion | Dirty25RS | Autocross | 101 | 09-20-2009 10:22 PM |
| FS: 2000 Civic Si, prepped for autox | ButtDyno | MAIC Private Classifieds | 4 | 05-12-2006 03:50 PM |
| Skuttlemotorsports, AutoX SM win with vids! | skuttledude | Motorsports | 13 | 06-25-2005 09:15 AM |
| Engine Swaps or Engine Mods in AutoX SM class... | ScreaminFast | Motorsports | 13 | 12-19-2003 02:08 AM |
| Scca Autox Sm Wrx | AWMIII | Private Vehicle 'For Sale' Classifieds | 14 | 08-28-2003 09:41 AM |
