Old 11-22-2008, 10:20 AM   #1
meat_WRX
Member#: 96919
2004 sti
black
Default Evo X goes 12.24 in 30 degrees!!! BURRRRR
how about a video?
soo..... Was looking for 11's but a 12.24 will do. ill try to get a video up soon. i waiting for a friend to upload it. but heres what the time slip looks like.
R/T .446
60 1.73
330 5.033
1/8 7.804
mph 88.13
1000 10.214
1/4 12.247
mph 111.05
The run was nowhere near what it could of been, i spent alot of time turning the tires, even snatched 2nd..! and bounced the 4th gear revlimiter (7600rpms) 5 TIMES!!!!!!! before i crossed the finish line.
the track was 38 degrees, that was the 2nd run of the day, tires were till cold.
I made 304 @ 27 psi
These passes were made at 26 psi, I can see some 11's this coming up summer on the same setup with a warmer track!
i owe a BIG Thanks to XTREMEBOOST and SPEEDCIRCUIT.
All my big power adders came from Frank at Xtremeboost and Dino hooked it up with a nice mail in flash. Heres the dyno chart. This is up from 270 WHP before the tune.
Heres a Still of my run, taken by Projektphoto.com
for Mods:
Mail in tune
turbo back exhaust, single exit
External dumped factory internal wastegate
upgraded Forge WGA
intake
3" FMIC (factory is 2.75")
gutted trunk
factory tires on 22psi
exedy 4 puck clutch
For a 3800lb car on 300whp, this isnt to shabby guys. just figured id share.
meat_WRX is offline   Reply With Quote
Old 11-22-2008, 10:23 AM   #2
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
ya, nice time... trap is pretty decent as well... your car is probably a bit lighter than 3800 due to the aftermarket parts... 3650ish?
All4bSpinnin is offline   Reply With Quote
Old 11-22-2008, 10:43 AM   #3
moorebl
Member#: 59238
iam actually impressed from a evo and that does not happen often, way to go justin. look forward to seeing that beast
moorebl is offline   Reply With Quote
Old 11-22-2008, 10:50 AM   #4
Chiketkd
Member#: 71634
In hibernation...
Nice run. Which dragstrip did you go to?
Chiketkd is offline   Reply With Quote
Old 11-22-2008, 05:34 PM   #5
meat_WRX
Member#: 96919
2004 sti
black
VMP... besides being cold as ****, track was in good condition.
Old 11-22-2008, 06:38 PM   #6
treystoys
Member#: 97436
05 Legacy GT
white
You might try with the tires around 25-30 psi...I know in my wrx, if I go lower than 25 psi I loose a bit in the traps.
Nice runs reguardless
Trey
treystoys is offline   Reply With Quote
Old 11-22-2008, 08:04 PM   #7
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
nice, as usual the evo crowd is making alot more progress, lol.
mxpunk is offline   Reply With Quote
Old 11-22-2008, 08:13 PM   #8
Clark_Kent
Member#: 114299
Nice run Justin. I'm sure with more seat time and/or a custom tune you'll be in the 11s easily.
Clark_Kent is offline   Reply With Quote
Old 11-22-2008, 09:37 PM   #9
meat_WRX
Member#: 96919
2004 sti
black
with a 60 degree day, and a 1/8 of C16, i might be in the 11's... haha
this run was made with almost a full tank of 93oct, Weight reduction!!
Old 11-22-2008, 10:42 PM   #10
marrenr813
Member#: 135668
2015 WRX
Whar makes this car so heavy?
marrenr813 is offline   Reply With Quote
Old 11-22-2008, 11:25 PM   #11
Clark_Kent
Member#: 114299
Overall, the GSR Evo X is just a bigger vehicle than the VIII and IX GSRs. Its only about 240lbs heavier. Larger wheels, tires, sound deading in the cabin among several others.
Old 11-22-2008, 11:41 PM   #12
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
you owe me a jacket... and a beany. I beat you!
japslapr is offline   Reply With Quote
Old 11-22-2008, 11:42 PM   #13
marrenr813
Member#: 135668
2015 WRX
That is what I was afraid of...
I feel like my car and the last gen evos are too heavy as is...
With teh price of new cars right now I wish there was a NEW vehicle out that I wanted(lighter) and/or could afford (~$30-35kish).
Old 11-23-2008, 12:03 AM   #14
Clark_Kent
Member#: 114299
It doesn't matter when you can make power effortlessly. It does seem somewhat early but a member on EvoM ran a 12.3 at 110 on a tuned Evo X. No mods. Just a dyno tune on 93 octane pump gas. IMO, the Evo VIII and IX and the GD STi are lightweight sedans. Relatively, 3200 is more than reasonable for a performance sedan.
Old 11-23-2008, 02:41 AM   #15
meat_WRX
Member#: 96919
2004 sti
black
well teh evo X weighs in at about 3800lbs, and i ran a 12.2 with 300 whp. that is pretty damn good. so more weight, might mean better technology also. they even themselves out.
Old 11-23-2008, 02:42 AM   #16
meat_WRX
Member#: 96919
2004 sti
black
fauck!!!!! did i bet you the benie? ****.... iight, ill thow them both in the car, next time i see your car at all aspects, ill steal your turbo and leave the jacket in its place.
Old 11-27-2008, 10:33 AM   #17
meat_WRX
Member#: 96919
2004 sti
black
bump, because i added a video!
Old 11-27-2008, 03:29 PM   #18
axion7606
Member#: 32747
08 EvoX & FJ Tank
Lets not forget extra weight is from stiffining up the car for better handling as well.
the evo x is responding to mods insanely.
At HBSpeed I dynoed 294whp with just a intake and bigger FMIC. You guys already know what stage 2 sti's do on this dyno.
With a little tweaking of the ecu (no timing adjustments yet)and a test pipe I put out 334whp/329tq while running stock catback still
Nice times! I want to see what my car does after I install my 02 housing TBE and go for a retune with AP and timing adjustments and raise the rev limiter! chuu!
axion7606 is offline   Reply With Quote
Old 11-27-2008, 03:58 PM   #19
Dizzuque
Member#: 98699
2007 SWP WRX
cool, i believe i saw this posted on vadriven. nice car.
Dizzuque is offline   Reply With Quote
Old 11-28-2008, 12:37 AM   #20
resideinva
Member#: 179641
2005 LGT Wagon 5spd
RBP
ive seen this car around before. i believe i saw it up at greenbrier mall within the past week or so actually...?
i know youve been working on it for a while now so idk.
congrats on the times man
resideinva is offline   Reply With Quote
Old 11-28-2008, 12:49 AM   #21
atenzany62
Member#: 163172
good numbers man
atenzany62 is offline   Reply With Quote
Old 11-28-2008, 01:49 PM   #22
mattyk04
Member#: 104256
2005 STI
nice run justin
mattyk04 is offline   Reply With Quote
Old 11-30-2008, 08:14 PM   #23
meat_WRX
Member#: 96919
2004 sti
black
ya you probably did... ita about to go in the garage as im doing to testing for grimmspeed, adding meth to the equation and shooting for stock turbo 10's next summer.
Old 11-30-2008, 08:15 PM   #24
meat_WRX
Member#: 96919
2004 sti
black
you did.
Old 11-30-2008, 08:20 PM   #25
meat_WRX
Member#: 96919
2004 sti
black
apparently i have a low reading dyno.. the guys said i shoudl be closer to 350whp to run that kind of time..
i think youll also find that if you g o back to the dyno, your car might read lower as it has corrected itself through the ecu. alot of people are getting insane numbers for marketing and then you dont see those gains on your pearsonal car. i know i didnt see the claimed 40 whp with a intake and MBC..
What's the biggest technological difference in your life since 12/24/99? Hamsterstyle Off-Topic 70 12-25-2009 12:12 PM
Would you stand outside for a hour in the 30 degree temps and rain? Sharkbait Off-Topic 50 01-19-2009 06:42 PM
Anyone have a 10-22 or 12-24 lens in Raleigh area? trhoppe South East Region Forum 2 05-30-2007 03:35 AM
wow...12 bids in 30 seconds Johnny Knoxville Off-Topic 8 08-26-2005 09:12 PM
