Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 11-22-2008, 01:14 PM   #1
wrxphantom
Member#: 128643
2013 STI Sedan
Default HID Conversion 2009 WRX
I have a 2009 WRX and wondering how i can go about getting my headlights upgraded to HID. I was looking at the HID sticky and couldn't find a 100% answer.
Would i need to do an HID conversion?
What would i need to convert to HID at a reasonable price?
I was looking on ebay, (maybe not the best place to look, but a good place to start.)
http://cgi.ebay.com/ebaymotors/Xenon...08#ht_5311wt_0
What lights are in the 09 wrx?
Any info would help.
wrxphantom is offline   Reply With Quote
Old 11-22-2008, 02:38 PM   #2
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
thats not what you need by any means to do it properly
that is the "cheap/ricer" kit
to do it properly would cost a good amount of money as you would need to buy projectors for your headlights, retrofit them, and get a real HID kid
you cant do it for cheap, simple as that
Jncominco2 is offline   Reply With Quote
Old 11-22-2008, 02:56 PM   #3
wrxphantom
Member#: 128643
2013 STI Sedan
or just buy the 2008 or 2009 sti headlights... would that work?
Old 11-22-2008, 03:01 PM   #4
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
that could work too, but again, it wouldnt be cheap
HID headlights, usually even used, are quite expensive
Old 11-22-2008, 03:44 PM   #5
wrxphantom
Member#: 128643
2013 STI Sedan
sweet at least i am left with another option
Old 11-22-2008, 04:51 PM   #6
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
you can either retrofit which isn't as easy or just find a wrecked sti and get its headlights and hid components.
the problems with hid kits from ebay or other hid components in your 09 halogen projectors stem from the optical differences of the aiming surfaces inside the projector that can't be changed.
the beam will be narrow, unfocused, and too sharp of a gradient(too bright in the middle, too dim on the sides). it results in DECREASED performance because your eyes can't adjust well to hazards in the majority of the viewing field.
if you get sti lights you'll have an even, sharp, focused, and properly adjustable beam. it's easily worth the extra money.
alternatively, you can just keep the oem lights with 55w halogen bulbs. unless you're blind as a bat, they're perfectly fine to see by for most situations and they don't cause problems for other drivers. even blue-coated halogen bulbs are better than a rebased HID 'kit'.
Handsdown is offline   Reply With Quote
Old 11-22-2008, 05:31 PM   #7
Lboogie
Member#: 171611
2014 FiST
Blk
That kit is only going to be enough for low beams OR high beams, but not both. If the low beam is in a projector , then it'll be an okay start. Definitely don't toss an HID kit on a reflector type (i.e. the high beams) because you'll blind everyone.
Lboogie is offline   Reply With Quote
Old 11-23-2008, 01:56 PM   #8
steverx05
Member#: 128269
'12 Audi TT-RS
Suzuka Grey
Wrong. Did you not even see the post above yours? HID kits do not work in ANY halogen headlight PERIOD. Not even projectors.
steverx05 is offline   Reply With Quote
Old 11-24-2008, 08:59 AM   #9
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
the reason not to use them in highbeams is because they will get damaged from being turned on and off before the salts color cycle.
just don't do it without retrofitting hid optics.
Old 11-24-2008, 12:39 PM   #10
JavaBot
Member#: 156723
05 srp foresterX
rip 2.0i/2.5rs
Since you have projectors already though the retro would be easy. Just get some FX35 projectors off ebay for like 80 bucks and retro them into where yours are and then put a nice kit in there. Talk to Caesar from Lightwerkz he has some quality products and info. Just make sure you've got the right kit for your car and you should be good to go on high and low beams. You're looking at about a $300 retro with lightwerkz kit and fx35 projector shrouds. GL let us know how it turns out. Cheers -M
JavaBot is offline   Reply With Quote
Old 11-24-2008, 12:54 PM   #11
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
im pretty sure that fx35s wont fit into the 2009 headlights. fx35 is bixenon, and the projector is much bigger than the tsx or s2k.
after looking at caesar's site, it looks like tsx or s2k is the way to go. you wont need shrouds because the 09 already has projectors and shrouds.
it will probably be about 400 bucks after all is said and done.
jdubya301 is offline   Reply With Quote
Old 11-24-2008, 02:18 PM   #12
JavaBot
Member#: 156723
05 srp foresterX
rip 2.0i/2.5rs
Thank you for the clarification, I'm not too up to date on 09 logistics quite yet... Although if you still have usable shrouds the projectors themselves shouldn't be all that expensive. Right? You could prob do a retro for under 400 whatddya think
Old 11-24-2008, 03:19 PM   #13
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
The posts above talking about getting 08/09 Sti HIDs would be your best bet and true for what was said. That alone with push me to find a set.
ejicon is online now   Reply With Quote
Old 11-24-2008, 07:32 PM   #14
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
08/09 sti lights are not the best way to go. the only benefit of installing sti HIDs are the fact that you would have leveling motors.
being almost brand new, any 08/09 sti headlight set is going to be too expensive.
tsx or s2k projectors are far superior to sti optics also. you will get a much brighter, focused, and wider beam from tsx or s2ks
Old 11-24-2008, 07:38 PM   #15
JavaBot
Member#: 156723
05 srp foresterX
rip 2.0i/2.5rs
^^ +1... go tsx if you can afford it. Best bang for your buck for sure.
Old 11-25-2008, 01:06 AM   #16
Lboogie
Member#: 171611
2014 FiST
Blk
Prove it
Old 11-25-2008, 01:29 AM   #17
steverx05
Member#: 128269
'12 Audi TT-RS
Suzuka Grey
Prove it
I don't have to prove crap. It's already been proven. Just do a search on the internet and you will find sites (like Daniel Stern's) that give SCIENTIFIC FACTS about why kits just don't work, no matter what you do.
The dozens of pictures I have seen of HID kits in halogen headlights ALL with complete piss poor results is proof enough.
The last THREE....count it with me, THREE times I have asked for photographic proof from someone claiming their HID kit produces no glare, ALL THREE TIMES NO PICTURES WERE POSTED! There's your damn proof right there.
Old 11-25-2008, 11:18 AM   #18
ritky
Member#: 72285
2003 WRX PSM w/FXHID
FLA Turnpike > I-95
Lboogie is probably just talking about semantics.....
Yes, you can put in a hid kit and yes you will get light output...so it does "work". Will it be well focused and have minimal glare? Most likely not.
ritky is offline   Reply With Quote
Old 11-25-2008, 11:40 AM   #19
ritky
Member#: 72285
FLA Turnpike > I-95
Taken from a different thread
2008 WRX HID kit (I think)
2008 STi HID factory
Old 11-25-2008, 11:53 AM   #20
steverx05
Member#: 128269
'12 Audi TT-RS
Suzuka Grey
^^^ There's some "proof" right there ^^^
Old 11-25-2008, 12:40 PM   #21
JavaBot
Member#: 156723
05 srp foresterX
rip 2.0i/2.5rs
That actually looks pretty decent. I know I know I see the glare but that is much better than the drop in kits you see in halogen reflector housings... Anyway, even though I recommend a projector retrofit because you're setup for it, I'm not really telling you what to do. However there is some great info in this thread. GL
Old 11-25-2008, 01:55 PM   #22
steverx05
Member#: 128269
'12 Audi TT-RS
Suzuka Grey
I would have to disagree with you. The top two pictures Ritky posted have extremely unsafe levels of light bleeding above the cutoff. The first picture doesn't look as bad as the second because (conveniently) the lights aren't against a flat wall. You can, however, STILL see a ton of glare in the first picture. Just look at the blue wall to see what I'm talking about. The third picture is in fact a stock STi HID setup, and you can see there is virtually no glare.
I'm not trying to knock your opinion msesno, I am just trying to make a valid point.
Old 11-25-2008, 02:32 PM   #23
JavaBot
Member#: 156723
05 srp foresterX
rip 2.0i/2.5rs
I hear you steve, and totally agree. There is a good amount of glare above the cutoff and I was more saying the cutoff itself is very good. Perhaps one could retro some sort of shield to eliminate that extra glare above the cutoff? I know it has been tried but it seems like if you get rid of the upper bleeding you'd be money.
Old 11-25-2008, 02:44 PM   #24
bzbuzz
Member#: 116052
2011 STI ( Sold )
the cut off in the picture looks better than my 06 wrx projector...
bzbuzz is offline   Reply With Quote
Old 11-25-2008, 03:18 PM   #25
steverx05
Member#: 128269
'12 Audi TT-RS
Suzuka Grey
Ah ok, I see what you're saying. I definitely agree...if there was some easy way to modify a halogen projector shield to make it usable with an HID kit, I would be all for that idea. But at that point, it would make sense to just go one step further and just swap out the halogen projectors for HID projectors and get the best lighting possible
HID Conversion 05 WRX nerdydorkus Electrical & Lighting 25 02-13-2007 12:54 AM
06 WRX HID Conversion - Buy STi headlights or buy HID kit? Pastapuck Newbies & FAQs 3 11-17-2005 11:25 AM
McCulloch HID Conversion Kit for WRX RS 9007 Bulb Size WRXerist Private 'For Sale' Classifieds 22 02-23-2005 05:03 PM
Post your HID conversions on 04 WRX Speedadickt Member's Car Gallery 76 12-30-2004 12:05 AM
FS: McCulloch 6000K HID conversion kit for WRX ghs2k Private 'For Sale' Classifieds 12 04-10-2004 06:14 PM
