Old 11-22-2008, 05:12 PM   #1
sti04dude
Member#: 96742
2014 ZL1 Camaro
Unhappy STi Timing Marks Won't Line Up ! ! !
I have been rotating the engine of my 2004 STi for a long time in a futile attempt to get all seven (7) timing marks lined up.
Although it defies logic to me, the relative position of the marks on the cam gears and belt change with every complete cycle of belt rotation.
As you spin the motor over time, the marks get closer, miss their exact alignments, and then start their cycle again.
Nowhere is this mentioned in any manual or write up.
It is always just, "Rotate the motor until all of the marks line up".
Well..okay...but I have been doing that and they are not lining up.
Somebody PLEASE provide some insight into WTF is happening how to remedy the situation.
Thanks very much.
sti04dude is offline   Reply With Quote
Old 11-22-2008, 08:23 PM   #2
mikeythejew
Member#: 141672
Sometimes you will not get all marks to line up 100% perfectly, even with a correct installation. This is known and not debatable.
mikeythejew is offline   Reply With Quote
Old 11-22-2008, 08:27 PM   #3
sti04dude
Member#: 96742
2014 ZL1 Camaro
The closest I got the marks to line up is perhaps 3 - 6 teeth off.
I would think that TDC would arrive once every complete belt rotation,
and that all of the marks would align at that time.
But, as I noted above, the alignment cycle is definitely not once every belt rotation.
The car runs great, and has never been apart, so I do not suspect anything unusal...
Old 11-22-2008, 08:45 PM   #4
mikeythejew
Member#: 141672
Here you go. Click on the top, "dohctbelt" PDF file. It's published via the end wrench = good info.
http://www.scoobymods.com/forums/sho...ht=timing+belt
Old 11-22-2008, 08:57 PM   #5
sti04dude
Member#: 96742
2014 ZL1 Camaro
Thanks for the link.
I was using that pdf throughout the day, although my cam pulleys are not what is shown.
However, it still does not address my situation where the marks do not line up,
and how the belt/pulley mark relationship changes with each belt rotation.
Perhaps the STi is different ?
Old 11-22-2008, 09:20 PM   #6
WRXDK
Member#: 187983
2005 WRX
Getting the marks on the belt to line back up with the marks on the gears only happens every ???? revolution. I am pretty sure that you should be concerned with the marks on the gears only (and covers). If for some reason you are going to re-install the belt, you could make new marks. If you can see the original marks you can use those to re-install the belt. If you are removing the belt make sure you have the left side(driverside) cam gears locked so you dont bend valves.
I am sure some one will correct me if I am wrong.
WRXDK is offline   Reply With Quote
Old 11-22-2008, 09:22 PM   #7
dunk
Member#: 15359
No,
They mean the marks on the cam gears, not the marks on the belt.
Rotate the motor until the mark on the crank pulley is under the notch below the crank sensor and the two double hash marks on both cam gears are pointing towards each other.
Now you're at TDC and you can remove the belt. If you're planning to reinstall the same belt you should paint new reference lines on the belt with a marker.
Duncan
dunk is offline   Reply With Quote
Old 11-22-2008, 09:22 PM   #8
dunk
Member#: 15359
Beat me to it.
Old 11-22-2008, 09:26 PM   #9
sti04dude
Member#: 96742
2014 ZL1 Camaro
All of the original mechanical and painted marks on the belt and pulleys are clearly visible.
If all four (4) cam pulleys are properly lined up, then are you assured that the crank pulley is also in the proper position ?
If so, why do all of the manuals and instructions tell you to specifically align all seven (7) marks ?
Thanks for everyone's input...every bit helps !
Old 11-22-2008, 09:28 PM   #10
rick-l
Member#: 33868
2003 wrx
srp
I worried about the same thing since it is a $3000 mistake. http://forums.nasioc.com/forums/show....php?t=1587945
It took a while to convince myself that they shouldn't line up after 1 revolution but when I counted the teeth I believed.
They will line up again in 281 revolutions.
rick-l is offline   Reply With Quote
Old 11-22-2008, 09:43 PM   #11
dunk
Member#: 15359
1 - crank mark
2 - drivers side cam marks to back cam cover
1- drivers side intake cam to drivers side exhaust cam
2 - passenger side cam marks to back cam cover
1 - passenger side intake cam to drivers side exhaust cam
= 7 marks total
Duncan
Old 11-22-2008, 10:48 PM   #12
sti04dude
Member#: 96742
2014 ZL1 Camaro
281 revolutions (my assistant got a kick out of that !)...
That explains my sore arms !
The proposed solution sounds promising...
My concern is that some posts (like munkis on the referenced thread)
mention a "pulley-cover" mark alignment.
However, there are only pulley-pulley and belt-cover mark alignments.
My understanding is to line up the pairs of left and right pulleys,
and to forget about the belt marks.
Question: when the pulley-pulley alignments are correct,
is the crank pulley also, by default, in the proper position ?
Thanks again to everyone.
With any luck, I may actually get this finished tomorrow !
Old 11-22-2008, 10:59 PM   #13
dunk
Member#: 15359
There's a mark on the crank pulley and it lines up to a notch below the crank sensor.
Anyways, since the cams spin at half the speed of the crank the cams will line up on the correct marks every two revolutions of the crank.
Duncan
Old 11-30-2008, 11:31 PM   #14
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
I am doing cams on a EJ20G and alldata says to line up all the crank and cams (noprob right) then line up the dotted mark on the belt for the crank (A) lineup the left intake cam (B) left exh(C) then I put it through the water pump and the first idler gear (toothed one) then right int cam(D) right exh cam (E) then it says to pull it over the last idler (OVER THE OIL FILTER) then tensioner pull the pin! butt EVERY TIME I TRY TO GET IT OVER THE LAST IDLER IT PULLS THE LEFT CAMS OUT OF POSITION AND ENDS UP THAT SOME CAM OR CRANK IS ALWAYS OUT) SO WHAT SHOULD i DO? cause I"M going to flip cause its been like 8 or more times I've tried and even had like 3 techs help and they can't figure it out either any help would be greatly appreaciated!!
thanx jesse
94 GT is offline   Reply With Quote
Old 12-01-2008, 09:15 AM   #15
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Take that lower idler pulley off.
Put everything on and line it up, put the tensioner in but dont pull the pin.
Then pull up on the belt, and install the idler pulley into its poisiton.
Make sure everything is lined up then pull the pin.
Old 12-02-2008, 12:16 AM   #16
94 GT
Member#: 193676
94 legacy GT
thanks man I thought of that but I thought that when you put it back on that it would do it agaian!! but on fri I will try that way!! kool ! but if I have the same prob , can I leave the timing marks on the left cams(both) a little advanced so when it pulls it pulls them straight, cause all the slack is were the tensioner is right?????
thanx again ,Jesse
Old 12-02-2008, 10:32 AM   #17
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
yeah you can do that. as long as all the marks line up properly when you are done.
Old 01-26-2009, 07:24 PM   #18
bloopsta26
Member#: 131371
05 buy my parts so
i can get my sti running
how would you know if timing is off? and if it was off how would you check it?
bloopsta26 is offline   Reply With Quote
Old 01-31-2009, 07:18 PM   #19
jakeafi
Member#: 159678
2005 WRX STi
Obsidian Black
rotate the motor by hand stop if u feel any tension, if it speins freely and marks look very close ur in time
jakeafi is offline   Reply With Quote
Old 04-01-2009, 12:40 PM   #20
bloopsta26
Member#: 131371
05 buy my parts so
okay soo i have been doing my timing a bagillion times....after i get the belt and everything on. all the marks are perfect. i turn the crank around and the marks are all off... like the double notches are off by a smudge. do they have to be dead nuts even or can they be alil off. like i mean u really have to look at it....
Old 04-02-2009, 01:07 AM   #21
rick-l
Member#: 33868
2003 wrx
srp
The marks on the belt will be off but the 5 reference marks line up.
They will line up again in 281 revolutions (but I didn't try it).
FS : STi intake manifold and throttle body jcovey2.5 Engine/Power/Exhaust 173 12-05-2011 09:38 PM
timing marks lined up, still rough idle? ravenlunatic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-12-2010 01:45 PM
Please Help!!!Timing marks on a 04 STI Maxspeed23 Service & Maintenance 1 07-04-2008 12:12 AM
Timing mark line up questions? Elitestuntz Service & Maintenance 2 10-16-2006 10:51 PM
Intercooler Won't line up icantdrive75 Newbies & FAQs 4 11-05-2005 07:02 PM
