Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 11-22-2008, 10:53 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default What Lies Beyond Bolt-Ons?
As soon as I get the header shootout completed, I'll have done all the common bolt-ons (intake, header, cat delete/hfc) as well as have tuned the car to take maximum advantage. For a variety of reasons, I have a feeling I'll be rebuilding my engine sooner rather than later (it just doesn't act healthy and it's getting worse). If I'm going to have the engine out of the car for a rebuild just to make it run again, I may as well do whatever it is you do to engines while you have it apart. The problem is that I just don't know what else one does to an engine.
Personally, I prefer to chase the broadest torque curve rather than the highest peak power. If I can do a mod that will boost torque in the 2k-5k, or even 3k-4.5k range but it will hurt me above 5k, I'm down with it. I'd much rather be able to press the pedal and surge forward than have to downshift two gears, wring it out to redline, shift, wring it out again, etc to make a pass. I'm not sure if that influences the suggestions or not.
Keep in mind, I'll do my usual exhaustive research on anything suggested. I just don't know what's possible at this point (the NA Whitepaper really isn't that helpful).
Old 11-22-2008, 11:25 PM   #2
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default as seen on tv
the tornado! supposed to give you like 10 ft lb's!!!!!
http://www.tornadoair.com/buy1/
watchunglava is offline   Reply With Quote
Old 11-22-2008, 11:28 PM   #3
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
Cams, PnP, high comp pistons.
Zac86 is offline   Reply With Quote
Old 11-22-2008, 11:29 PM   #4
watchunglava
Member#: 168862
supercharger!!!! its 6 k though
Old 11-22-2008, 11:31 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I cant remember what you have done to your motor off the top of my head right now.
But have you done cams? There is an extra 10-12hp right there, and with a tune you could really take full advantage. Not exactly a "bolt-on", but definately something worthwhile to do to your motor.
I have delta spicy's in my SOHC EJ25, and it really wakes up around 3600.
~Josh~
Old 11-23-2008, 02:01 AM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I'm considering cams. The only problem is the labor to get them done. It's $$$ and would be the first thing I didn't do to the car myself. I'm just not sure I could pull it off on my own.
Old 11-23-2008, 02:07 AM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
most of the labor is getting the cams in and out of the motor, WITH the motor still in the car. If you're already pulling it for a rebuild, cams would be much cheaper to put in, even if you send the heads off for the cams to be put in that way...
rougeben83 is offline   Reply With Quote
Old 11-23-2008, 03:37 AM   #8
Zac86
Member#: 136919
ABP
remove intake manifold and exhaust manifold, remove heads. Send out heads to be PnP or just replace the stock cams. I dont reckon this be too hard.
Old 11-23-2008, 03:41 AM   #9
watchunglava
Member#: 168862
Default lol
its really time involved . http://techinfo.subaru.com/diagnosti...a_WRX_and_STi/
Old 11-23-2008, 04:15 AM   #10
Zac86
Member#: 136919
ABP
wtf that site says you need to remove the cams before you take off the head.
Old 11-23-2008, 11:40 AM   #11
inkpreza
Member#: 142064
2001 Dodge Ram Sport
1973 MGB
subscribed, the williaty investigations always yield great results, I am also wanting the torque over HP and this will hopefully lead me down the correct path.
inkpreza is offline   Reply With Quote
Old 11-23-2008, 12:15 PM   #12
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
On dohc heads the cams cover the head bolts( cams must be removed first). On sohc heads you can pull the heads with the cams in.
You also have the buckets on the dohc heads which must be measured/swapped/machined to get the correct lash with new cams. The sohc heads have adjustable rocker arms for lash adjustment.
Tim Sanderson is offline   Reply With Quote
Old 11-23-2008, 12:26 PM   #13
Skidd
Member#: 1853
GC6 Supercharged
STM
Hopefully less
http://www.rs25.com/forums/showthread.php?t=92852
But... if you have not done it.. go get the Delta 2000 cams. Worth EVERY PENNY and bruised knuckle lashing the drivers side!!
Skidd is offline   Reply With Quote
Old 11-23-2008, 12:49 PM   #14
Blacksails192
Member#: 142686
back to european
spray?
Blacksails192 is offline   Reply With Quote
Old 11-23-2008, 12:51 PM   #15
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Never.
Old 11-23-2008, 01:03 PM   #16
Storm
Member#: 5218
96L Most Over-
Developed Beater
Willaty, don't let the labor of installing cams even be an issue. It is FAR easier to do the cams, than in doing a full rebuild. I would be willing to find Powell, OH. and lend a hand if needed.
My suggestion for your goals would be an overbore and higher compression pistons, mild cams for a broad range of increase, and a mild port and polish of the heads. Keep everything mild and the curve will flatten out. The overbore will increase torque and compression ratio, hi compression pistons will further improve torque. The cams and PnP will improve the airflow for torque and power if kept to a moderate level.
Jay Storm
Old 11-23-2008, 01:09 PM   #17
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I thought there wasn't much room to bore these blocks?
Old 11-23-2008, 01:29 PM   #18
Storm
Member#: 5218
96L Most Over-
Developed Beater
There isn't, really. It's about .5mm limit. The easiest option would be a set of 100mm pistons with a CR of 11.xx-ish to 1. Get the pistons and have the block bored to match them.
Jay
Old 11-23-2008, 01:33 PM   #19
ballitch
Member#: 74907
98 cam'd EJ251
You can bore them .020'' over, which gets you too 100mm.
Cams for that motor are easy, setting the valve lash is the difficult part. If you buy a T45 (torx) bit and a small set of metric hex drivers, you can do the cam install yourself. I just bought a Chiltons manual and went to it.
~Josh~
Old 11-23-2008, 01:42 PM   #20
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Honestly, I'd love to just do the cams, even before an engine rebuild. However, 3 years ago, the only thing I'd ever done to a car was change the oil. I actually didn't even do anything to my car until I did my own 30k service. Then I started the heavy suspension mods about 2 years ago and learned that as I went along. I've never done anything inside or with an engine at all. So I really have absolutely NO experience that would help me pull off the cam swap at all.
So, all the stuff you see me publishing happens from me doing the research, then the experiment, then writing it up. It's all stuff I'm doing for the first time.
Storm, I might just take you up on that offer to help me install cams someday.
Old 11-23-2008, 02:08 PM   #21
jordan s
Member#: 122233
1997 Legacy GT
Aspen White 5MT
how many miles do you have on that motor? do you think all the tuning you do has effected it?
jordan s is offline   Reply With Quote
Old 11-23-2008, 02:10 PM   #22
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
74,500 miles. If anything, I think the tuning has extended its life. The engine was never really "right" from the factory. It always knocked like a mofo and consumed A LOT of oil. The fuel mileage has steadily gotten worse since break-in as well. Really, I think one of the cylinders has/is about to let go.
Old 11-23-2008, 02:53 PM   #23
rougeben83
Member#: 115154
2005 Outback XT
White on grey
rebuilding a motor usually takes more work than doing just the cams. If you can do the former, you can certainly do the latter.
Old 11-24-2008, 12:18 AM   #24
watchunglava
Member#: 168862
Default no foolin
personally and im sure 90% of people around would agree if .20 is the max bore size for our clinders, you only want to go .10 because if something ever goes wrong you can still use that .10 left to bore it out one more time .
~Josh~
Old 11-24-2008, 12:44 AM   #25
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
when i replaced my block, I smoothed out every corner of every fluid passage that I could. There were a couple of oil passages that really needed it, too. This probably won't net you much(if any) torque, but it's sure to reduce some pumping losses. Hell, smooth out the oil pump and match it to the block, they're not as lined up as one might think.
2004 wrx sti bolt-ons what am I missing carscrash83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 05-14-2010 06:44 PM
What will i make for power? Ver 8. EJ207 with small bolt ons... prokaw875 General Community 10 09-25-2009 06:22 AM
cant find dyno with cobb stage 2 AND bolt ons (hoses, inlet and what not) jimtweet Engine Management & Tuning 1 03-27-2005 11:03 PM
What Garrett turbos are bolt-ons if any? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 50 03-06-2003 11:57 AM
what are all the bolt ons? joe_white Proven Power Bragging 4 12-10-2002 10:29 AM
