Old 11-22-2008, 11:10 PM   #1
dustin 2008
Member#: 195250
Default need help
i have a 2008 impreza 5 door and im wanting to put a turbo on. i cant seem to find any where to get the turbo or information on what else needs to be done to my engine it has the 2.5i so if any one can help please let me know
dustin 2008 is offline   Reply With Quote
Old 11-23-2008, 12:04 AM   #2
Lugal
Member#: 193865
You do know that you're gonna have to build the motor first to handle that turbo right? Why did you buy an N/A car to turbo when there was a turbo version available....
Lugal is offline   Reply With Quote
Old 11-23-2008, 12:54 AM   #3
2006WRX4ME
Member#: 134286
2006 WRX Limited
I would look towards suspension mods. The amount of money that it will cost you to upgrade to turbo and supporting it is not worth IMO. Throwing on some decent springs, shocks, and sways would make that car a fun ride.
2006WRX4ME is offline   Reply With Quote
Old 11-23-2008, 01:24 AM   #4
wrxskier18
Member#: 88005
2002 WRX PSM
GS500
^^ I def agree. On a 2.5i, go with suspension mods. Getting a turbo would be expensive. If you do it, you would probably blow your motor (almost all stock block n/a 2.5 turbo's do). Any powertrain/drivetrain problem you had would not be covered under warranty either.
If you want a turbo, trade it in for a wrx. Seriously. It will cost less in the long fun for sure. And you get the other goodies, too.
wrxskier18 is offline   Reply With Quote
Old 11-23-2008, 01:52 AM   #5
Web Foot STi
Member#: 39086
2004 STi
The N/A 2.5 ltr engine isn't the same as the WRX 2.5 ltr engine. There is a reason that you can't find the info...
There are some older turbo kits around because back before 2002 Subaru didn't import the WRX. With the factory version available the kits just died off.
Web Foot STi is offline   Reply With Quote
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain 0 06-04-2010 08:53 AM
Need help!! Need to find a +12v switched wire NOW! Please help! nxwrxfx Electrical & Lighting 16 04-25-2006 05:29 PM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain 7 04-18-2003 12:11 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
Message Board Statistics All times are GMT -4. The time now is 07:20 AM.
