Old 04-10-2009, 08:16 PM   #51
fantomas
Member#: 87500
2012 Outback 2.5i P
Graphite Gray
Originally Posted by carnz-pj-410 View Post
yeah. why not just get the auto hvac stuff? since the hardest part(the wiring) is already done for you with the stock 05 wrx harness
I already have EVERYTHING for an 02 dash..
fantomas is offline   Reply With Quote
Old 04-29-2009, 02:37 AM   #52
fantomas
Member#: 87500
2012 Outback 2.5i P
Graphite Gray
So anyone that has done this or is looking to do it let me know because i'm looking for 02-04 WRX HVAC plugs and i guess i'll have the 05 HVAC plugs to give up!
Old 04-30-2009, 02:30 AM   #53
Unrealgtx
Member#: 178853
2007 Sleeper Suby
id rater just buy and entire sti interior harness and get auto hvac tha way
Unrealgtx is online now   Reply With Quote
Old 04-30-2009, 07:01 AM   #54
carnz-pj-410
Member#: 110994
2004 Impreza WRX STi
the sti bulkhead harness(which is what you need) is over $1000 at the parts dept
carnz-pj-410 is offline   Reply With Quote
Old 05-08-2009, 09:02 AM   #55
sxotty
Member#: 95600
2003 WRX wagon
Holy craptastic those wires are going to be madness if something ever goes wrong in your car Once the masking tape falls off that is. I want to do something far simpler and am wondering how many colors of wire I need to differentiate it... I guess none But I will still definitely try to get 3, for hot ground and random other stuff.
sxotty is offline   Reply With Quote
Old 05-08-2009, 12:20 PM   #56
carnz-pj-410
Member#: 110994
when I did this(i made the wiring diagram for Loomin) i used 5 colors so if i ever need to diagnose it wont be as bad
Old 06-02-2009, 03:23 PM   #57
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
not likely that anything will fail in regards to the wires themselves. the sheilding is very durable.
Loomin is offline   Reply With Quote
Old 08-09-2009, 06:40 PM   #58
Waking The Fallen
Member#: 125950
2010 BMW 135i/05 Sti
7.3 F350/06 Audi A4
pics of it finished???
Waking The Fallen is offline   Reply With Quote
Old 08-12-2009, 04:07 AM   #59
soon2brb240
Member#: 103089
I'm curious what all it'd take for me to do the 05-07 auto controls in my 04 sti? From what I've read in this thread, it seems all I'd need would be the controls themselves, the trim that goes around them, the 05-07 center console and e-brake lever?
Can anyone confirm this for me?
soon2brb240 is offline   Reply With Quote
Old 08-31-2009, 06:25 PM   #60
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
Did anyone have problems with the cig lighter? Mine has power (but doesnt illuminate the "ring"). Once I turn the lights on then the socket looses pwr. I could of sworn I saw something about re-pining the connector... Anyone know what I need to change? My swap was '04 STi to 05 STi console/HVAC. I already had auto climate control so this was supposed to be plug and play. Everything else works 100%.
BVM is offline   Reply With Quote
Old 08-31-2009, 08:24 PM   #61
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
Figured it out using Ohm's law.
re-pin cig lighter harness side connector to:
Red to Yellow
Green to Blue
2 black wires go:
Black to Black
Black to White
Old 09-02-2009, 03:31 AM   #62
soon2brb240
Member#: 103089
So it is true, that since I have an 04 sti, the 05+ auto climate control swap is plug and play, with the exception of the cigarette lighter?
Old 09-02-2009, 07:51 AM   #63
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
Well that and you have to move a few things around but other than that, it was very simple.
Old 09-02-2009, 12:24 PM   #64
soon2brb240
Member#: 103089
Nice! I'll be doing this in the near future now, thanks for the info!
Old 10-20-2009, 04:51 PM   #65
sxotty
Member#: 95600
2003 WRX wagon
This thread is great glad to see all the awesome info here. Eventually I may do this, but for now I finally got everything ordered to finish my swap from 03-->05 door panels and center console with manual controls still. Hopefully wiring up the side mirrors will not be a big deal. The part number is 81820FE370 for the drivers door wiring harness btw if anyone cares. I could not find a junk yard anywhere with the harness, or if they had it would sell it... No one had a subaru harness, but the mirror plug was used in toyotas too so I thought I might have luck there. Nope they were afraid to sell a wiring harness for the wrong car. Thought you would burn yourself up or something crazy.
Old 11-13-2009, 05:23 PM   #66
sxotty
Member#: 95600
2003 WRX wagon
Just to help out I am cross posting what I did in the door swap thread to this, plus adding a bit of content.
So I swapped out the harness which was quite laborious to get the rubber boots in.
Anyway I have some photos
2003
and
2006
There is one additional pin in the dead center assignment 13 circled in red. This pin brings in power to the mirror switch it is wire YR going into the mirror switch on an 03. Exercise caution here as on the car side there is a ground connected to the spade connector. Hence you need to cut the ground and solder the extended YR to it, or bypass the connector entirely with YR. If you do not you will blow fuse 4 in the fuse panel.
Pins 20-22 have to do with the mirror for 2003-2005 swap with a new harness in the door (circled in yellow)
20: Light Green (Lg) Door side on new harness: LR car side This will need to be soldered to wire in center going to right mirror which is (Lg)
21: RL door side: RB car side solder in center to RL
22: Red Door side: Red car side and should be connected to Red in center
Solder them as shown, the crossed wires hook together and the YR wire in middle extend to the door connector shown above. You can either connect on the door side or cut the ground wire going to pin 13 and solder to the stub. Either way you must cut the wire on car side going to pin 13 or it will just short circuit and blow a fuse.
The mirrors work perfect now which is great after having them non-adjustable for so long. It is an easy job, but the swap of the center console is more laborious over all.
I noticed the alarm is going off when I use a key and not a clicker. http://forums.nasioc.com/forums/showthread.php?t=389623 Says that this is normal behavior, maybe mine was broken before.
If someone knows what the deal is with the cigarette lighter let me know as well. The ring doesn't light on mine, but there are only 2 pins a hot and ground so I am unsure how it was supposed to light up anyway.
Old 04-23-2010, 11:39 PM   #67
choiboi
Member#: 126614
2006 WRB WRX TR
OS Stage 2
Read the whole thread and seems very very possible for me. But noone did it on the 06 wrx tr's. How would this be done on the 06 wrx tr's with the 05+ Sti HVAC's? Where can i get the wire diagram for these two models?
choiboi is offline   Reply With Quote
Old 10-07-2010, 04:57 PM   #68
Carlito2002WGN
Member#: 18914
2006 WRX
Black with some stuff
Answer this man's question. Please
Carlito2002WGN is offline   Reply With Quote
Old 10-13-2010, 07:31 PM   #69
STiGuy23
Member#: 215108
02 rex sti and jdm
flat black stealth mode
so hey wheres this wire diagram? i have an 02 wrx and will be swapping the auto hvac in very soon. i was originally planning to swap the entire harness throughout the entire car to complete the sti swap and to gain avcs, but ive found that a jdm v7 sti ecu will plug into the usdm wrx harness, so all that will need to be done is run the wiring for the avcs to the ecu..... so ofcourse i find this out after ive bought everything for the swap, so idk atleast i have every little thing sitting in my garage to pull this off.
so yea please post up some info on your wiring information and some pics.... if thats not asking too much lol. i am a mobile electronics installer by trade and know my way around 12v electrical systems very well so i feel confident that i can pull this off alone, but if youve already done it, then a reference diagram wont hurt to same some time.
thanks
STiGuy23 is offline   Reply With Quote
Old 01-02-2011, 03:09 AM   #70
zkiller
Member#: 221287
2015 WRX
ISM
Originally Posted by Loomin View Post
im almost positive they made a JDM WRX with auto climate controls in 01-02 (bugeye years in japan) but the harness would be RHD and almost unusable in a LHD car.
I had a 02 WRX in Germany before moving to the states and it had auto climate controls stock.
You can't see it above, but it also had the display for the ambient temp.
There were tons of little difference that I never new existed on USDM models. The EDM WRX had much nice seats also.
zkiller is offline   Reply With Quote
Old 01-09-2011, 10:22 AM   #71
langsbr
Member#: 209630
2002 WRX / V7 STI
3.9USM6 / PSM
Am I missing something? The picture shows the standard manual hvac controls...
Auto hvac doesn't have a twist handle, its a rolling knob.
langsbr is offline   Reply With Quote
Old 01-09-2011, 02:45 PM   #72
MotorolaBizz
Member#: 119290
2004 WRX 4EAT
Java Black Pearl
Yeah you did miss something. The temperature on the knob (its in Celsius) on the right side in picture 1. I can't make out what the middle knob is but the left knob directs where the air is to go.
MotorolaBizz is offline   Reply With Quote
Old 01-09-2011, 05:41 PM   #73
zkiller
Member#: 221287
2015 WRX
ISM
Yup, you are missing something. Have a closer look and guess again. Those are Auto HVAC controls.
The center knob has the options: Off, Auto and 4 speed settings.
Old 03-29-2011, 01:08 PM   #74
STiGuy23
Member#: 215108
02 rex sti and jdm
HEY GUYS!!!!! JUST SOME FYI - I AM DOING THIS SWAP TONIGHT AND I WILL BE PROVIDING A FULL WRITE UP ON HOW TO SWAP THE 05+ STI AUTO HVAC AND CENTER CONSOLE INTO A WRX WITHOUT ALL THE AUTO COOLNESSS SINCE THERE IS BASICALLY ZERO SUPPORT FOR THIS WITHIN THE NASIOC COMMUNITY.
SO ANYONE WHO IS INTERESTED IN THIS SWAP, STAY TUNED TO THIS THREAD AND I WILL PROVIDE A LINK TO A NEW THREAD WITH THE WRITE UP ONCE IM DONE.
I will say this, this swap is very electrical knowledge based and is not for most people. ALMOST NOTHING IS PLUG AND PLAY. The ENTIRE heater box from an auto hvac car must be installed being that its completly electronic with sensors and actuators and the fan control amp, you will need all the connectors which i will list, the two sensors (sunload and ext. temp) which also have two wires that run to the sti cluster to make the ext. temp display work, and the silver center pieces obviously lol, and bunch of wire and solder.
So now the fun begins! Stay tuned for the swap details
Old 03-29-2011, 01:22 PM   #75
BoostinChick
Member#: 218971
2007 WRX
Yea, I wonder if it would be a bit easier since the years are closer. So far, one of the differences I have seen between the TR and STi for wiring is the leveler harness for the headlights. Everything else seems pretty much the same. I also think the Limited and WRX's came with auto-climate for 06-07 as well.
BoostinChick is offline   Reply With Quote
v6 cluster & HVAC in 02 WRX WReXd Subaru Conversions 5 09-15-2009 10:36 AM
02 HVAC swapped with 05+ auto HVAC Loomin Interior & Exterior Modification 14 01-04-2009 03:22 AM
05 wrx windshield in 02 wrx??will it fit? gotawd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-01-2008 04:27 PM
04 STI HVAC in 02 WRX? alwrxwu Interior & Exterior Modification 5 04-01-2008 03:56 PM
04 sti cluster in 02 wrx will it work? red_rex_02 Interior & Exterior Modification 6 03-27-2006 02:38 PM
