Old 11-23-2008, 09:44 AM   #1
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Default Enkei Bortex wheels??
I just found a set of Enkie Bortex wheels for sale... They are 17x7, 5x100. The guy doesnt know the offset. Does anyone know if these will clear '07 wrx calipers?? I realize offset would help determine this, but lets assume +48...Also what do you thin an acceptable range of offsets would be?
Zottyzot is offline   Reply With Quote
Old 11-23-2008, 10:27 AM   #2
MattPersman
Member#: 139385
acceptable range, 42-53 just throwing that range out there. should clear 4 pots as some 16s do.
MattPersman is offline   Reply With Quote
Old 11-23-2008, 10:57 AM   #3
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Cool, thanks.
Old 11-23-2008, 01:09 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
this is not true
ASSuming that some wheel or another will fit based on offset is a false assumption
Old 11-23-2008, 06:38 PM   #5
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Originally Posted by Uncle Scotty View Post
this is not trueASSuming that some wheel or another will fit based on offset is a false assumption
I ASSumed he meant, beacause some 16" wheels fit and the wheels in question are 17", there would be no problems. Anyhow, I picked up the wheels/tires, havent put them on yet. The offset is +48 wheel size 17x7. A perfect set of firehawk gts are mounted, but size 215/55 not sure how they are gonna work...
Old 11-23-2008, 06:58 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
ASSuming that wheels will fit based on size is just plain stupid.
Because it is a false ASSumption.
There are PLENTY of 17's that dont fit
and those tires are too tall
Old 11-23-2008, 07:18 PM   #7
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
You are absolutely right, its stupid.
Old 11-23-2008, 09:39 PM   #8
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
first thing I would have done before handing over the cash is to jack up the car, remove a front wheel, put on one of the potential new ones, and see if it hits the caliper - takes less than 5 minutes (much less if you are feeling inspired) and then you know if they'll work before you buy them...
Old 11-24-2008, 06:50 PM   #9
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Flame away, please. I'm a moron. The wheels do NOT clear the 4 pots....I.ve got a sweet set of enkei's available if anyone is interested.
Old 11-24-2008, 07:44 PM   #10
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
how badly do they not fit? if it's only a little bit, there's always spacers...
Old 11-24-2008, 08:31 PM   #11
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Honestly, passenger side worked w/ about 0.00" clearance. the driver side after torquing down rubbed slightly, but still spun...Whats the smallest spacer i can buy?
Old 11-24-2008, 09:43 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
3 mm...
or grind the calipers
Old 11-24-2008, 09:47 PM   #13
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
I'm gonna see if ayone wants the wheels in the next few days. After that get some thin spacers...No grinding for these calipers, thanks.* I should have listened to Uncle Scotty form the start...
Old 11-24-2008, 10:40 PM   #14
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Also, with just a 3mm spacer should I do front and rear?
Old 11-24-2008, 10:59 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
just the front
Old 11-24-2008, 11:01 PM   #16
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Thanks for your help.*
F/S (NJ): 1 New Enkei RPM2 Bortex wheel *Mint* shizznats Wheels/Tires 21 01-19-2011 05:06 PM
Enkei Bortex RPM-2's lawn boy Brakes, Steering & Suspension 2 09-06-2002 12:40 AM
Updated pics of Enkei Bortex wheels on Red WRX STI RDY Member's Car Gallery 5 05-22-2002 04:04 PM
Red WRX with Enkei Bortex wheels STI RDY Member's Car Gallery 22 05-13-2002 01:26 PM
Just ordered my new rims, Enkei Bortex RPM2 atf78 Brakes, Steering & Suspension 129 04-14-2002 11:57 AM
