Old 11-23-2008, 11:08 AM   #1
docsmitty
Member#: 189991
2009 Spec.B
QSM
Default VDC and Hill start assist warning lights on
I just swapped out the cruise switch on my 08 WRX for a cruise + steering wheel audio version from the premium. The cruise and audio controls work perfectly, but now two lights on my dashboard have turned on.. one the "Vehicle Dynamics Control warning light" (not the one that lights up when you turn off traction control manually) and the other is the "Hill start assist warning light." This mod required removing the airbag and steering wheel to swap out the control pods. In another thread someone said you can break the VDC sensor by doing this, but I don't believe that.. I was extremely careful, and there's no way something broke. Would the vdc system need a reset perhaps?
Any help would be greatly appreciated.
docsmitty is offline   Reply With Quote
Old 11-23-2008, 03:08 PM   #2
Cocoa Beach Bum
Member#: 17355
Use secret handshake to find out what ABS/VDC trouble code is.
Cocoa Beach Bum is offline   Reply With Quote
Old 11-23-2008, 05:53 PM   #3
docsmitty
Member#: 189991
2009 Spec.B
QSM
Getting two codes for abs / vdc:
C 0071
C 0042
What are these?
Old 11-23-2008, 07:03 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
C0071 is steering angle sensor
C0042 is Power Supply Voltage Failure for the VDC module.
Did you disconnect the batter while you swapped out the steering wheel?
You can try reseting the codes by disconnecting the battery, if the code 71 comes back you are going to have to take it to the dealer they can try re-calibrating the sensor.
Old 11-23-2008, 10:11 PM   #5
docsmitty
Member#: 189991
2009 Spec.B
QSM
Hrm I really don't want to go to the dealer. The car is nearly brand new, two weeks at most.. would they know that this is something I've caused or would I be looking at warranty work?
Old 03-22-2009, 09:09 PM   #6
abefroman
Member#: 81431
2015 CWP STI Ordered
docsmitty, did you ever get this resolved?
We added steering wheel controls and get the same codes
abefroman is offline   Reply With Quote
Old 03-22-2009, 09:23 PM   #7
docsmitty
Member#: 189991
2009 Spec.B
QSM
I went to the dealer. I told them a couple lights had come on my dashboard. They replaced the steering wheel angle sensor under warranty... good luck!
Old 04-11-2009, 06:39 PM   #8
warp speed
Member#: 168841
Default Codes
I have a similar problem with my 08 WRX, from removing the steering wheel.
C 0071
C 0047
C 0042
Can anyone tell me what C 0047 is?
Thanks
warp speed is offline   Reply With Quote
Old 06-12-2009, 11:11 AM   #9
WRBear
Member#: 207171
2016 Golf R
Thanks for this, this just happened to me last night after replacing the wheel controls. I was very careful also, but I also read that you're not supposed to detach the clips from the airbag--should keep that attached and have someone else holding it while you work around it--what a PITA!
Hopefully they'll replace for me under warranty also...did you say you replaced those controls? I'm sure saying that would make them hesitant to replace under warranty right?
WRBear is offline   Reply With Quote
Old 06-30-2009, 02:31 PM   #10
jpatryna
Member#: 213818
2009 Impreza WRX
How did everything go?
jpatryna is offline   Reply With Quote
Old 06-30-2009, 04:11 PM   #11
WRBear
Member#: 207171
2016 Golf R
I brought it in, they checked it out, said it was indeed my steering wheel angle sensor that was 'damaged', or not functional. Made an appt for the next day to drop it off at lunch, picked it up at the end of the day. All done under warranty, no questions asked, and I did not disclose my DIY installation however
Old 07-01-2009, 11:37 AM   #12
jpatryna
Member#: 213818
2009 Impreza WRX
Awsome! I am going through the same deal. I hope it goes as smoothly.
Old 07-01-2009, 12:36 PM   #13
jpatryna
Member#: 213818
2009 Impreza WRX
Does anyone know what wires to tap into for a boost gauge? I want to go through the clock on my 09' WRX. It's a mechanical with three wires. what color wires are the power, ground and illumination on the clock side?
Old 08-31-2009, 11:04 AM   #14
jndimaria
Member#: 203076
05 STi CGM
today when driving in traffic to work my ABS, VDC and hill assist light came on and stayed on until i got to work. i tried the code and S-On came on the ODO screen and then turned my instrument panel off and security started flashing. when i turn my car back on the warning lights aren't on anymore, but i haven't tried driving it again yet. should i take this into the dealer? i also haven't done any recent mods that require any wiring or anything to do with the steering wheel/column.
this is on an 08 WRX.
jndimaria is offline   Reply With Quote
Old 08-31-2009, 11:51 AM   #15
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Is it not possible to do the audio control swap withOUT messing up this steering angle sensor? This is something I had in mind to do on my 09 non-premium.
What are the logistics of the job anyway. Are the audio controls prewired in the steering wheel so you just need the controls to plug into it? Or does it require wiring?
09rexwagon is offline   Reply With Quote
Old 08-31-2009, 12:21 PM   #16
WRBear
Member#: 207171
2016 Golf R
No wiring involved, you'll receive a new harness that has both cruise control and steering wheel controls--plugs into the same spot where cruise control plugs into now.
You may be able to--my suggestion is to have another person hold the airbag, while its still connected. I've heard disconnecting the airbag is what may trip this sensor? But this is just a theory....Let us know
Old 08-31-2009, 12:39 PM   #17
09rexwagon
Member#: 216135
2011 Civic SI
So this steering angle sensor breaking is related to the air bag....hmmm good to know. I'll just keep the airbag on there then and had the SWMBO hold it .
Old 08-31-2009, 01:21 PM   #18
WRBear
Member#: 207171
2016 Golf R
Just make sure to disconnect your battery, and wait a while. Wouldn't want an airbag in the face!
Old 01-26-2011, 01:29 AM   #19
BraveSTi
Member#: 262030
Bump....'cause I'm havin the-same-****in-issue, VDC off, ABS off and Hill Assist off, all illuminated and cannot re-engage, just installed WL steering-rack bushies.
So is it safe to say that its the steering-angle sensor and/or a Power Supply Voltage Failure for the VDC module?
BraveSTi is offline   Reply With Quote
Old 10-31-2011, 03:20 PM   #20
gregroot198521
Member#: 280844
2006 STi
Default ???????
Bump, since I am having this same problem in my 2011 WRX. I replaced the steering wheel with the GTSpec D-shaped wheel, and forgot to mark the "straight" angle when I removed the stock wheel. In the process of realigning the new wheel, I made contact across the horn with my ratchet causing the horn to honk. After finishing the tightening of the wheel and reconnecting the battery, the "VDC off" & "Hill Assist off" lights came on, and have not turned off since. At the same time the "one-click up/down" feature for my window wasn't working right either, it would only go the normal up if held all the way clicked either way. That problem went away, but the VDC & Hill Assist problems are still there, and I can feel that both do seem to be off. Any suggestions?
-Greg
C/N After steering wheel install, VDC & Hill Assist are off.
gregroot198521 is offline   Reply With Quote
09 WRX-VDC, ABS, and Hill Assist Warning Lights Subirex09 Warranty Issues & SOA Problems 47 09-07-2015 04:12 PM
VDC OFF and Incline Start Assist OFF warning lights???? bradman77 Service & Maintenance 2 04-18-2010 11:25 AM
VDC OFF and Incline Start OFF Warning Lights on??? bradman77 Electrical & Lighting 0 04-14-2010 09:35 PM
08 wrx:ABS,VDC,Hill Start Warning lights ON theotherguy Newbies & FAQs 7 03-15-2009 12:35 PM
So about the 08 Impreza hill start assist... moestock Newbies & FAQs 22 10-12-2007 10:46 AM
