Old 11-23-2008, 01:03 PM   #1
MyScoobie28
Member#: 59185
2014 Impreza WRX
Default my car is killing me :(
hey guys, this is a nonstop issue with my car. hopefully you guys can help me figure it out.
lately, it's been harder and harder for my car to start. more recently, it won't start at all. tuesday, i was hoping that my car would start because i had an appointment at DS1. well, it didn't. i was in a hurry, and my only other option was putting in a new battery that i bought (optima red top). i really didn't want to put in the new battery because i had a feeling that the battery wasn't the cause of the car not wanting to start, but i had no other options.
i put in the battery, and the car fired up. started up and i drove to DS1. that was on tuesday. wednesday i drove to the train station, left my car for a few hours, went to school, and came back. started up fine. thursday drove to school, let it sit for a few hours, and drove home. friday i didn't drive it.
saturday, i drove to work, and let it sit from 9am to 3pm. came out at 3, and it didn't start. my friend came, hooked up his battery starter/charger thing (looks just like this: http://www.sears.com/shc/s/p_10153_12605_02871988000P)
that gave power to my battery, meaning, all the lights/electric devices worked, everything lit up on the dashboard and cluster as it should, BUT as soon as i tried to start the car, it died, and the battery died (all the lights inside and out turned out), just like a dead battery.
we did this a few more times - hook up the device to the battery, all the lights turn on, as soon as i try to crank it - everything dies just like a dead battery.
so, we pushed the car a little bit and tried to start it that way. after a few times of pushing the car to give it a little speed, it finally started.
i've come to the conclusion that it's not a battery problem because i put my brand new optima in. now i'm thinking it's either the starter (maybe the alternator too??), and it has to be an electrical issue.
cliffnotes: i know it's long, i'm sorry, but i tried to go into as much detail as possible. please try to help me out, my car is dead, and i cannot drive anywhere. i'm screwed without your guys help.
thanks for all of the help, you guys really are a great community. --Arthur
edit: i know this might be the wrong section to post it, but i did it intentionally because i know that i will get the most feedback here.
MyScoobie28 is offline   Reply With Quote
Old 11-23-2008, 01:05 PM   #2
Spootypuff
NASIOC SUPER Supporter
n00b jesus
Member#: 200000
2012 Wrangler
sounds like a faulty alternator
Spootypuff is offline   Reply With Quote
Old 11-23-2008, 01:06 PM   #3
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
What kind of noise did it make when trying to start? Did it crank, and just not turn over, or did it click or nothing?
Is your check engine light on at all?
RexyGirl is offline   Reply With Quote
Old 11-23-2008, 01:07 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
not charging
Old 11-23-2008, 01:09 PM   #5
rage557
Member#: 117441
2001 Impreza 2.5rs
I would guess the alternator. Take your car to one of the autoparts places and get it tested.
rage557 is offline   Reply With Quote
Old 11-23-2008, 01:10 PM   #6
ketchupdtf
Member#: 175060
GR STi
FYF Squad!
Start the car let run for a minute then take positive cable off battery while car is running, if car stalls after, your alternator is dead!!! Had it happen to my honda!
ketchupdtf is offline   Reply With Quote
Old 11-23-2008, 01:10 PM   #7
MyScoobie28
Member#: 59185
2014 Impreza WRX
no sound when attempting to crank, nothing, it just dies
Old 11-23-2008, 01:12 PM   #8
Divet
Member#: 188242
I also agree with it being the alternator that's bad. If you have any doubt, Autozone will test your alternator and starter for free.
Divet is offline   Reply With Quote
Old 11-23-2008, 01:18 PM   #9
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
That sucks Arthur, unfortunately I have no advice.
eurospek is offline   Reply With Quote
Old 11-23-2008, 01:20 PM   #10
Divet
Member#: 188242
This I would not recommend doing, as it can blow a diode in your alternator if it isn't the culprit, or cause other problems. If you want to check yourself and have a voltmeter, start the car and connect the voltmeter with the red clip touching the positive battery post and the black clip touching the negative battery post, if you see less than 12-13 volts, I would say the alternator is not working. If you can't get the car started to try this, just get it checked out at a place like Autozone.
Old 11-23-2008, 01:22 PM   #11
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
Alternator.
Hey at least it is easy to change! My wife's on her old 99 cougar was down low in the passenger side fender well...had to pull off the axle/suspension on that side just to get to it!!
geddesk2 is offline   Reply With Quote
Old 11-23-2008, 01:43 PM   #12
MyScoobie28
Member#: 59185
2014 Impreza WRX
thanks a lot guys for the help. so far i'm going to start out with testing the alternator (replacing if needed), testing the starter (replacing if needed), and getting new battery cables/clamps.
how difficult can it be to replace battery cables/clamps?
keep the suggestions coming. --arthur
Old 11-23-2008, 01:43 PM   #13
MyScoobie28
Member#: 59185
2014 Impreza WRX
edit: double post
Old 11-23-2008, 02:52 PM   #14
MacintoshMan
Member#: 160863
2009 Speed3****box
its an 01 change the ALTERNATOR. It't not difficult either, and if you really want things to be more like a new car. Try a new fuel pump, nicer fuel injectors and fluids!
MacintoshMan is offline   Reply With Quote
Old 11-23-2008, 03:24 PM   #15
boostbaron
Member#: 172549
2011 WRX
Satin White PoOp
Hey if you want, stop by Maverick and i will test everything out for you... if you end up needing anything i can order it for you...
boostbaron is offline   Reply With Quote
Old 11-23-2008, 03:31 PM   #16
Back Road Runner
Member#: 60082
2004 Forester STI
Many places like Advance, Autozone, etc. will check your electrical system for free.
Old 11-23-2008, 07:45 PM   #17
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
nooo!!! dont take your positive cable off!!! that is ok to do on other cars but on newer ones you risk letting the gene out of your ecu...it sounds like a alternator..or a wire that is shorted somewhere draining your battery....go back to sears where you got it tsted from the first place tell them to check the alternator with the big maching not the small one ....and if not hook up a dmm in-line with your battery and cable(take positive cable off and hook it up in series) then turn it to amps scale and if you have a current draw of more than .2-.5 amps you have a parasitic draw my friend ...i would say check wiring aroung the turbo region,interfooler,and places like that sill stuff happens all the time like this...o and also clean your terminals to if they are corroded that would cause it to
shift0246 is offline   Reply With Quote
Old 11-23-2008, 10:00 PM   #18
MyScoobie28
Member#: 59185
2014 Impreza WRX
no turbo, no intercooler...it's a 2.5RS
Old 11-24-2008, 02:14 AM   #19
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
thats not good for the obd2 cars. Might cause a short somewhere in the system.
HighRevimpreza is offline   Reply With Quote
Old 11-24-2008, 11:52 AM   #20
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
edit:
already suggested :3
Sir-Knight is offline   Reply With Quote
my throat is killing me this morning... heron163 Off-Topic 17 12-12-2005 07:47 PM
My seat is killing me... Phoebe Interior & Exterior Modification 14 02-26-2005 10:31 AM
my eye is killing me philip_g Off-Topic 4 01-28-2004 01:46 AM
Ugh, my stomach is killing me... little help? rogue Off-Topic 9 12-24-2003 09:42 AM
my nose is killing me!!!!!!!!!! randolph-rs South East Region Forum 12 10-31-2003 12:32 PM
