Old 11-23-2008, 02:26 PM   #1
Cobb Tuning
Member#: 4803
Default E85 with the 16G + 2007 WRX
I thought it might be interesting to post up a 2007 WRX 16G tune from last week using E85. The 16g is a great upgrade for the 2.5L WRX guys, and on 92 octane pump fuel we usually see 290-310whp in a street setup. Spoolup is usually comparable to the VF39/43s, and the addition of larger injectors (850cc Deastchworks) and a fuel pump bring the car on par if not a bit above the usual stage 2 STI. This particular WRX had a Perrin TMIC, Injectors, Fuel Pump, and the DW injectors.
Since E85 is available at the pump in a few locations around here, I thought it would be good to do a small comparison.
Here are the dyno results from the pump fuel tune and the E85 tune:
As you would expect when you run the higher octane fuels, more boost equates to more torque and power. Crossing to 350 lb-ft of torque at 3250rpm makes for a snappy ride. Peak HP rose from 304whp to 336whp with a bump of about 2psi of boost. On our dyno 336whp is pretty amazing for a 16G.
Let's take a look at the boost difference:
Midrange boost in the E85 tune was ~2psi higher, but if you look at the range above 6000, the boost levels off as the turbo gets near the edge of the compressor map. Consider that at 6500 rpm the boost is nearly identical, but the hp is nearly 25whp more on E85. That is your mixture of higher octane and oxygenated fuel. Boost for E85 peaks at 20psi, then rolls down to 17.5psi at redline. Pump fuel boost is about 18.5 psi down to 17.5 at redline.
Timing has the reverse profile from the boost for the most part:
You can see the E85 tune has lower timing during most of the run primarily due to the higher boost pressure. While the burn rate of E85 has a greater variance with AFR, the timing numbers are typically similar to the pump fuel, with a slight bit of advance at higher loads. Looking at the above plot you can see the advance numbers come into line at higher RPMs as the boost levels merge. Adding more timing didn't net significant gains in torque, so keeping them near their pump fuel equivalents is prudent.
Jumping to E85 does require more fuel volume, as you can see in the graph below:
Notice that the pump fuel tune ramped the injector duty cycle to a peak of 74%, while the E85 tune peaked at 91%. Across the whole tune duty cycles were about 22% higher, which is the typical amount of scaling I would use when going from pump fuel the E85. The AFRs on this chart are Gasoline equivalent AFRs, the E85 numbers represent what you would see on and AFR meter calibrated for gasoline.
Taking a closer look at the E85 AFR, here is the AFR corrected:
The correct AFRs show the ratio running very close to 8:1. Max power lean for E85 is typically ~8.4:1 and max power rich is ~6.9:1. This falls about in the middle, with a bit of bias towards max power lean. On the 2.5L platform running richer, especially getting near 7:1 results in power drop, and leaner then about 8.2:1 does not net any gains. This tune at 7.9:1 - 8.0:1 is about .81 lambda, and targeting .80-.82 seems to work well on this platform.
While E85 is not available everywhere, even at $2.85/gallon (the price I paid yesterday) it is a bargin compared to running a normal 100+ octane race fuel. We have had good success building OTS maps for E85 for most configurations, so it is something to consider for those looking for more power. (I tuned my H6 last night with E85, and I'll get those results up in a bit. It worked well. )
Cheers,
Jeff Sponaugle
Research Calibrator
Surgeline Tuning
Old 11-23-2008, 02:51 PM   #2
Tuned200
Member#: 127740
2015 WRX-Mine
2007 F-STI-Her's
Very nice. E85 here is 1.31 a gallon
Tuned200 is offline   Reply With Quote
Old 11-23-2008, 03:04 PM   #3
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
hell yeah E85 revolution . My car is turn apart right now getting ready for some goodies so I can run E85, I hope I can put it back together .
Old 11-23-2008, 03:11 PM   #4
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
Nice info Jeff. Very simple and easy to read and understand. Now can someone tell those farmers to get E85 more readily available here in PA?!
NickWRX is offline   Reply With Quote
Old 11-23-2008, 03:11 PM   #5
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
So, how much boost are you running?
Can you read a graph? Youre going to be out of injector, just FYI. I dont know why Im bothering to repeat this, but I am, and yet, you still dont listen.
Still planning on a new motor by Christmas?
cucamelsmd15 is offline   Reply With Quote
Old 11-23-2008, 03:51 PM   #6
Cobb Tuning
Member#: 4803
Nice. It was a bit lower here, but has recently been at about $2.70 - $2.90. Of course pump fuel is now down to about $2.19. Then again, 104 unleaded is still about $6.50/gallon, so E85 is a steal.
While I don't know what injectors you are running, if you plan on doing E85 start off with the DW 850s. And a big fuel pump.
Jeff
Old 11-23-2008, 03:55 PM   #7
cucamelsmd15
Member#: 122980
Jeff
I had 816's and Ive done e85 already. Whats your elevation there, just out of curiosity?
Ive said this before, but Ill say it again. 850's are bare minimum, and if youre going to be running something larger than an 18g and youre not at altitude, well, youre going to need alot more.
Old 11-23-2008, 04:31 PM   #8
cucamelsmd15
Member#: 122980
Sent you a PM Jeff.
Old 11-23-2008, 04:32 PM   #9
Cobb Tuning
Member#: 4803
Sea level here, perhaps 1000 feet at my house. Agreed that 850s are the minimum if you want to go with something larger then a 16g Also a single Walbro pump would not be sufficient if you want to go to big power.
Jeff
Old 11-23-2008, 06:17 PM   #10
juanmedina
Member#: 133146
idiot, I am installing 860ccs with 255 walbro they should be enough
Old 11-23-2008, 06:27 PM   #11
cucamelsmd15
Member#: 122980
*sigh*
Listen dude, I dont know how many times I have to tell you for this to sink in. Those injectors and FP wont be enough. Period. End of story. Curtains. I have logs that prove it, without a doubt. Those nice pretty graphs posted in this very thread serve to back my assertions. Notice that nice shiny 16g thats only running ~19psi of boost? Yeah, thats because its *gasp* out of injector. That 16g is easily capable of 24psi in the midrange, especially on a Perrin TMIC. This tune is on the leaner side according to the graph, and it doesnt even go above 20psi. Oh yeah, his altitude is higher than ours, since we are only at around 350-400 feet above sea level, but its not like that matters. Do you want me to quote the 500 other times that Ive told you this already? Who is tuning your car?
Oh yeah, one would think after hearing the same thing over and over and over again that it would sink through their thick skull, but apparently thats not the case with you. You dont listen to people who are more advanced and experienced than you. Who is the idiot again?
Old 11-23-2008, 09:23 PM   #12
C J
Member#: 132587
2006 JrTuned STi
[email protected]
so just curious but did you do anything to prep the car to run on e85 or did you just throw it in the tank and tune?
C J is offline   Reply With Quote
Old 11-23-2008, 09:53 PM   #13
Cobb Tuning
Member#: 4803
We drained the tank of remaining pump fuel before filling with E85. Its easy to drain the fuel from these cars.....
Turn off the motor. Take off the return line. Connect the return line to a longer line that terminates in an empty can. Start the car and allow the pump to drain the tank.
Prepare a fresh cup of coffee and make initial changes to the pump fuel map to prepare for the first E85 runs.
Reconnect the lines, refill with E85, and make some power.
Best regards
Tim Bailey
Old 11-23-2008, 10:24 PM   #14
STiBottom
Member#: 127041
02 WRX
Midnight Blue Pearl
Wow... What is stoic for E85
STiBottom is offline   Reply With Quote
Old 11-23-2008, 10:28 PM   #15
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
I love that turbo
I'm slightly surprised though, that the spool isn't a bit quicker. I'm not hating by any means, but I see full boost a little sooner with the EvoIII on a 2.0 with a UEL header and crappy eBay TMIC.
Is that pretty common for the 2.5/16g? You don't see a lot of them around.
I want that torqueband
Audiosavvy is offline   Reply With Quote
Old 11-23-2008, 10:29 PM   #16
Cobb Tuning
Member#: 4803
Default Comparing different injectors
Take a look at the graph below. This car was equipped with 850 cc injectors I still had some headroom. 750 cc injectors would have indeed maxed out on this car. The other comparison is to stock injectors.... Pretty clear how stock injectors simply won't work on E85 applications.
Sorry for the poor quality. My graphing program is being a little cranky.
Best regards
Tim Bailey
Old 11-23-2008, 10:31 PM   #17
Cobb Tuning
Member#: 4803
Originally Posted by Audiosavvy View Post
I love that turbo
I'm not sure if jeff mentioned this but the turbo is an EVO3 16g.... slightly larger than a regular 16g.
I was worried about breaking this customer's transmission. The spool up is a bit sluggish because i was trying to avoid a 3rd gear crushing torque spike.
Tim
Old 11-23-2008, 10:37 PM   #18
Cobb Tuning
Member#: 4803
Default Pump vs meth injection vs e85
I was doing some a web search on e85 and my own subiesport article popped up on driving sports website. I had NO idea it was even posted on the web!!
Here is the link. Its a good read.
http://www.drivingsports.com/site/20...nol-injection/
The article compares E85, pump fuel, and meth injection tuning strategies and results on a STOCK TURBO 06 STi.
If i get permission from the magazine i'll post the results here with full resolution graphs.
Tim
Old 11-23-2008, 10:37 PM   #19
Cobb Tuning
Member#: 4803
Take a look here:
Old 11-23-2008, 10:40 PM   #20
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
1.0 lambda for E85 is approximatly 9.765:1.
Jeff
sponaugle is offline   Reply With Quote
Old 11-23-2008, 10:48 PM   #21
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Tim
I didn't see that, but assumed it. The comparison was ALSO to the EvoIII that's on my car, smaller motor/less efficient TMIC/UEL header. But I won't threadjack, I was just curious if that was the normal, I don't recall ever seeing a 2.5/16g setup on paper.
Old 11-23-2008, 11:45 PM   #22
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
E85 FTW 1.27 gallon here...
TDagen is offline   Reply With Quote
Old 11-24-2008, 12:20 AM   #23
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
You got raped on E85. You can purchase it locally for 1.75 per gallon.
pegdrgr is offline   Reply With Quote
Old 11-24-2008, 12:40 AM   #24
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Matt K mentioned the place downtown, and the one in Cornelius is much cheaper then the Shell station on I5, but the one on I5 is open late, and is pretty close by.
Jeff
Old 11-24-2008, 01:10 AM   #25
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
The closest one to the shop is the one I was talking about, but good job missing it
Red Perrin Turbo Inlet for the 2002-2007 WRX, 2002-2008 STI & 2004-2008 Forester XT dexterous Engine/Power/Exhaust 2 03-07-2010 01:30 PM
Name of the stock 2007 wrx turbo? ASpel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-05-2009 12:14 PM
Anyone with a 2006-2007 WRX T3/T4 WRX Mid West Subaru Owners Club Forum -- MWSOC 2 03-07-2007 12:58 AM
To the hot chick with the 06 black WRX wagon at the Deale Shell station Undepelo Mid Atlantic Impreza Club -- MAIC 11 04-01-2006 07:52 AM
Hi to the new guy with the WR Blue WRX in Lawrenceville Fido Tri-State Area Forum 2 05-15-2001 06:04 PM
