Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 11-23-2008, 06:40 PM   #1
jester696
Member#: 135952
04 XTi
Default It's 14 degrees out and my car is blowing cold air!!!
I start my car up in the morning so that my windshield defrosts. The only problem is my car only produces cold air until I drive it. When I drive, it will blow hot air. I really appreciate the help if anyone can give me some info.
~J
jester696 is offline   Reply With Quote
Old 11-23-2008, 06:47 PM   #2
prometheum
Member#: 92003
04 bicycle!
you understand the heater works by using engine coolant don't you?
prometheum is offline   Reply With Quote
Old 11-23-2008, 06:51 PM   #3
jester696
Member#: 135952
04 XTi
If I stop driving my car,(say at a stop light) it turns to cold air again
Old 11-23-2008, 07:30 PM   #4
dudley123
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
because the water pump is not spinning nearly as fast as when you are driving.. IF you rev the car at a stop, the hot air will return.
dudley123 is offline   Reply With Quote
Old 11-23-2008, 07:38 PM   #5
jarencibia
Member#: 187021
2004 WRX Sedan
So what is the cause? Maybe the thermostat is stuck open. How is the coolant level? Check it out
jarencibia is online now   Reply With Quote
Old 11-23-2008, 08:15 PM   #6
hotrod
Member#: 14141
2002 Impreza WRX
Check your coolant level, and antifreeze mixture first. Cold air can be a sign of low coolant, or slush formation in the cooling system or freezing in the radiator. At low water pump speeds no hot water can get to the heater core.
Second most likely is a theromstat stuck open. Put a piece of cardboard infront of the radiator, and if the engine warms up normally then, you probably have either a bad water pump or a bad thermostat. If the engine has been partially frozen the ice can lock the water pump rotor and when the engine starts, it twists the impeller on the water pump shaft. This kills the water pump. Likewise freezing can damage the thermostat (also over heating can kill them).
If you are having 14 deg temps you need antifreeze protection that is at least -10 deg F to be safe, prefer -30 or better protection (50/50 mix of water and antifreeze).
Larry
hotrod is offline   Reply With Quote
Old 11-23-2008, 09:48 PM   #7
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 410/395 JJtuned
I agree, coolant level or t-stat.
Dave D. is offline   Reply With Quote
Old 11-23-2008, 10:06 PM   #8
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
I just read this thread an hour ago, drove to the store and now my car is doing the exact same thing.....wtf
a6n6d6y is offline   Reply With Quote
Old 11-23-2008, 10:15 PM   #9
k mier
Member#: 98000
05 sti e85@420hp
Doesn't the ac come on with the defroster? On mine the ac can be turned off with the defroster still on, doesn't clear the windshield nearly as good on rainy days, but does seem to clear the frost away quicker. Don't think that's your problem though but it might help defrost quicker.
FYI, the old Ranger pickup didn't have enough antifreeze in the coolant and it did basically the same thing. Heater would slightly warm up sitting in the drive but as soon as moving it would turn cold as the coolant slushed up.
k mier is offline   Reply With Quote
Old 11-23-2008, 10:29 PM   #10
04 Slo Sti
Member#: 156478
06 330i
so weird that this thread comes up b/c my girlfriend was complaining about it being cold in the passenger seat...i'm never cold in my car when i'm driving...dono why
but anyways i felt it and i'll be damn my car is doing the same thing...i think i'm a tad bit low on antifreeze...but its only gotten down to about 25 and my car still stays realllllllll cold...about 160 when crusing...
04 Slo Sti is offline   Reply With Quote
Old 11-23-2008, 10:33 PM   #11
Haych
Member#: 169719
2005 Impreza WRX
Grey
Definitely sounds like a thermostat stuck open, or your heater core is clogged.
Haych is offline   Reply With Quote
Old 11-23-2008, 11:43 PM   #12
MasterKwan
Member#: 98961
2003 WRX
Or a blown head gasket...
Old 11-24-2008, 02:07 AM   #13
dudley123
Member#: 120831
PIA Purpose Built -
??^^^ Wouldnt you have some white smoke issues also then?
Old 11-24-2008, 02:52 AM   #14
silentt
Member#: 119995
2004 Outback XT
Peachy
Does your car overheat at idle when it blows cold air?
silentt is offline   Reply With Quote
Old 11-24-2008, 03:08 AM   #15
MasterKwan
Member#: 98961
2003 WRX
If a blown HG is just leaking a little combustion gases into the coolant, you get air pockets and no heat. That's worst case, I just wanted to throw it out there, 'cause it is possible. I've never actually seen a 'stat go bad.
OP has an 07. That's mighty new to have any real issues.
Old 11-24-2008, 04:00 AM   #16
04 Slo Sti
Member#: 156478
06 330i
i checked my coolant level and its a lil low...i'm assuming thats the OP problem
check coolant level
Old 11-24-2008, 05:54 PM   #17
jester696
Member#: 135952
04 XTi
yea...coolant was way low
Thanks for the help
Old 11-24-2008, 06:53 PM   #18
MasterKwan
Member#: 98961
2003 WRX
It would only be low if it leaked out. It's a closed system. You have a coolant leak somewhere.
Old 11-24-2008, 07:13 PM   #19
04 Slo Sti
Member#: 156478
06 330i
eh filled my coolant today....wasn't really empty at all...
so i'm gonna keep this thread up and hope for the best....car runs great otherwise...
Old 11-24-2008, 07:23 PM   #20
Subaruski
Member#: 39905
head gasket bye bye
Subaruski is offline   Reply With Quote
Old 11-24-2008, 08:00 PM   #21
jays05
Member#: 78165
05 STI 35r + e85
I agree, I read this and was thinking "That's how my car acted right before the HG blew"
jays05 is offline   Reply With Quote
Old 11-24-2008, 08:39 PM   #22
jester696
Member#: 135952
04 XTi
Just finished my 20G / tranny swap...there is no leak
Old 11-24-2008, 08:44 PM   #23
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
Could also be air in the system.*
Zottyzot is offline   Reply With Quote
Old 11-24-2008, 10:20 PM   #24
04 Slo Sti
Member#: 156478
06 330i
my damn car has 60,000 miles on it...if the headgasket is on its way out....the damn car is on its way out..
i know how it acts when the head gaskets go....buddy's RS did the stupid heat thing...my car isn't showing signs of that at all....
it only does it when its sittin at 500 rpms and its not even all the time......so its weird....car runs extermely cold 160 degree's according to my temp gauge and 180 when i'm sittin for a bit.. and uses no coolant...
any other ideas?
if it were the gaskets i think i'd be losing coolant as my buddy did with his RS?
Old 12-04-2008, 03:42 PM   #25
jiggles
Member#: 99032
what does it mean when it overheats at idle while blowing cold air and returns to normal when it starts blowing warm air?
jiggles is offline   Reply With Quote
Help me figure out why my car is bucking/bogging at certain RPMS! vipernj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-30-2006 09:29 PM
Help me figure out what my car is worth Jason02WRXCT New England Impreza Club Forum -- NESIC 6 05-27-2004 04:42 PM
Help me find out why my car is so slow MAD REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-17-2003 01:16 PM
I bought an STI part today and my car is faster 2003 sedan Texas Impreza Club Forum -- TXIC 6 01-03-2003 10:56 PM
I just installed 5zigen springs and my car is lopsided? Brood Brakes, Steering & Suspension 6 04-18-2001 11:08 PM
