Old 11-23-2008, 09:17 PM   #1
nightcrawler_20003
Member#: 168161
2004 WRX
Java Black Pearl
Default Anyone swap from wrx 5 speed to 4 speed auto?
I was thinking about swapping my 04 from the 5 speed to an automatic. what all is involved for the swap?
thanks
nightcrawler_20003 is offline   Reply With Quote
Old 11-24-2008, 12:56 PM   #2
EvenSteven
Member#: 156542
You would obviously need the tranny, probably a different rear diff as they are different gear ratios, TCU, floor shifter, shift cable, you would have to switch out the dash harness also. You might need to ad a shift-lock control box on the new harness.(it would probably come with it). But that should be about it.
EvenSteven is offline   Reply With Quote
Old 11-24-2008, 01:03 PM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
WAHBAM! evensteven nailed it
also pedals, cluster
sidewayz is offline   Reply With Quote
Old 11-24-2008, 01:39 PM   #4
jaed_43725
Member#: 194078
1997 Legacy Outback
One question. Why?
jaed_43725 is offline   Reply With Quote
Old 11-24-2008, 01:52 PM   #5
Lamont
Member#: 125190
I might still have an 06 4EAT tranny, rear diff, drive shaft and TCU back in San Diego.
Give P&L a ring, they swapped their STi to an auto.
Lamont is offline   Reply With Quote
Old 11-27-2008, 12:26 PM   #6
nightcrawler_20003
Member#: 168161
2004 WRX
Java Black Pearl
thanks guys. the reason i want to switch is because its better for drag racing than the stick (and my driving). i'll take consistancy (sp) and high-boost launch over a little more power and fun factor anyday.
Old 11-27-2008, 10:18 PM   #7
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
The wiring is going to be fun. I dont know if the 5 speed cars came with the TCU wiring that the ecu needs.
There is something like 30 wires or so the TCU and ECU share to operate the shifts, and timing controls during shifts and all that jazz. If you could look at an auto wrx, and see if the plugs for the TCU are there, that would be great.
You would also have to swap over the key interlock and shift lock modules as well. The starter interlock for autos is wired backwards compared to the 5 speed cars (to be able to turn the car on.) Not to mention the fact that the 5 speed cars probably dont have the plugs for the auto in the engine bay, so would might have to source those yourself.
You definately should talk to P&L to see how they did it, and if they have any tips for you.
~Josh~
Old 11-27-2008, 10:46 PM   #8
Lamont
Member#: 125190
You don't have to swap the key interlock. It's just a little magnetic solenoid that keeps the key from being taken out while the car is in drive. You can short this wire.
Hehehe, if you lived in IL, I'd totally let you pull all the 4EAT wiring to swap for your 5MT wiring. It would take a while though !!
OP, I didn't get a reply about if my tranny and other bits are still there. As soon as I find out, I'll let you know. I'm still looking for the TCU, I hope I didn't throw it away when I tossed the shifter (but you can always find a shifter on eBay).
Old 11-28-2008, 12:02 AM   #9
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
if your gonna do it why not go with the 5eat from the legacy?>
Mr_Snips is offline   Reply With Quote
Old 11-28-2008, 05:15 PM   #10
SA2USA
Member#: 184240
If you have a place to do the swaps ill drive down and trade you all my stuff for yours. that way its all plug and play.
SA2USA is offline   Reply With Quote
Old 11-28-2008, 08:13 PM   #11
Lamont
Member#: 125190
I'm going through the shop manuals to see where all the wires run to for the TCU. To see if I can just cut off my harness for the TCU and make a new one for the bulkhead/shifter.
Old 11-28-2008, 08:20 PM   #12
Lamont
Member#: 125190
My friend still has my 2006 auto tranny. If you pay for shipping, she's all yours. I'd send it right to a shop to make sure everything is legit with it, or just get it built right off because it's been abused (300whp).
Old 11-29-2008, 12:40 AM   #13
Lamont
Member#: 125190
I looked all over for my old TCU, can't find it. I think I tossed it when I moved. I know of another TCU, will ask if it's available. It's from an 02 WRX.
Old 11-29-2008, 12:54 AM   #14
Lamont
Member#: 125190
Cool man, I found a TCU from an 02, and my first look over of the wiring, it doesn't seem to be that hard to make a custom harness that goes to the tranny, shifter (or buttons). There are a couple of unknowns there, but if I put more time into it, I am sure I can figure it out.
Old 12-04-2008, 10:31 AM   #15
nightcrawler_20003
Member#: 168161
2004 WRX
Java Black Pearl
Appreciate the help guys but plans have changed. A good deal for a drag car came up. going to buy that one and keep my wrx for dd.
5 speed to 6 speed swap zipossible Transmission (AT/MT) & Driveline 3 10-16-2006 01:38 PM
Convert FROM 5-lug TO 4-lug? Crashsector Brakes, Steering & Suspension 32 02-26-2006 09:49 PM
swapping from 2002 5 speed to 2005 sti 6 speed what do i need 2002bugeye Transmission (AT/MT) & Driveline 6 01-30-2006 07:57 PM
Quick questions for those that have swapped from a 1.8 to a 2.5. EcksJay Subaru Conversions 16 05-06-2005 05:47 AM
5-MT to 4-EAT swap questions Depeche Transmission (AT/MT) & Driveline 20 03-20-2003 11:58 AM
