Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 02-20-2009, 05:11 PM   #151
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
The Blitz axle back exhaust for the GC chassis is on back order so I picked up a used Skunk 2 cat back. I didn't need the midpipe since I already have the TXS exhaust installed to the rear axle. I found out pretty quick that the TXS and Skunk 2 flanges didn't mate up so I cut the pipe and took it to a local guy that welded the Skunk 2 flange so it would mate to the TXS. I had to use my spare set of extended exhaust hangers so everything would mate up. Results below.
I finally power up the car (didn't start it) on the stock ECU to check the fuel pressure, lights and gauges. Well, 1 out of 3 worked. While the gauges worked, my wiring isn't quite right because the gauges only illuminate if I turn on the running lights. They switch colors when I turn on the headlights (at least that worked). The headlights and fogs work, but the fuel pressure doesn't look right. When I turn the power on I can hear the fuel pump prime and my fuel pressure will go to around 15psi then taper to 6-8psi. I put a gauge in the engine bay just to make sure the Prosport gauge was reading correctly, and sure enough it is. If anyone has any suggestions, I'm all ears.
beaviscih is offline   Reply With Quote
Old 02-21-2009, 08:26 PM   #152
beaviscih
Member#: 123362
'93 Crapcan, '98L
Replaced the ball joints and tie rods with the WL re-engineered versions, reconnected the axles, struts and brakes. I still need to torque them and install the cotter pins.
I had to come up with some not so creative hose routing for my BOV. The Apexi CAI requires a small restrictor pill that goes between the BOV and TMIC. Unfortunately there wasn't enough room for the pill so I had to add hose and route it around back to the turbo inlet. Short of pulling the TMIC and tapping it to add room, I chose this route instead. I'm not wild about the 90's, but hopefully it will work properly.
Old 02-22-2009, 03:05 PM   #153
stivan
Member#: 203702
Nice. I love gc's. I wish i could get ahold of one 22b STi
stivan is offline   Reply With Quote
Old 02-22-2009, 06:41 PM   #154
beaviscih
Member#: 123362
'93 Crapcan, '98L
Thanks, I've kinda grown found if it myself.
All four wheel hit the ground today, the first time in several months. I secured everything under the car (Innovate, double checked the exhaust bolts, etc.). I do need to torque the lower ball joints and front swaybar endlink bolts now that the full weight of the vehicle is on the wheels (at least that's what the FSM calls for).
I'm pretty sure I had the feed and return fuel lines crossed since my fuel pressure looks good. I also resolved the wiring issue with the Prosport gauges and they illuminate like they are supposed to (white w/o lights on and green with the lights turned on), now I just need to figure out how to silence that annoying tone on startup. I calibrated the Innovate wideband and secured most of the wiring, but still have a few odds and ends remaining. The Link G4 should be in next week. I'm going to drop by the tuner's shop this week and have them modify one of the Link WRX base tunes so I can load it on the Link when it arrives. Getting closer by the day.
Old 02-22-2009, 08:12 PM   #155
subartender
Member#: 135652
2007 WRX TR
CGM
Very nice build! I check this thread almost everyday to check on the status of the car. Good work!
subartender is offline   Reply With Quote
Old 02-22-2009, 08:14 PM   #156
tony_0227
Member#: 177300
93 Subaru
coming along quet nice i relly like the look of that car
tony_0227 is offline   Reply With Quote
Old 02-22-2009, 09:27 PM   #157
beaviscih
Member#: 123362
'93 Crapcan, '98L
Thanks.
Looking at the last picture it is hard to see the top of the front tire, but tire to fender well is very close to the rear. Prior to installing the Swift springs and Paranoid 3/8" saggybutt spacers the rear looked like it had a busted strut.
How it looked when I bought it last summer:
Right before the swap started:
After suspension install:
Looking at the first picture one might ask why I changed the the trunk lid (and probably question whether I'm actually making improvements ). The main reason was the spoiler - it was an aftermarket job and they drilled through the trunk lid and did a horrible job of sealing the holes.
Old 02-25-2009, 12:20 AM   #158
beaviscih
Member#: 123362
'93 Crapcan, '98L
Got the Ver 1/2 EJ20G base map from Simon @ Link and pulled it into the G4 PCLink software. While the ECU comes with the base map loaded (the ECU won't be in until next week), I'm taking my laptop to the tuner Thursday so he can make appropriate changes so I can start the car. My plan is to run WG pressure for startup and easy road testing. While I know a little about the software, I'm lost as last year's easter egg when it comes to tuning and will let him make the adjustments for the larger injectors, check timing and trigger settings, etc.
Old 02-25-2009, 01:21 AM   #159
tony_0227
Member#: 177300
93 Subaru
coming along quiet well cant wait for you to start it up
Old 02-26-2009, 05:14 PM   #160
Lockness79
Member#: 162872
1996 Impreza L 2.2Mt
Red
Default Right on
Fun ain't it. Getting my car shipped to me can't wait to work on it again. Got a 96 l , took the rear seat and rear disc's from a 90 Legacy.... Interior from a 96 wagon, got to love interchangability, now to save up a ton of money to get the sti motor tranny and clip.
Lockness79 is offline   Reply With Quote
Old 02-27-2009, 10:27 PM   #161
beaviscih
Member#: 123362
'93 Crapcan, '98L
Interesting looking at the stock injector settings in the Link software for the Ver1/2 EJ20G. Latency values by voltage numbers look different than what I've seen posted elsewhere for stocker 440cc injectors.
After updating with the DW650's, the numbers look like this...
Old 03-01-2009, 07:13 PM   #162
beaviscih
Member#: 123362
'93 Crapcan, '98L
Since I'm still waiting on the Link EMS I decided to do some clean up. I removed the washers used for spacers on the accelerator bracket and put in some small tubing. I also picked up a Ver 3 STi TMIC. I'm not sure if I'll use it, but I modified it so it should clear the IACV and tapped in a fitting for the stock BOV. I cut the stock BOV elbow, ground it down and installed a metal plate over the opening. I used an industrial grade bounding material that makes JB Weld look like Elmers glue. Once it has cured I'll buff it out so it looks a little less ghetto.
Lastly, the job I've been dreading, changing the passenger side door window from crank to power. The previous owner put the manual power door on following an accident. Fortunately I had a spare door harness because the clip for the power window motor was cut. It took a few hours but was much easier than expected. In typical Subaru fashion, everything bolted right up and I managed not to break the glass. Now I need a door card without holes cut in it.
Old 03-03-2009, 12:53 PM   #163
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
I need to say one thing besides this swap looks amazing-- You come up with the best analogies bill. Some of them are just classic
I love the swap and you are energizing me to start mine I just wish I had everything I need keep up the awesome work
bugeye-brawler is offline   Reply With Quote
Old 03-03-2009, 01:24 PM   #164
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Hey,
I've got a set of 99 RS doorcards with no holes I'd let go cheap.
jamesfacts is offline   Reply With Quote
Old 03-03-2009, 09:00 PM   #165
bugeye-brawler
Member#: 182337
Sport -- White
Hey where did you find the whiteline tie rods I have been searching for them but have not been able to find them
Old 03-03-2009, 10:43 PM   #166
beaviscih
Member#: 123362
'93 Crapcan, '98L
I bought mine last summer from another member. I'm pretty sure you can get the re-engineered version from FastWRX, MachV or Annapolis Subaru. I spoke with Jackie at Annapolis Subaru a few weeks ago and she was getting her old inventory replaced with the new stuff from Global Performance.
Old 03-07-2009, 06:26 PM   #167
beaviscih
Member#: 123362
'93 Crapcan, '98L
The original grey carpet was so bad I didn't even want to attempt putting it back in. I decided to go with black, but work was required (and I'm still not finished). The pre-cut stuff you can find from many vendors including eBay are pre-cut length and width, you have to cut the holes for the seats, belts, etc. It takes a lot of patience, but since I'm pushing my swap budget I didn't want to take it to an upholstery shop. If I was building a show car I would definitely take it to a pro. Tools required: scissors, carpet cutter, stapler, hair dryer and a hot glue gun. I also got the hood back on and installed some carbon fiber hood dampers.
Old 03-07-2009, 08:06 PM   #168
MOBBiN
Member#: 128441
2006 STi WRB
01 BRP RS, 01 Silver XJ
what do you have left to do?
MOBBiN is offline   Reply With Quote
Old 03-07-2009, 09:37 PM   #169
beaviscih
Member#: 123362
'93 Crapcan, '98L
Start the car! The base map has been tweeked for startup and I'm just waiting on the Link G4, which should be in this week. I've checked most of the electrical stuff that can be checked without starting the car, but I don't want to start the car on the stock ECU with the 650 injectors. While I'm waiting I decided to try and finish some of the loose ends of the project. Body work and paint will come later, if I even decide to do it.
Old 03-07-2009, 11:48 PM   #170
MOBBiN
Member#: 128441
2006 STi WRB
cant wait to see the finished product
Old 03-08-2009, 11:31 AM   #171
beaviscih
Member#: 123362
'93 Crapcan, '98L
Me too. I finished the carpet this morning, disconnected the JDM ECU and cranked the car... and it cranked! With so much work done and being a mechanical n00b I was slightly pessimistic that it wouldn't turnover. Anxiously awaiting the ECU!
Old 03-09-2009, 02:33 PM   #172
bugeye-brawler
Member#: 182337
Sport -- White
where did you find the carpets, I have been searching for a couple weeks cause mine is just as horrible. I found one on ebay, but it was grey I never found any black carpeting.
Old 03-09-2009, 08:13 PM   #173
beaviscih
Member#: 123362
'93 Crapcan, '98L
IIR I got mine from MachV Motorsports. They had both gray and black in stock.
Old 03-11-2009, 02:24 AM   #174
tony_0227
Member#: 177300
93 Subaru
do you know if they have carpet for a 93 wagon mine is gone been looking for a while cant seem to find some thanks
Old 03-11-2009, 06:55 AM   #175
beaviscih
Member#: 123362
'93 Crapcan, '98L
I don't remember seeing it, but I've slept since I bought this so they might have it. Give'em a call or send them a PM (they are a supporting vendor).
I want to tune my 1995 L GF8 2.2L AT OBDII Type2 Engine Management & Tuning 0 02-26-2009 05:06 PM
FS: '98L 2.2L Motor, 5MT and Rear Differential beaviscih TXIC Private Classifieds 0 12-06-2008 10:26 AM
2.2L to 2.5L swap? PyronAbyss Subaru Conversions 11 03-14-2006 04:12 PM
2.2L to 2.5L will this work ? PumpsGOTAWD Normally Aspirated Powertrain 6 04-25-2005 12:49 AM
How much to mod 2.2L to =2.5L hp OSUBeaver Normally Aspirated Powertrain 27 03-27-2003 12:21 AM
