Old 11-23-2008, 09:45 PM   #1
YusukeSTI
Member#: 101707
2008 STI
WR Blue
Default will 17's muck up the 08 STi's VDC
When I went to pick up my new 08 STi this weekend, I brought along my 17's with me, thinking I'd have them put them on before I left.
They agreed to do so, but about 20 minutes later the head tech came out and said he really didn't want to put them on.
He said that the VDC system monitors the rotation of the wheels, and he was worried that the height difference from stock, and hence the rotational difference, would wreak havoc with the VDC system and it could do some screwy things.
Have any of you heard of this, or had problems running 17's on your 08 STi's.
Thanks
YusukeSTI is offline   Reply With Quote
Old 11-23-2008, 09:47 PM   #2
Subjugator
Member#: 154403
05 WRX Wagon
as long as the circumference of the 17's tires are identical to one another you shouldn't have a problem.
Subjugator is offline   Reply With Quote
Old 11-23-2008, 11:48 PM   #3
JohnnyG
Member#: 164671
2009 WRX 265
I had a client pick up his 09 STi a few weeks ago, and he bought some 17" Enkei's for his winters. He mounted his tires, and drove off the lot on 17's, with no issues, and I'm sure many guys will be using 17" wheels for their track tires, so no worries. It'll only mess up the VDC system if you've got different tire sizes on the car at the same time.
The head tech said not to? WTF?
JohnnyG is offline   Reply With Quote
Old 11-24-2008, 07:43 AM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
245/45-17 is almost the same diameter as the the stock 245/40-18 (I think that's the stock 08-09 STI size). A 225/50-17 is about .02" bigger, but still close. As stated above, as long as all 4 are the same, and close to the stock diameter, you should be fine.
http://www.rims-n-tires.com/rt_specs.jsp
Old 11-24-2008, 07:50 PM   #5
YusukeSTI
Member#: 101707
2008 STI
WR Blue
great - thanks all for the help.
Old 11-24-2008, 07:55 PM   #6
jalm111
Member#: 119074
2008 STI
The Japanese version of our STi runs 17s I believe. You will be fine as long as all the tires are the same circumference.
jalm111 is offline   Reply With Quote
Will this work on the 08 N/As weaponstroop Newbies & FAQs 4 05-26-2008 11:44 AM
Can i buy just one tire or will it mess up the car pmatty Tire & Wheel 2 01-28-2008 09:36 AM
05 STI - turbo outlet to IC hose mucked up! AnorexicSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-17-2006 02:45 PM
05 STI - turbo outlet to IC hose mucked up! AnorexicSTI Vancouver Impreza Club Forum -- VIC 3 09-17-2006 05:55 AM
Will it mess up the paint if you remove the rear bumper cover? Veloce Interior & Exterior Modification 5 09-27-2002 12:32 PM
