Old 11-24-2008, 12:04 AM   #1
Safe Drives
Member#: 75146
1998 Impreza Wagon
Arrow Leaking Impreza - Here is Why and How to Fix.
Hi All,
I've been chasing a leak in our 2000 2.5RS Sedan for about two years now. It has been a long and trying challenge for me to find the true culprit(s) of our problem. Currently the entire interior of our car is out and listed below is what I have learned.
Signs of a leak in your car could be:
1) Excessive moisture on the windshield in the morning.
2) Check for the carpets to be damp, even in the least.
3) Sloshing water sounds when driving.
4) Finding water in the trunk.
These could be a sign of a leak in the car.
I'll point out that our car lead a very rough early life. My wife bought the car new in 2000, so we have had it since new. Later, after meeting me, the car won the Oregon Rally Groups 2003 Open Class Rallycross Championship. So if your car is having leaking issues the root cause could be from it living a rough life.
Now I will list the leaks that I have found and fixed in our car, a 2000 Impreza 2.5RS.
Leak 1:
I found that there are drains in the bottom of the frame rails (who knew?) under the car. These got smashed and plugged with dirt and debris after 2 seasons of rallycrossing the car. Over time, water would fill these frame rails and would seep out, in our car, in (mainly) the rear passenger side foot well. Simply clear these drains on either side of the car and the problem is solved.
Leak 2:
The firewall has many rubber gaskets. Check them all to be fitting snug into the firewall. I found a couple of these to be loose and leaking a small amount of water into the car.
Leak 3:
The sunroof and (I think) also the standard rain gutters drain down the "C" pillar and out through the trunk wells in the side areas of the trunk. These too get plugged with dirt causing water to back up into the trunk and even fill up the spare tire well. Again, simply clear these drains on either side of the car, behind the rear wheel well and the problem is solved.
Leak 4:
Front and rear windshields. I could move ours back and fourth by hand... Remove and re-seal them is the only way to fix this issue.
I do hope this helps.
Best regards,
Charles Buren
Safe Drives LLC
www.safedrives.com
877-739-1713 Toll Free
Safe Drives is offline   Reply With Quote
Old 11-24-2008, 01:52 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
cool. thx.
Old 03-19-2009, 09:26 PM   #3
importdoc
Member#: 184078
1999 Impreza RS
Default Trunk Leak
Hi,
Good tips for the leaks, but do you have anymore places to check in the trunk. Mine fills up in the trunk well on the right. So I also assumed it might be the drain being plugged. I disconnected the drain tubes attached, then ran some water through the drain. It appears to drain fine, but the well still fills up with water. This leak is just driving me crazy. Help.
thanks,
Mike
importdoc is offline   Reply With Quote
Old 10-18-2009, 04:41 PM   #4
Man Man
Member#: 224674
1996 Outback ej22
Primer Black
where are these pipes my 96 leaks like a sieve. wagon behind the wheels and spare well, and front and rear floor mat area soaked but the car is spotless underneath. thank you.
Man Man is offline   Reply With Quote
Old 10-19-2009, 12:25 PM   #5
Safe Drives
Member#: 75146
1998 Impreza Wagon
Look under your car on the outer edges of the underside are holes designed to drain away water. Man Man, you should find some holes directly under the area that is filling up with water in your wagon. You'll have to lie on the ground to see them or put your car a lift.. Take a flat head screwdiver with you to clear these drains.
Best regards,
Charles
Old 10-21-2009, 06:49 PM   #6
Man Man
Member#: 224674
1996 Outback ej22
Primer Black
Charles, thank you so much, you were right, they were collapsed from being jacked up on those spots. It hasn't rained yet, but the 3 spots i get wet were the drains that were collapsed. Thank You
Michael Lee
Downshifting Clunk - What is it and how to stop it? hieu1004 Newbies & FAQs 17 04-07-2010 12:50 PM
AFR Gauges help, car is apart and need to fix noonagon Electrical & Lighting 4 03-10-2008 01:02 PM
What the hell could cause this, and how to fix? JEEENKINNNS Off-Topic 11 11-05-2006 05:45 PM
UTEC: Knock when shifting. Whats causing this and how to fix it? STR8OUT Engine Management & Tuning 14 07-03-2003 11:35 AM
New Gen ratlles: where and how to fix pajono Car Audio, Video & Security 0 08-10-2001 02:42 PM
