Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 11-24-2008, 01:33 AM   #1
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Default Some more E85 goodness with the EZ30R
After seeing how well E85 worked on that 16G setup, I decided to go ahead and try some E85 in my H6 Bugeye Subaru. I have been running around on pump fuel at about 18psi, which is about 450whp. With 6 DW 850cc injectors at 80% I started to run out of fuel pressure at higher RPM. At the time I was running a Supra pump with a boost-a- pump at 15Vs. I’m planning on switching to an Aeromotive A1000 over the winter, but in the interim I decided to drop in a dual Walbro setup. With the Aeromotive regulator set at 52psi base fp, the fuel pressure is now stable all the way to 100% injector flow.
With the boost at 18psi on pump fuel output was 454whp and 451 lb-ft of torque. Switching over to E85 and turning the boost up a bit to ~20psi netted a nice 502whp and 541 lb-ft of torque. All in all not bad for only 20.6psi. It is interesting to compare to other 35R based projects. Looking at a few other threads at the top of PPB right now I see the ATP/Agile 35R setup makes about 250 lb-ft at 4000 rpm (onj Q16), while this setup make about 425 lb-ft. The HTA35R setup from top speed makes 240 lb-ft at 4000 rpm (but of course goes on to make a crazy 621whp!).
I experimented with the fueling and found the best power occurred at a slightly leaner than usual .83 lambda. The pump fuel tune was closer to .78-.79 lambda (11.6-11.7 AFR).
I didn’t notice until I was off the dyno that the duty cycles were a bit low in the low end, so next time I’m on the dyno I’ll work on getting the lower boost ramped up a bit faster. Given the injector headroom down low I may try running more boost near torque peak and rolling off towards redline.
While there is adequate injector headroom on pump fuel, the E85 tune pushed duty cycles to about 97% at redline. Any more boost uptop and I’ll need something bigger. I’ll switch over to some 1000cc injectors over the holidays to make things a bit safer.
I originally ran the 20psi E85 map with the same timing as pump fuel, but gained an additional 35 lb-ft of torque with ~ 2 degrees more timing. There is still some work to do in regards to experimenting with different AFRs and the related MBT, but as it sits now the timing seems well placed.
For those not familiar with my H6 WRX, here is a quick rundown of the pertinent details:
(details posted here: http://forums.nasioc.com/forums/show....php?t=1215617 )
EZ30R 3.0L H6 6 Cylinder Engine (used in the 05+ Legacy and 06-07 Tribeca)
Supertec 8:1 CR Custom Pistons
Pauter H6 I Beam Rods
Supertec High Rate Valve Springs and Retainers
Supertec Exhaust Valves
EZ30D Intake Manifold
Custom Fuel Rail and Lines
Aeromotive 1000 FPR (52psi base FP)
Twin Walbro Fuel Pumps intank
Perrin GT35R .82 A/R Turbo kit
Custom H6 Header
DTEC Boost Controller
Hydra 2.5 Engine Management
6x810cc blue Top Feed Injectors
JDM 6-Speed, w/ 05 US 5th and 6th gears
Cheers,
Jeff Sponaugle
Research Calibrator
Surgeline Tuning
sponaugle is offline   Reply With Quote
Old 11-24-2008, 01:47 AM   #2
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Oh, here is a small clip on the dyno.
http://www.sponaugle.com/nasioc/H6DynoRun.wmv
Jeff
Old 11-24-2008, 02:20 AM   #3
swiftwrx1
Member#: 72352
06 E85 v-mount
wht/bronzse WFC#555
Very nice!! I can't wait for my upcoming E8fizzle tune!!
swiftwrx1 is offline   Reply With Quote
Old 11-24-2008, 02:42 AM   #4
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
me either...lol.. hey buddie!!!!!!
H6 the way to go.
Boxer112 is offline   Reply With Quote
Old 11-24-2008, 10:12 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
awesome gains!!
Old 11-24-2008, 10:42 AM   #6
Dobbs
Member#: 28291
2015 WRX
not to **** in your cereal but.. since we're bragging about power at 4000rpm... take a look at P&L's 08 sti 3076R... ~435ft-lbs at 4000rpm, 330whp
Last edited by Audiosavvy; 07-14-2009 at 04:42 PM. Reason: let the swear filter do its job please
Dobbs is offline   Reply With Quote
Old 11-24-2008, 10:42 AM   #7
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Nice gains there. Im still waiting for them to build an e85 station where I live they have one where I work 75miles away but it doesnt do me any good here haha.
robbieshonda is offline   Reply With Quote
Old 11-24-2008, 10:44 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
Originally Posted by Dobbs View Post
not to shi*t in your cereal but.. since we're bragging about power at 4000rpm... take a look at P&L's 08 sti 3076R... ~435ft-lbs at 4000rpm, 330whp
think about that for a minute...
but much like trying to compare an engine that's 20% larger to a smaller one...its all apples and oranges.
Old 11-24-2008, 10:53 AM   #9
Dobbs
Member#: 28291
2015 WRX
ya ya... i guess what i'm saying is... will you put some 100oct in and try again
Old 11-24-2008, 11:10 AM   #10
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
No worries mates. I was only making the comparison to other setups with the same turbo. As one would expect, more displacement helps spoolup and torque. The same can be said for a smaller turbo. If my memory serves me, I made just over 400 lb-ft at 3250 rpm on the stock turbo in my 08 STI (meth spray of course).
Apples to bigger apples indeed.
For me the most interesting thing about this tune was the changes in AFR. I originally ran at about .76l, then started slowly leaning out the E85. On some setups leaning above .78 makes small gains, but here the biggest jump was from .8 to about .83. I'm going to do some more experimentation of the holidays to determine the MBT for each AFR level and see how they compare.
Jeff
Old 11-24-2008, 12:10 PM   #11
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
just wondering, but why does it hold power better with pump?
seanathanq83 is offline   Reply With Quote
Old 11-24-2008, 12:22 PM   #12
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
less boost = flatter tq curve
LatentWagen is offline   Reply With Quote
Old 11-24-2008, 12:38 PM   #13
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
I'm not sure I understand you question. Looking at the graph, the E85 power is flatter then the pump fuel power. Did you mean to say why is the torque curve flatter?
Indeed at the lower boost levels it is often eaiser to keep the torque curve flatter. Keep in mind the torque curve could be made flatter my simply running less boost in the midrange. For a time-attack map that might be worth trying, but I suspect in the end the most torque possible would be the fastest.
I have considered playing around with the boost to try and get the torque curve as flat as possible, just for the fun of trying.
Jeff
Old 11-24-2008, 03:06 PM   #14
Dobbs
Member#: 28291
2015 WRX
jeff.. hope i didnt come off like a jerk from my post earlier. your h6 build thread prompted me to come up with a budget to do it myself, but i decided on an admittantly lower hp 2.5l setup. trying to keep it under 10k, which hopefully should net around 400/400 after all is said and done. anyway, keep up the awesome, first-off work.
Old 11-24-2008, 04:56 PM   #15
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Nah... My comparison was really just a jest.
As an aside, I got a PM about why I had the Aeromotive FPR, so I figured I might as well go ahead and post the reply here:
"The primary reason to upgrade the FPR is if your fuel pump flows so much that the stock unit can't keep up. The FPR is on the return side of the fuel system, and if the FPR can't flow enough to keep the pressure down, you will have above normal fuel pressure at idle and low load/cruise.
In my case there are two critical problems. First I am using a twim walbro setup, which flows quite a bit more fuel, and second I am not using the factory fuel pump controller. As a result both pumps are running 100% all the time. This leads to more flow then the stock regulator can handle, thus the need for a larger regulator.
If I were to stage the pumps (only power the second pump over perhaps 50% duty cycle), I could probably still use the stock regulator.
The only other advantage is in the setup. The nicer aeromotive regulator has either -10 or -6 AN inputs, and FPR Gauge port, and very good construction. It is also adjustable.
In this case I raised the base fuel pressure from 43.5psi to about 52psi, which gave me more headroom with the injectors that I have.
Jeff
Old 11-24-2008, 10:30 PM   #16
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
nice post, your post are always very informative.
how many miles do you have on the h6 now? how is it holding up?
kevinh211 is offline   Reply With Quote
Old 11-25-2008, 09:02 AM   #17
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Notice any issues with the BOV so close to the turbo? Why didn't you keep it at the throttle body?
wcbjr is offline   Reply With Quote
Old 11-25-2008, 09:31 AM   #18
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Jeff Sponaugle
Research Calibrator
Surgeline Tuning
When did that happen?
Interesting results, Jeff. Looking forward to updates here.
jblaine is offline   Reply With Quote
Old 11-25-2008, 10:22 AM   #19
seanathanq83
Member#: 173241
i was reading the graph wrong lol looks good though, great job on the 500whp bet it feels great
Old 11-25-2008, 12:16 PM   #20
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
That is a great question. I actually love the way it is setup now. I have a very light spring in the BOV, so it is open at idle. It will blow off on negative transitions, even from just 1 or 2 psi. The result is very very smooth driving. At part throttle, it will be partially open, and as you increase pressure it closes. It is pretty much the opposite of the BOV setup on my 08, which is the typical vent to atmosphere heavy spring setup.
Anyone driving the heavy spring setup knows about the jerkiness at part throttle high rpm if you lift at all.
Speed density is so much better for this kind of setup.
Indeed. Life is full of surprises. Actually I have been working with Tim for sometime on Surgeline, and of course Tim and I were part of the original PDX crew. Ah the history.
Cheers,
Jeff
Old 11-29-2008, 12:49 AM   #21
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Just a small update:
I played around a bit on the dyno to see if I could get a bit more torque. My upper end hp is limited as I am at 100% injector on E85, but the midrange had a bit more room to go.
After perhaps 30 pulls or so, I managed to get the torque up to 580 lb-ft, but that took about 24psi, compared to the 540 lb-ft at only 20.5 psi. Clearly I am getting to the edge of the compressor map. I was able to get the HP a bit flatter, but I also rolled the boost down a bit more at redline.
On the plus side, I have done probably 50 pulls at >530 lb-ft of torque and the engine is running great.
So.. It looks like I'm going to need to change to a slightly larger turbo to get to my goal of 600/600. I am considering the new GT3788R, which would give me a bit more compressor without too much additional lag.
I'll post a dyno plot tomorrow.
Cheers,
Jeff
Old 11-29-2008, 12:23 PM   #22
wrxhard
Member#: 108091
sweet!!
Maybe plans for a ts40 instead? I've heard the 3788r may be a bit of a mis-matched turbo like 3040r style mismatch. Too much compressor not enough turbine
either way, i love this project. BTW, if you're out of injector now, are you planning on getting some bigger ones or are you just gonna bump the fuel pressure?
wrxhard is offline   Reply With Quote
Old 12-07-2008, 02:13 AM   #23
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Jeff, have you considered the use of a twin-turbo setup for the H6? I know it has many disadvantages in terms of fabrication required, clearances, etc. I mainly would just love to see if it gives even broader area under the curve.
Any option to run dual injectors with the EZ30R manifold? Does the use of the Aeromotive FPR effectively give you more range in injector sizing before low-rpm drivability is hurt?
Frank
Frank A is offline   Reply With Quote
Old 12-10-2008, 11:25 PM   #24
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Now that' I still have yet to check are the stock 3.0R injectors topfeeds aswell and did it take no modifying for the larger injectors? I know you guys worked over the rails on the Perrin 06' car but didn't know what you did on yours. Also would you consider running back to the non-return fuel lines like the stock Legacy's setup? And can I just say DAMN that vid rocks like CRYSTAL METH! Listening to it spool it's like R@@@@@@@@...PEEeeee.....
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 12-11-2008, 12:36 AM   #25
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Frank
The twin turbo setup would be nice, but indeed the packaging is the hard part. I am still planning on doing a twin scroll 4088, as I think that will be the best overall. Right now I have 6 8xxcc injectors, but I will be putting in some 1000cc high impendence ones shortly. They are regular top feed style injectors. It would take some work to do two injectors setups, as the injector inlets in the H6 are in the head, not the intake manifold.
The FPR is there only because the two walbro setup overflows the stock regulator, making fuel pressure to high at idle. It does not make flow better in any way, as it is on the return side of the equation.
-Gaddis
Yes, top feeds just like the old WRXs and new WRX/STIS. Since I am running the Hydra, I could go to 1600cc low impedence injectors, and that is a good option. I have the same fuel rail setup that Jeff has.. pretty much modded stock rails (they are a simple setup), with a regular return system.
It would be difficult to do a returnless system and maintain pressure control, as a boosted envirionment really needs 1:1 fuel pressure ramp. Actually to get the E85 tune, I had to up the pressure a bit from 43psi. I really need bigger injectors to make more power on E85..
Jeff
Back from Tahoe. Take the good with the bad... Asinine Off-Topic 33 02-01-2005 01:31 PM
Some More Night Pics Of The MightyWRX (with temp wheels) + an EVO & No 56K. N'CTRL Member's Car Gallery 26 10-28-2004 12:28 AM
Anyone want to get in good with the wife/gf? joeyproulx New England Impreza Club Forum -- NESIC 10 08-28-2002 07:21 PM
What tire pressures have you found good with the stock RE92 on Bay Area roads whomR Bay Area Impreza Club Forum -- BAIC 7 07-28-2001 07:16 PM
some more spy pics of the new turbo impreza dinosaur General Forum Archive 1 07-27-2000 06:55 PM
