Old 11-24-2008, 09:13 AM   #1
johnowilson
Member#: 195402
Default 1997 Subaru Outback Legacy
I have a 97 5 speed Outback with 170,000 miles.
It has had all the major repairs that happens with this vehicle.
I have 2 questions.
1. My gas mileage has really gotten poor, and never had the oxygen sensors replaced. A friend hooked up his computer and the codes mentioned both oxygen sensors are faulty. Do I need to use a Subaru sensor, or may I install an after market sensor?
2. My cooling fans run continually when my key is on ACC position, and my check engine light blinks off and on. It sounds like the relay is switching off and on and off and on, the fan just keeps cycling on and off. This happens whether the engine is warm or cold. However, when the engine is running the fan appears to work appropriately.
I disconnected a single green wire under my dash, and the fan stopped continually running when the key was on ACC position. Also, the blinking check engine light disappeared. When the engine is running, the fans appear to be running normally, especially when the AC is turned on. Can I leave that single wire disconnected, or should I reconnect it and start to replace relays or???
thank you
JW
johnowilson is offline   Reply With Quote
Old 11-24-2008, 09:34 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Leave the green plugs disconnected. They are for diagnostic/pre-delivery use only and should never have been connected in the first place. Apparently somebody (you or another person working under the dash) saw them hanging and plugged them in.
Old 11-24-2008, 09:43 AM   #3
johnowilson
Member#: 195402
thank you
Old 11-24-2008, 10:25 AM   #4
johnowilson
Member#: 195402
how about the oxygen sensors?
Help from 1997/98 Outback/Legacy Owners: Idle CirrusWRX Normally Aspirated Powertrain 2 03-15-2005 12:00 PM
NY NJ PA: 1997 Subaru Outback 5SPD iceboy Private Vehicle 'For Sale' Classifieds 14 12-31-2004 10:24 AM
FS: 1997 SUbaru Outback iceboy Private Vehicle 'For Sale' Classifieds 1 10-28-2004 03:45 PM
FS or TRADE: 1997 Subaru outback iceboy Private Vehicle 'For Sale' Classifieds 9 07-29-2004 01:14 PM
1997 Subaru outback (clean!) iceboy Private Vehicle 'For Sale' Classifieds 8 05-04-2004 03:02 PM
Message Board Statistics All times are GMT -4. The time now is 04:48 AM.
