Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 11-24-2008, 12:50 PM   #1
vtdave
Member#: 181001
2012 Impreza WRX 5DR
Rally Blue
Default Uneven tread wear mystery...
Help me solve this uneven tread wear mystery....
The patient: 2000 Subaru Outback (wagon). 104k miles. Original suspension. Stock 16" wheels. Gets aligned when it needs it.
The problem: The car is eating tires. It consistently chews through the center tread of both front tires, leaving the tread on both sides of the tires wearing normally and symmetrically. Rear tires wear normally and evenly, too. This has occurred with 2 sets of tires. I doubt overinflation is the culprit. I run 32 psi.
The tires: Bridgestone Blizzacks( same as stock: 225/60/16). When the center tread wore down to 2/32", the outer tread was still 6/32"!
Another set: Nokian WRs (also same size as stock): just purchased in May. Center tread is down to 7/32" but the outer tread is like new.
A penny for your thoughts....
Dave
vtdave is offline   Reply With Quote
Old 11-24-2008, 02:54 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
are you are SURE your tire pressure gauge is correct and that you are reading it properly?
Old 11-24-2008, 03:03 PM   #3
vtdave
Member#: 181001
Rally Blue
Yup...checked with multiple gauges and always while cold. One of them is digitial, so I'm pretty sure I could read it right.
Old 11-24-2008, 03:27 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
post up your complete alignment numbers
Old 11-24-2008, 05:16 PM   #5
apexanimal
Member#: 170186
08 Fit
simply put, despite alignment, if you're wearing the centers faster than the inner AND outer tread, you have too much pressure...
different tires requires different pressures... start with 30psi cold and go from there... good luck...
apexanimal is offline   Reply With Quote
Old 11-24-2008, 05:34 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
Dave
doh......missed that one
running snow tires year round
don't
Old 11-24-2008, 05:39 PM   #7
vtdave
Member#: 181001
Rally Blue
I'll get the alignment numbers tonight.
Uncle Scotty - The Blizzaks were only used during winter. The Nokian WRs are an all season tire, believe it or not!
Old 11-24-2008, 05:46 PM   #8
salisburyv
Member#: 41863
2015 STI
Crystal Black Silica
Wearing in the center of the tire is typically always due to over-inflation. Abnormal wear, such as inside edge/outside edge is either a toe, or camber problem. What is your measured tire pressures? I believe they should be 32fr and 30r. More info required, I'm assuming tires are balanced properly... interesting condition... I'll check back for more info.
salisburyv is offline   Reply With Quote
Old 11-24-2008, 05:57 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
well....it would seem that too much pressure is it unless you have some really weird mechanical issue
i have run LOTS pf different tires in my life and never had this issue...even running 44psi in tires
uneven tread on my rims Luvboost Tire & Wheel 3 02-11-2010 02:01 PM
uneven tread wear causing diff issues... AWDshenanigans Transmission (AT/MT) & Driveline 6 10-05-2009 06:29 PM
Uneven tire wear question: bad alignment by Subaru? Kaiser Brakes, Steering & Suspension 11 02-27-2002 11:40 AM
Uneven tire wear and AWD... Layman Brakes, Steering & Suspension 7 07-05-2001 07:50 PM
Uneven tire wear... strange... jasony Brakes, Steering & Suspension 7 07-02-2001 02:20 PM
