Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 11-24-2008, 11:53 AM   #1
dremersvision
Member#: 141272
Default tire sizing question
i had no idea where to look for this and that is the reason why i posted this question.
I recently ordered some 9.5*18 wheels well i wanted to know if buying 225.45.18 is the same thing as buying 235.40.18 any help would be appreciated thanks.
dremersvision is offline   Reply With Quote
Old 11-24-2008, 01:03 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
You have a LOT of reading to do.
http://forums.nasioc.com/forums/showthread.php?t=524624
http://forums.nasioc.com/forums/showthread.php?t=400311
No. 225/45-18 is NOT the same thing as 235/40-18. Why would you even think that? They're obviously 2 different sizes.
And 18x9.5 wheels? What offset? You do know they are WAY wider than the stockers, and very wide for a WRX? On a 9.5" wide wheel you need at least a 245 width tire. 265 or 275 would be better. All of which will not fit unless you do A LOT of fender modification, or install some sort of wide body kit or fender flares.
This might help too:
http://www.rims-n-tires.com/rt_specs.jsp
Old 11-24-2008, 01:31 PM   #3
drkramm
Member#: 159156
2007 wrx
wrb
while the tires are roughly the same diameter 225 is 26" and 235 is 25.4"
not really safe putting that on a rim that wide .. that is unless you want the euro /vw/audi look they love strechin out tires. ( not alot of places will even consider mounting these and the ones that do will have a helluva time getting the bead to set)
i agree with mav though atleast a 245 is needed i had trouble fitting 245's on 17x8's on my wrx (more negative camber in the rear)
drkramm is offline   Reply With Quote
Old 11-24-2008, 01:42 PM   #4
fiveoh88
Member#: 125600
2005 STi perrin stg2
World Rally Blue
yea man, you need a hell of a tire for a 9.5" rim- unless you want tire stretch and poor performance...i use to run 17x9's with 275's on a old car of mine
235/40R18 looks good on a 8" rim, i run 18x8's and 235/40R18 star specs, ET 48 offset and negative camber is the only reason i don't rub in the rear under full compression...
fiveoh88 is offline   Reply With Quote
Old 11-24-2008, 01:47 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i think you ordered the wrong wheels
SCC WRX Tire Size Questions... SCOOBER Brakes, Steering & Suspension 4 09-05-2001 02:22 AM
tire size question... redbaron Brakes, Steering & Suspension 8 09-04-2001 09:27 PM
Tire size question Joelk Legacy Forum 3 08-15-2001 11:22 PM
tire sizing question wop Brakes, Steering & Suspension 11 06-22-2001 03:45 PM
Tire Size Questions (solo 2) Miracle Worker Technical Forum Archive 12 09-13-2000 11:31 PM
