Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
View Poll Results: Is this set-up safe to drive on?
Safe 11 100.00%
Not Safe 0 0%
Voters: 11. You may not vote on this poll
Old 11-24-2008, 05:24 PM   #1
jalm111
Member#: 119074
2008 STI
Default Is this safe? Need your help/opinion.
I don't know much about mounting tires on rims and matching up the sizes. I got my 215/45-17 winter blizzaks mounted on BBS 17x8 rims *stock 05-07 STi rims). I put one of the rims on the car and lowered it down. It did not debead but the tire does look kind of stretched. Please let me know if this is safe to drive on. The firestone guy said that if it doesn't debead on initial mount then you're fine but I just want to make sure I don't loose a tire at 70 mph. Thanks for you help guys.
I took a couple pictures as I thought they would help.
jalm111 is offline   Reply With Quote
Old 11-24-2008, 06:22 PM   #2
fiveoh88
Member#: 125600
2005 STi perrin stg2
World Rally Blue
i've seen VDubs with more tire stretch...
fiveoh88 is offline   Reply With Quote
Old 11-24-2008, 09:32 PM   #3
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
A "215" tire can be mounted onto a rim that is from 7" to 8" wide. So in your case you are at the upper end of the limit on an 8" wide rim.
The stock sizes for a 2008 STI, with either rubber or metal valve stems, is either 235/45-17 or 245/40-18.
With the 215's you will have slightly better snow traction over either a 235 or 245 wide tire.
Old 11-24-2008, 10:08 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
its ok....not optimal....but ok
Old 11-24-2008, 11:01 PM   #5
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
running the same setup for 3 years now, you will be fine. and have better traction in the snow than a wider tire as it will "cut" through the snow better.
been a lot faster than 70mph on them as well
pauli18c is offline   Reply With Quote
Old 11-24-2008, 11:34 PM   #6
BlaineWasHere
Member#: 165271
2013 FR-S
This is mild in the VW world... Not my style though...
BlaineWasHere is offline   Reply With Quote
Old 11-24-2008, 11:35 PM   #7
jalm111
Member#: 119074
2008 STI
Cool. Thanks for you help guys. That was the idea behind the 215. I know in snow the skinnier the tire the better... plus I got these off CL for $250 a while back with 12/32 life left so I figured I'd try to make it work
Now I just gotta pray to the snow gods.....
Old 11-25-2008, 04:03 PM   #8
2.5GTLegacy
Member#: 111219
2005 SWP LGT
That's the same size tires I'm running, but my BBS are 17x7 tho.
2.5GTLegacy is offline   Reply With Quote
Old 11-25-2008, 04:33 PM   #9
Craigs92X
Member#: 147159
2012 Outback Limited
Modless....
You will be fine....
Coming from V-Dubs I know a little bit about stretch.
Craigs92X is offline   Reply With Quote
Old 11-26-2008, 04:39 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
but WE know stretch is stupid and dont recommend doing such stupid, unnecessary things
Need your help, tell me what turbo this is! RaceCreations Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 06-02-2009 09:58 AM
Need your help! Find out what this is!? YBajaSteve Baja Forum 8 12-09-2008 02:22 AM
OT, I need your help. is this site legit? brucelee Off-Topic 57 12-25-2007 09:11 PM
OT I need your help...this is a desperate situation... ZMANNH25rs Off-Topic 36 06-13-2007 05:04 PM
Please Please Please read this. I need your Help. wrxman555 Mid West Subaru Owners Club Forum -- MWSOC 26 07-19-2001 04:50 PM
