Closed Thread
Old 11-24-2008, 11:13 PM   #1
08SubieWRX
Member#: 178758
08 WRX [email protected]
08 STI Blk/ 09 WRX Slvr
Default What does this do?!?!?!?
I have been waiting patiently all day and not one person has responded. So i will post it here in the General area. But i also have another question. What is does this line do? Because i no when i was pressurizing my car if i were to move this barley it would release all the psi. Can anyone tell me what it is and why it did that?!?! Thanks.... Also reply to my other post here i need help!!! (Its the metal line that goes into the rubber line fyi)
Here is the reference to the other post.... http://forums.nasioc.com/forums/show....php?t=1645270
08SubieWRX is offline
Old 11-24-2008, 11:47 PM   #2
jalm111
Member#: 119074
2008 STI
You need to put up a little more detail of where this is. Is that your blow off valve? You have like 5 lines in your circle....
It's probably a vacuum line if it releases your psi when you pull it off. Not sure which one. Maybe you could throw up a zoomed out shot?
If you loose PSI when you move it slightly than that might mean it's cracked somewhere or etc. It's not suppose to loose vacuum when it's just moved.
jalm111 is offline
Old 11-25-2008, 12:18 AM   #3
yankeesfan
Member#: 182065
^+1. What happens when your car flexes?? it loses pressure?
yankeesfan is offline
Old 11-25-2008, 03:22 AM   #4
razgriz
Member#: 160925
2004 wrx wagon
white!
your picture is confusing but to me it looks like the pcv line that runs along the top of the I/C. it should have no effect at all on your boost, other than it might create a genralized vacum leak. but again im not sure what im looking at as your recirc valve isnt hooked up to the I/C that i can see. please tell me your recirc valve isnt just sitting there not hooked up to anything..
razgriz is offline
Old 11-25-2008, 07:50 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Do not crosspost, use your original thread.
Mulder is offline
Closed Thread
What does this do? Frogsthatmoo Legacy Forum 10 10-28-2008 03:10 AM
what does this do? romanlynch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-19-2007 04:52 PM
what does this do and how can i use it sigma pi Off-Topic 14 08-11-2003 01:30 AM
So What Does This Do? (radiator ques) stimpy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-26-2003 09:42 AM
What does this do? Keiho Normally Aspirated Powertrain 6 10-30-2000 10:51 PM
