Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Closed Thread
Old 11-25-2008, 06:16 AM   #1
Member#: 189378
Default Valves are Bent... Options??
Ok, if you followed my previous thread, or not, my Vibration Damper came apart, and the result was my timing belt skipped about 10 degrees. I opened up the timing area and just re-alligned everything, the engine would not start, guessing there is valve damage.
What are my options? I want to know, how likely are the valves seats damaged too? How about the pistons? Do they ever suffer damage from valve contact? I don't want to be into $2000.00 of engine disassembly and find I need to get new heads too.
I want to know if Valves bent are the only probable issue.
I have ordered a Perrin Aftermarket Crank Pulley. I have read they vibrate the engine, is this true? I will never use a stock damper again. This was a perfect running engine, and really makes me wonder if Subaru will continue to be my favorite car. This is my third one, but this should not have happened, and teh factory should make amends.
I really dread taking this to Subaru to do the work. I would like to do the work myself, but no garage and winter is almost here.
Does Subaru warrenty the engine after such a repair, and how many miles is the warrenty?
Mike_Subaru is offline
Old 11-25-2008, 07:48 AM   #2
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Please use your original thread, do not start a new one.
Mulder is offline
Closed Thread
Rims are bent, but are tires ok? Fleek04 Vancouver Impreza Club Forum -- VIC 11 01-17-2006 08:52 PM
Is it ok if the intercooler fins are bent or damaged? minisiu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-21-2002 03:44 AM
My Team Ds are bent. 25psi Brakes, Steering & Suspension 9 06-01-2001 09:58 AM
My Speedlines are bent??? Bunuel General Forum Archive 13 07-31-2000 10:18 PM
