Old 11-25-2008, 12:22 AM   #1
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
Default EJ20G into 94EJ22T
I'm in the midst of swapping a EJ20G (Ithink) into a 94 legacyGT (EJ22T)
I have the engine in hokked up to the (AUTO) tranny turbo hocked up to the downpipe some coolant lines hocked up doing th cam timing wed had to get cam gear (the plastic kind) from a 2002 WRX (hope that works) cause one had some of the guide cracked off! have to still find a new coolant resiviour cause the 22's was on the other side to tall to work on the right side need a intercooler and Y-pipe gotta make the 22's engine harness work cause the stuff is in different locations (make some longer some shorter!! what else am I into with this?????? any help would be greatly appreaciated thanx jesse miller!
94 GT is offline   Reply With Quote
Old 11-25-2008, 12:51 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You NEED a 7 tooth cam gear. I.e. the older DOHC style and NOT the 7 tooth 90-94 SOHC gear. The WRX cam gear will NOT work with your ECU/sensor (unless its an early 7 tooth).
Did you replace the water pump? The timing belt? check the timing belt idlers? That **** is usually done for on these used engines.
Old 11-25-2008, 03:01 PM   #3
johnny p
Member#: 141232
02 v7sti wagon
signal green
Reddevil,is there a early WRX cam gear that works?
johnny p is offline   Reply With Quote
Old 11-25-2008, 08:08 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yep. Any of them.
Old 11-25-2008, 10:06 PM   #5
94 GT
Member#: 193676
94 legacy GT
Default yup the 2002 wrx will work??
just picked up the 2002 wrx LH EXAUST cam gear it was almost exacly the same as the EJ20G's exept the bolt holder for holding the com gear in place is star shaped as the G's was hex shaped!! and the G's had a little press in stud tha fit into the cam while the WRX's needs the woodruff key!! it should fit right in the cam!! the teeth and gear markings are identical but tomorrow I got's to do the timing! I checked the play on all the tensioners they were good also the EJ22T"s were all new so ifany probs I'll just but them in cause there exacally the same the water pump look's good. the 22's is the same too!! .the hydrallic tensioner has a different # on it so I'm using the 20's one. (it's a little rustyer looking though) but it should be fine new belt and keys new seals all round .
Tomorrow I got to hook it all up I have to change the engine harness to reach all the sensors and injectors, coolant temps, I,C,V, oilpress,e.t.c.
all are the same conectors but in different locations throught the engine so's I gotta make some shorter some longer with the JDM harness!!
Do you guys think the EJ22T's ECU run the 20G okay .I"M going to get a manual boost controller to control the bigger turbo. will that work do you think??? I think the 22's controls should be close cause it's turbo too!! the fuel pump and stuff shouldbe the same or close cause the GT's and RS's were both built in Japan. american cars probly run richer compared to HP than the Japs do cause they squeze mor out of smaller and want good economy! Anyways the coolant resivivour for the 20G is on the right front side of the motor the 22's was on the left rear and is too tall for the right front and the G's is all bustedso I gotta make somtin work untill I get the right one1 so any help is greatly apps thanx Jesse
Old 11-26-2008, 11:17 PM   #6
94 GT
Member#: 193676
94 legacy GT
the wrx"s cam gear didn't fit to well but I made a custom key and wrapped the cam in tape so the gear fit more snug like the old one I woulda found an old one round here or somewere but it's outta the shop after tomorrow so had to make do.
man timing is a bitch to do on this engine those short little cams sure move tooo easy when there loaded but hopfully ti's good now(after only like 6-8 tries) the one in my 4A-GE corolla was way easier to do even if the space was like 20 times smaller!!
wires tomorrow finish hookups and check timing after running if it in fact runs (hope so)
if anyone has any tricks to tell please let me know thanx
Old 11-27-2008, 09:42 PM   #7
94 GT
Member#: 193676
94 legacy GT
Default it can be done!!
I got it to start today but the wrx cam gear kinda was bumpy so I filed the rough part on the old cam gear guide that was cracked off and used that . the wrx one worked but not to good so ( DON'T USE ONE CAUSE IT MAY CAUSE PROBS) but it worked I was just un cofortable with it plus it was like $130 so I will get most that back??? but cam timing still off so I can't get it , we just cant get it perfect, tried like 6 more times but the best we got was LH ext cam 1 tooth advanced so startin it again then check it again, Doe's any one have any good info bout doing this cause when I pull the belt over the last idler it pulls the lef or right cams out together!!! so can anyone HELP ME
thanks jesse
Old 12-07-2008, 10:31 PM   #8
94 GT
Member#: 193676
94 legacy GT
she drives now!! so I still need a TMIC to work good ,the getto set up I made by cutting up the ej22's intakepipe flipped upside down with some rad hoses with two 80 degree angles put together with a plumming coupler, and glued it to the inside of the intake pipe!! so I'm not going to be pushing too much boost untill I get an intercooler!
Old 12-08-2008, 12:38 AM   #9
suberdave
Member#: 101865
88 GL-10 STi
what kind of intercooler are you looking for? i have a slanty EJ2G TMIC ill sale for $40 a huge turboXS style TMIC ill sale for $100 and a stock 02-04 WRX TMIC ill sale for $35, plus shipping on all of them of course...
good to hear you got it running...
-=Suberdave=-
www.suberdave.com
suberdave is online now   Reply With Quote
Old 12-08-2008, 12:50 AM   #10
94 GT
Member#: 193676
94 legacy GT
what you want for shipping to L1N 4M4 Canada??/ do any of them have the BPV and Ypipe??? is the ej20g's better than the wrx's?? will the big turboxs one fit in a 94 legacy turbo with a ej20g??
thanx those are some good deals let me know Jesse
EJ20G into 94EJ22T 94 GT Pre-2002 Factory Turbo Powertrain 1 12-08-2008 12:53 AM
EJ20G into a WRX snowman4us Subaru Conversions 24 03-15-2005 11:20 AM
Ej20g into 93-97 early gc8 swap muhon Subaru Conversions 5 12-02-2004 11:25 PM
Early JDM EJ20G into USDM EJ22 Legacy 96WRX Subaru Conversions 2 09-10-2004 12:54 PM
Legacy EJ20G into 93 L FWD skyliner33v Subaru Conversions 36 04-28-2004 04:01 AM
