Old 11-25-2008, 11:19 AM   #1
the white wrx
Member#: 146957
Default noob egt sensor question
hey everyone, my car threw a p1312 cel a few days ago. autozone said it's a bad egt sensor. my question is, do i have more than one egt sensor? ive got a 2004 wrx with an sti up pipe, so i dont even have an egt in the up pipe. is there one in the exhaust?
i also noticed that some people were saying that a p1312 is a misfire code. did they change the code from year to year?
mods are: cobb intake, sti uppipe, helix bellmouth downpipe, greddy evo2 exhaust. tune.
the white wrx is offline   Reply With Quote
Old 11-25-2008, 11:59 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
P1312 Exhaust temperature sensor malfunction
there is only 1 stock EGT - if you have a catless uppipe w/o EGT you need to do the '2.2kohm resistor mod' - basically you fake a normal EGT thermistor reading using a 2.2k resistor in the harness - search or read the Exhaust / Uppipe FAQs for more detailed instructions
perhaps you had a resistor fitted but it's recently fallen out
afaik missfire codes are all low 3xx not 13xx
UkNuck is offline   Reply With Quote
Old 11-25-2008, 12:06 PM   #3
the white wrx
Member#: 146957
thanks for the quick reply! ill have to check it out this weekend.
Old 11-25-2008, 12:25 PM   #4
the white wrx
Member#: 146957
something just occured to me, when i had my car tuned we erased the cel code that resulted in not having an egt sensor. that way i never needed to mess with the 2.2k resistor mod. what else could be causing this?
Old 11-27-2008, 01:53 PM   #5
the white wrx
Member#: 146957
for those interested, the problem has been solved. it turns out that with an open ecu reflash, the egt sensor error can creep back. solve it with the 2.2 ohm resistor mod.
Noob o2 sensor question teamsubaru2006 Newbies & FAQs 8 03-26-2008 06:23 PM
EGT sensor question jim1969 Engine Management & Tuning 34 10-17-2005 11:36 PM
EGT sensor question Chefn76 Newbies & FAQs 3 06-01-2005 12:55 PM
noob o2 sensor question Rickyh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-21-2004 11:09 AM
EGT sensor questions Tim Quinn Vancouver Impreza Club Forum -- VIC 0 10-31-2003 05:55 PM
