Old 11-25-2008, 01:06 PM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Spied: Next-generation Audi A8
Following closely on the heels of the first sighting of Audiís upcoming A7, our spy photographers have captured the first images of the next-generation A8. Although the pictures arenít of the highest quality, they are the first of the A8 in its own sheet metal.
Under the new sheet metal will be an extended version of the modular platform used in the A4, but expect to see more exotic materials such as aluminum and magnesium employed to help save weight and improve dynamics.
The A8ís engine lineup will likely mirror the current range, starting with a 2.8-liter V6, and topping out 4.2-liter V8 FSI. And, possibly, Audiís new 6.0L V12 TDI will be offered.
And like the A7, there will also be more supercharged units as well as increased application of Audiís latest valve-lift system. The base model will remain front-wheel drive, but all-wheel drive variants will feature the latest Quattro torque vectoring systems, which distributes drive individually between each axle and between the rear wheels for improved traction and stability.
http://www.leftlanenews.com/audi-a8-future.html
Old 11-25-2008, 01:08 PM   #2
White out
Member#: 46277
** LP640
Viper GTS
Looks great.
Nick
White out is offline   Reply With Quote
Old 11-25-2008, 01:12 PM   #3
ghibli99
Member#: 90761
2003 S2000
Save the Manuals!
Looks-wise, it doesn't look all that different from the current A8. The back end might be stubbier. These have never looked like $80k cars to me (not that a lot of Audis look or support their asking price to begin with).
-Mike
ghibli99 is offline   Reply With Quote
Old 11-25-2008, 01:15 PM   #4
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
not really liking it, but I'll wait for the airbrushed and massaged pics to case my final vote.
That rear pillar is sorta foul.
monovich is offline   Reply With Quote
Old 11-25-2008, 02:15 PM   #5
Hazdaz
Member#: 14611
Jebus Christ, talk about front overhang!
By comparison, a couple of it's fellow competitors:
You can tell that they are trying to play-up the R8-look on this car (especially in the headlight/hood area), but damn it's proportions are just awful.
Hazdaz is online now   Reply With Quote
Old 11-25-2008, 02:51 PM   #6
richde
Member#: 79498
2013 XV Silver Slug
'84 Porsche 911-sorta red
Isn't that overhang required to package the AWD system?
richde is offline   Reply With Quote
Old 11-25-2008, 03:07 PM   #7
Hazdaz
Member#: 14611
^^ The A8 (like most Audis) is predominantly a FWD car... the AWD is kind of a "retrofit". I think Audi did something stupid in the new A4 like move the engine forward... ahead of the front axle or something like that to let the tranny fit. (I hope some Audi-guy can clear up my info because I admit to not remembering the whole story). This A8 is loosely based on that A4 platform.
Also, note that I believe all the cars I posted have AWD availability...they are also all RWD-based.
Old 11-25-2008, 03:43 PM   #8
Yotsuya
Member#: 935
Jack Soo Fan Club
Isn't that pretty much every Audi since VW rekindled the brand in the 70s? Or did they somehow move it up even more for some fancy pants tranny?
Yotsuya is offline   Reply With Quote
Old 11-25-2008, 03:51 PM   #9
Hites
Member#: 138997
0000 Nothing
the a8 does not compete with the bmw 5-series or cadillac cts. the a8 is made to compete with the 7-series and s-class, maybe the cadillac sts.
Hites is offline   Reply With Quote
Old 11-25-2008, 03:53 PM   #10
unclemat
Member#: 114530
2005 LGT 6MT wagon
Holy overhang. Worse than on Subys.
unclemat is offline   Reply With Quote
Old 11-25-2008, 04:07 PM   #11
dunk
Member#: 15359
The engines on the A6 and A8 are longitudinally positioned. The tranny is behind the engine like a traditional RWD layout. At the tail of the tranny there's a transfer case and foward driveshaft that runs back up to the front axle/diff. It's the same basic layout as BMW's system.
You're correct that the A4/TT platform has a transverse engine/tranny layout like a traditional fwd car. (Also similiar to the EVO AWD layout)
There's almost no similarity between the the A4/TT and A6/S6/A8/R8 drivetrain layouts, other than the brand Quattro.
Duncan
dunk is offline   Reply With Quote
Old 11-25-2008, 04:09 PM   #12
dunk
Member#: 15359
Here's an S8 cutaway that shows the engine position. Unfortunately you can't really see the foward driveshaft as it's on the other side of the car.
Old 11-25-2008, 04:29 PM   #13
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
Duncan
There is so much misinformation here, I don't know where to begin.
The basic layout for Audi "Quattro" is what subaru used as a template. go look at your car and get back to me.
The Quattro (as used in the A4,A5,A6,A8) is AWD first. Some versions are changed for lower cost in the A4 for FWD.
The AWD in the A3 and TT are from VW and are transverse motors with a FWD first setup. This is radically different from the rest of Audi's line.
(Also, the R8 is really a lambo and uses a different AWD system as well).
As far as the A4,A5,A6,A8 layout, which dates back to 1980, the motor is mounted longitudinally. Behind the motor is a casing that houses a transmission, front differential, and center differential. This saves weight over the BMW/MB/Infinity type system which is rear drive with a center gear after the tranny, a small shaft going forward next to the engine, and a front differential.
The benefit is overall reduced weight of the AWD system, and a better balanced system as it is "symmetrical" (again, Subaru borrowed the basic design). The inherent problem is that the front axles connect to this tranny/diff housing, requiring the motor to be mounted fully in front of the front axle line.
Subaru and Audi share this issue. Subaru has used smaller engines to keep the motor short, and a boxer layout to keep it low. Audi used only I4 and I5 engines for a while, and this worked reasonably well. However, and they have fitted V8 and V10 motors, the front-heavy nature is exaggerated. The newer Audis actually angle the axles forward, to push the motor back a bit, but it is what it is.
As far as this car, I don't mind the front. It helped the car guy in Ronin to shove a bit anyway. I find the C-Pillar to be a bit thick for this car, and gives it almost a Bentley stance. I like it on a Bentley, but not on an Audi for some reason.
Actually, I can see that the back piece of glass is blacked out, and you can see the trim where the window actually is.
Derbagger is offline   Reply With Quote
Old 11-25-2008, 04:40 PM   #14
unclemat
Member#: 114530
2005 LGT 6MT wagon
So Audis never went to DFD (divorced front differential)? The holy long overhang would suggest they did not.
Old 11-26-2008, 03:24 PM   #15
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
the most they've done is to pull the engine/tranny back a bit and angle the front axles forward. the A5 was the first use and it did help by an inch or two.
They won't divorce the diffs since it would detract from the whole point of Quattro in minimizing the weight of the entire AWD system.
Next-generation Audi RS4 coming in 2010 AVANTI R5 Non-Subaru News & Rumors 31 09-02-2009 03:18 AM
Official: Next Audi A8 coming in 2010 AVANTI R5 Non-Subaru News & Rumors 2 07-08-2009 02:47 PM
Next-generation Audi A3 delayed by a year AVANTI R5 Non-Subaru News & Rumors 6 05-04-2009 04:23 AM
Next-generation Audi A6 details emerge eurospek Non-Subaru News & Rumors 10 05-18-2008 11:36 PM
Spy shot: next generation Audi S4 Avant during nordic testing in Nunavut GusS Legacy Forum 11 01-20-2002 03:13 PM
