Old 11-25-2008, 01:40 PM   #1
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Default Evo warning... 674 whp on 93 octane + meth
I know it's not a Subaru, but we thought it was a cool car so I wanted to share. This is a daily driver setup tuned on AEM EMS.
Brian Crower stroker kit, T67 Shearer manifold turbo kit, plus the supporting intercooler, intake/exhaust, and fuel mods you'd expect.
93 octane with meth injection. It's always fun to see a 4 cylinder make good power on pump or pump/meth for a daily driven application.
I also thought it was interesting to compare the torque output and curve on this setup to the STIs we do so much more of.
As you can see the graph is uncorrected so the numbers aren't inflated. I had street tuned the car and and tested it afterwards on Magnus's dyno in Toronto where the customer is from. I was asked to retune the car and tune it up to see what it can make and then back it off. It turns out I never increased the boost because it made plenty of power just from tuning. The car went from 489-623 whp with tuning (no boost adjustment), and then to 674 whp with the manifold and retuning the fueling back to where it was. I'm not a magician so clearly the tune needed some attention. It could have made more power still, but this is already plenty so there was no point in bumping the boost up or getting aggressive with timing. The manifold worked as advertised so we were happy.
The alignment on the car is off a bit. That made the car want to run wild on the dyno which made the graph undulate a bit, but it will get an alignment at some point. As you can see max boost was 31.08 psi and it tapered to 25-26 psi at redline.
We tested the car with and without Magnus's new cast manifold for the Evo. Here's a little video showing the before/after dyno pulls etc.
For reference, Gary who wrenches at our shop has a DSM with 480 whp uncorrected on this dyno. It goes low 10's at 137-138 mph at 3000 lb weight.
Innovative Tuning is offline   Reply With Quote
Old 11-25-2008, 02:02 PM   #2
BrentS
Member#: 96601
2004 WRX
Wow, that is nice! That car would be an absolute blast to drive around!
BrentS is offline   Reply With Quote
Old 11-25-2008, 02:10 PM   #3
APS04silverwrx
Member#: 103813
2004 Silver STI
377whp 341wtq Green baby!
good god
APS04silverwrx is offline   Reply With Quote
Old 11-25-2008, 02:16 PM   #4
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
I notice a lot of EVO's run 30+ psi on 93+meth as daily drivers while the consensus is 25-26psi over here for Subarus. Is your opinion built Subaru motors could run the same?
verc is offline   Reply With Quote
Old 11-25-2008, 02:27 PM   #5
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
I saw 600+ in the title and my first thought..............EVO
JMK508 is offline   Reply With Quote
Old 11-25-2008, 04:01 PM   #6
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
It can definitely be done with the right build on a Subaru.
Evo guys often deal with head flow while they have a stock turbo. They get that issue right out of the way. STI guys either never touch the heads or don't port plus add cams. The few that build the engine, port the heads, upgrade cams, and have a turbo and intake/exhaust mods to flow this much air efficiently can run this boost on pump/meth no problem.
It's more a difference in the Subaru vs. Mitsu customer than anything.
Old 11-25-2008, 04:14 PM   #7
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
It's also a difference of pulling a valve cover and slapping in 2 cams in 2 hours vs pulling a motor, changing 4 cams and reinstalling a motor
Back OT: WOW.
rjrutzky is offline   Reply With Quote
Old 11-25-2008, 04:18 PM   #8
wittmer25
Member#: 102970
2004 STi gt30r
better flowing heads, short runner intake/exhaust manifolds help the VE on the evo's. These are the three things that stick right out. I believe they can also run more lift on their cams without as much machining of the heads.
wittmer25 is offline   Reply With Quote
Old 11-25-2008, 04:29 PM   #9
APS04silverwrx
Member#: 103813
2004 Silver STI
almost perfect power band, Lag would not be an issue outside of first gear!
I bet it just hauls!
Old 11-25-2008, 04:40 PM   #10
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
4G63T's rule.
If your evo runs 12s its slow, lol.
mxpunk is offline   Reply With Quote
Old 11-25-2008, 04:52 PM   #11
Clark_Kent
Member#: 114299
I am seeing more and more this. Good job and keep it up.
Clark_Kent is offline   Reply With Quote
Old 11-25-2008, 05:10 PM   #12
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Back OT: WOW.
You're absolutely right about cam install.
On the other hand it's still a difference in customer base. Subaru guys are getting used to 35R's for street cars while Evo guys are running 37r/t67's/40Rs or bigger on the street and have been for a while.
280 is a common duration for a shelf cam for an Evo while Subaru guys are just warming up to the idea of putting that in a drag car.
Many guys with Evos are fully prepared to build the shortblock, port the heads, upgrade the cams and valvetrain plus gears. Subaru guys generally only want to do some of the above, or none. Like I said, a Subaru can definitely do this. You just have to go to the lengths the Evo guys are going to. One Subaru I tuned comes to mind. He paid to play and his car makes about 600 on pump gas (no meth).
Old 11-25-2008, 05:47 PM   #13
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
The iron block (assuming this is not an Evo X) helps withstand high boost a bit too lol
Steve.804 is offline   Reply With Quote
Old 11-26-2008, 12:36 AM   #14
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Look at the cost of parts for a mitsu compared to them of a subaru 10K Axis motors, etc 10K on a Evo motor will get you a very long way.
Token-Negro is offline   Reply With Quote
Old 11-26-2008, 07:26 PM   #15
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
damn very nice #s!!
Iflysti06 is offline   Reply With Quote
Old 11-26-2008, 07:38 PM   #16
REXLR8
Member#: 70937
2006 VW GTi
RED
Well put. To summarize, us subaru guys have NO balls lol.
REXLR8 is offline   Reply With Quote
Old 11-26-2008, 07:58 PM   #17
Chiketkd
Member#: 71634
In hibernation...
Originally Posted by APS04silverwrx View Post
good god
+1 Damn!
Chiketkd is offline   Reply With Quote
Old 11-26-2008, 10:53 PM   #18
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
The cost this is a big issue...I have a built motor 272 cams GT37R(T67) and a light port job...My car runs amazing and I've been useing it as my daily driver since my se-r is broken. The problem is, I dont have the money to build a sleved block, and get a wild headgames port job. The evo's have a big advantage with the iron block. Pistons rods berrings and cams go a long way in an evo.
perrin247 is offline   Reply With Quote
Old 11-27-2008, 01:56 AM   #19
Shabib67
Member#: 61749
yea if prices on sleeved blocks and built blocks in general came down i bet we would see a lot more sti/wrx with big hp numbers all over the country.
Shabib67 is offline   Reply With Quote
Old 11-27-2008, 09:01 AM   #20
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Love the screen-name dude!!
Happy turkey day!
scramjett is offline   Reply With Quote
Old 11-27-2008, 11:23 AM   #21
oneoverWRX
Member#: 74793
02 WRX
BLAZE YELLOW
LOL. Subarus can not run 45-50 or whatever psi. They may be able to compete with the performance of this car but will never be able to compete with cars like the buschur, ams, or devo cars. I am sure there are others that i left out just thought i would say those few.
The subaru motor just cant handle those boost levels. The block will eventually push itself apart. 35psi is about the safe limit from what i have been told.
I dont think it has anything to do with the customers It is mainly the fact that you can do a rod and piston swap to a 4g63 and have a motor ready for 500-600whp with a set of cams. Maybe more power not really sure. I have a friend with a 2.3 evo, bone stock heads but he has gsc280s and he has been 131mph in a fullweight evo. This is on the stock ecu and stock maf. Biggest difference is the block, in my opinion.
oneoverWRX is offline   Reply With Quote
Old 11-27-2008, 12:17 PM   #22
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
That because there fully closed deck block's. There's a lot of R&D into those 4g63's.
People run 30psi on the EJ207's all day.
spoolinsti05 is online now   Reply With Quote
Old 11-27-2008, 12:19 PM   #23
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Nice Mike puttin that work in! Did you guy's get another dyno?
Old 11-27-2008, 12:34 PM   #24
twitch 420
Member#: 192130
05 WRX/wagon
WR Blue
i have an 03 evo and i plain on using meth with AMS 35r setup this spring,after driving one my mind is made up..
twitch 420 is offline   Reply With Quote
Old 11-27-2008, 10:50 PM   #25
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
This is the problem.. People think this way... I have run 30psi on 93 octane for a year on a piston and rod motor with cams EJ25/WRX HEADS.. 40-42psi on race gas all day long, reason I didnt go higher is because the turbo couldnt. 0 problems..
I have customers that make 500+whp on stock motors and run into the 10s,.. 1 with a stock ecu and MAF.
While you are right that the block is diffrent, you are wrong in saying you "cant" as the OP posted.. People are scared to try.. I try and I seem to be getting the cars going down the track fast.
As for competeing with guys like Dave B, AMS, devo... Its just easier to go fast in the other platform.
Look at the Pr cars, Big Valley to be exact, that car is just as fast as any other evo with a 42r, or the few other PR boys that have gone 9s on smaller turbos, just like the EVO guys.
So in closing, the OP is right... Most subie guys are just scared to try it.
Junior2JZ is offline   Reply With Quote
2005 Saabaru - stock 2.0 - Super16G - 352/304 whp/wtq - 93 octane Motion Lab Tuning Proven Power Bragging 53 09-17-2010 10:24 AM
Not a Subie: AMR EVO 8 - 600whp / 93 Octane / Meth Injection AMR Proven Power Bragging 27 12-18-2008 01:56 PM
400 WHP, 24.5psi on 93 octane, no meth??? TurboQueef Built Motor Discussion 4 08-13-2008 08:31 PM
Warning! New Summer blend 93 octane. If you are tuned read!! Valhakar Engine Management & Tuning 99 08-19-2006 01:40 PM
New Record! 407 WHP on 93 octane! Tuning Factory Inc. Proven Power Bragging 61 07-29-2004 08:22 AM
