Old 03-26-2002, 06:32 PM   #1
Borjaq
Member#: 4812
04 STi
Blk
Angry Bown head gaskets, warped heads and a piston melted to the cylinder wall!!!!????
Well, I still need the figure out what to do. I called the dealership and they told me it was covered, but I have to take my car down to them which is 80 miles away. They said that they had to make sure it was really covered under warranty. I guess they just want to make sure I didn't do anything to it to make my engine do this. Any suggestions or help that I might be able to use to make sure it's under waranty still?? So far I have a homemade intake that has been working for months now and a muffler. Thanks.
Borjaq is offline   Reply With Quote
Old 03-26-2002, 07:25 PM   #2
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Do your self a favor and loose the intake & possibly exhaust FAST!
before the dealer see's it.
Good luck but a pistion temp that high is crazzy.
can you say lean?
GLwagon is offline   Reply With Quote
Old 03-27-2002, 05:53 PM   #3
WRXSTi69
Member#: 12012
can you say lean?
And you wonder why Subaru is so suspicious of so-called "stock" vehicles with warranty claims??? All you are doing is hurting someone with a legitimate problem. You broke it. You pay. :monkey:
WRXSTi69 is offline   Reply With Quote
Old 03-27-2002, 10:16 PM   #4
Borjaq
Member#: 4812
04 STi
Blk
So, your saying that if I buy a defective Subaru and it breaks, it's my fault for buying the Subaru? Right?
Old 03-28-2002, 01:15 AM   #5
IEWRX
Member#: 13535
2006 300C SRT8
11 Durango 03 Vette Vert
Default No....
I think what he is saying, is the same things other people have said. If you modify the car beyond factory, you need to be ready for the potential consequences of the modifications. The thing to remember, when you drive the car off the lot, that is what Subaru in warranting, the stock car. When you add items, in your case homemade intake, exhaust/muffler, that is not what Subaru intended for the vehicle and cannot warrant the possible issues that may cause.
The main thing here is that Subaru will ultimately have to show that these items caused the problem, but this may take a while and you either have to pay to fix the car yourself, of not drive the car to cause further damage the will then not be covered.
Wow... did just say that?
IEWRX is offline   Reply With Quote
Old 03-29-2002, 04:40 PM   #6
WRXSTi69
Member#: 12012
No, not at all. I was commenting on the "advice" you got about unbolting all your mods prior to bringing the car to the dealer for inspection. If you are so certain your mods didn't cause your problem, then why take them off? A good dealer tech will look for the cause of the problem. If you melted a piston, it really doesn't make much sense to put a new short block in without finding out what caused the meltdown to begin with. If a problem is discovered in your homemade intake, then you SHOULD be responsible for the damage it caused.
Old 05-12-2010, 07:38 AM   #7
Borjaq
Member#: 4812
04 STi
Blk
I know this is a long time from when it happened, but here is the result.
When I started driving on the highway, I noticed a loud "ping" noise after a minivan sped past me. After about an hour of driving on the highway I niticed that my heat had stopped working. I checked the heat settings then looked at my vehicle temp guage and noticed it was fully pegged in the red. I released the gas and all of the sudden the car jerked and a massive cloud of white smoke poured out the tail pipe followed by a huge black cloud eventuially. I got pulled over and then called for help.
After the dust settled, I found out that the minivan may have most likely kicked a piece of metal up off the road and into my radiator. SoA was greatful enough to rebuild any damaged parts of the engine, with installation, for free except the radiator. The insurance company covered the radiator, but seeing as I had a $500 deductable, I ended up paying for that.
I was happy in the end and now the car is screwed up again after getting it hydrolocked. Pulled the plugs and it still won't turn over. Even tried wrenching a little on the crank...
Thanks for reading.
Old 05-12-2010, 09:09 AM   #8
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Nice bump and clearing up some info.
blackfang is offline   Reply With Quote
Old 05-12-2010, 10:48 AM   #9
depACE
Member#: 117307
2007 WRX TR, UGM
2015 Forester XT, VRP
Wow, thanks for going back and updating with the outcome!
depACE is offline   Reply With Quote
Old 05-12-2010, 12:35 PM   #10
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
And you're assuming the intake or a damn muffler "broke it".
SoapBox is online now   Reply With Quote
Old 05-12-2010, 12:37 PM   #11
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
If you are so certain your mods didn't cause your problem, then why take them off? .
Because many many dealers will look to anything to deny your claim, whether it realistically caused a problem or not.
Old 05-18-2010, 02:36 AM   #12
nine7oh
Member#: 208840
2004 FXT, White
18ged
your trash talking a 8 year old post?
nine7oh is offline   Reply With Quote
Old 05-18-2010, 07:05 AM   #13
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Old 05-22-2010, 10:16 PM   #14
andsix
Member#: 231035
2008 Subaru WRX
kill yourself
andsix is offline   Reply With Quote
head gasket,tranny problems and reccomended maint. Jiggie_2006sti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-14-2009 09:00 PM
Head gasket thickness - Is thicker/thinner more likely to leak? bugeyes Built Motor Discussion 3 07-31-2006 02:00 PM
changed head gasket, had slight problem, now car chokes to death 1995LegWag Normally Aspirated Powertrain 5 03-23-2006 11:06 PM
small rust spots on the cylinder walls of new block! IllNastyImpreza Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-22-2006 09:41 PM
Class Action Lawsuit Re: Blown Head Gaskets/ Cracked Heads/ Overheating oldblackbeard Legacy Forum 22 01-13-2005 12:18 AM
