Old 11-25-2008, 09:19 PM   #1
bnr34rb26dett
Member#: 188424
2012 640WHP STI
Have a Nice Day? High pitch whistling noise at higher RPM but not WOT
I started noticing this high pitch whistling noise at higher RPMs. I do not hear the sound at WOT but only at high RPM's starting around 5k.
i tried locating the noise but it is very hard to tell where its coming from.
i have recently installed a catback exhaust.
could exhaust leak/ bad gasket make a high whistling noise like that??
any comments/ thoughts would be appreciated.
thanks!
bnr34rb26dett is offline   Reply With Quote
Old 11-26-2008, 02:57 PM   #2
bnr34rb26dett
Member#: 188424
2012 640WHP STI
bump...
Old 11-26-2008, 04:25 PM   #3
ranson
Member#: 169938
exhaust could make a noise like that, if there is a small leak, but a lot of times its a boost leak. how is your boost? use a vacuum line at all the exhaust flanges to listen for a leak, before you mess with the boost.
ranson is offline   Reply With Quote
Old 11-26-2008, 05:44 PM   #4
bnr34rb26dett
Member#: 188424
2012 640WHP STI
Zero Boost.
im N/A
should i check the exhaust? i dont remember putting a gasket between mid pipe and cat pipe where spring bolts are...
Old 11-27-2008, 08:51 AM   #5
msedillo
Member#: 193030
2007 wrx
red
man im having TH EXACT same problem. i just installed my cat back to. does your sound almost sound like loose change?
msedillo is offline   Reply With Quote
Old 11-28-2008, 06:59 PM   #6
bnr34rb26dett
Member#: 188424
2012 640WHP STI
loose change? no, mine sounds like a whistle..
Old 06-23-2009, 10:39 PM   #7
stisubie8787
Member#: 196636
04 subaru sti
black
does it sound like a high pitch squell / whistil
stisubie8787 is offline   Reply With Quote
high pitched whistling noise in STI hilfiger4you Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-07-2006 12:12 AM
high pitched whistling noise from right rear? KIDREX Brakes, Steering & Suspension 2 08-22-2005 11:45 PM
High Pitched Whistle at 3K RPM FD777 Newbies & FAQs 23 08-16-2005 07:20 PM
High pitched whistling noise from turbo Turbotegra Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-18-2004 03:47 AM
High Pitched Whistling At 70-75 MPH Cruising speed BryanD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-25-2001 03:14 PM
