Old 11-25-2008, 10:27 PM   #1
RChampion
Member#: 21481
99 2.5RS
07 Forester STI
Default Bad battery terminal. P0340 Camshaft position sensor circuit malfunction. Related?
For the past year, my car has shut off at random every 3 months only to start up within an hour or so and run fine for another 3 months. Every time it resets the ECU, but the last two times I managed to get the code from a CEL mentioned in the title before it disappeared.
This weekend it did not start back up, until just now when I reconnected the negative battery terminal. Could this be related to the CEL I got? Or do I have two separate problems?
Lastly, is it possible to have a perfectly fine looking battery terminal + connector thingy and still have it reduce the dependability of the car to 98% (like I said, runs solid between instances)?
TIA,
Robert
PS - car is a 97 L 2.2
RChampion is offline   Reply With Quote
Old 11-25-2008, 10:34 PM   #2
mikeyc
Member#: 32338
03 WRX Wagon
I had an issue with mine last winter. I thought my battery was going bad - randomly, it wouldn't start unless I jumped it, and after trying, the battery would appear to be dead. I had checked that the terminals were tight, and couldn't figure out what it was. Finally pulled the terminals off, and they were fairly corroded. Cleaned them up with some battery post cleaner and a scotch bright pad, and it started fine after that.
So yeah, I would guess it's possible
mikeyc is offline   Reply With Quote
PO325 Knock sensor circuit malfunction Art Hazebrook Service & Maintenance 6 08-20-2007 06:27 PM
Can camshaft position sensors go bad? scooterforever Service & Maintenance 6 07-07-2006 10:39 PM
So what the hell is a P1101 "Neutral Position Switch Circuit Malfunction (M/T)"??? obyone Mid West Subaru Owners Club Forum -- MWSOC 17 06-08-2006 01:52 AM
I just got P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) tmat3 Normally Aspirated Powertrain 18 03-03-2002 03:25 PM
OBD code P0340 - Camshaft Position... bobgrice Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 12-31-2001 10:28 PM
