Old 11-26-2008, 12:28 AM   #1
akbibeau
Member#: 183454
2007 Impreza 2.5i
Urban Grey Metallic
Default mid pipe
i have a spt axle back on my car right now and im looking to install a new mid pipe from boxer4racing.com has anyone tried this does it bolt right up in the future i will be adding new headers and hfc
i was also wondering if the stock mid pipe was for backpressure
akbibeau is offline   Reply With Quote
Old 11-26-2008, 12:36 AM   #2
cmiovino
Member#: 134005
2004 WRX Premium
With an SPT axleback, adding a midpipe will not really change your HP gains or sound. In the future if you add headers and a HFC, it might make a small difference. I would go for the borla replica headers right now considering they will make it sound a lot better. The HFC will most likely net you the most power out of all those options. Once you get them all working together, each will do more than if they were just installed by themselves.
Is the stock mid pipe for backpressure? Let's not get started on that debate Just keep around the 2.25 or 2.5 stock piping diameter and you'll be fine. The Stromung one on Boxer3Racing is meant for NA models, so you're good there. And it should bolt right up no problem.
cmiovino is online now   Reply With Quote
Old 11-26-2008, 12:39 AM   #3
akbibeau
Member#: 183454
2007 Impreza 2.5i
Urban Grey Metallic
i wanted to put the mid pipe on because its very silent i was thinking if u eliminated the resonator it would make it noticable i would be pleased with that
Old 11-26-2008, 01:22 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I'm presuming you actually have that 07 your profile lists. If so, you need to make sure the midpipe is for an 06-07 RS as nothing else will work. B4R lists both the old style and the new, so make sure you click the right one. So long as you buy the right one, yes, it's a direct bolt up. However, your new headers and new HFC won't be. AFAIK, no one makes 06-07 headers or HFC. You'll have to go either custom or convert to an older-style setup.
It's not because NA ENGINES DO NOT NEED BACKPRESSURE.
Just sayin.
Old 11-26-2008, 01:23 AM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Due to rust, I ended up replacing my stock midpipe with a Stromung with the entire rest of the exhaust being stock. Absolutely no change in sound.
Old 11-26-2008, 11:05 AM   #6
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Just want to add that when I added a stromung centerpipe to my stromung axleback, it made a huge difference in sound.
If really depends on the axleback portion.
If the muffler itself is of a quiet nature, the stromung centerpipe won't make a big difference, if the muffler is of a loud nature, a non resonated center will make it even louder.
kero is offline   Reply With Quote
Old 11-26-2008, 01:29 PM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Exactly. Even more, if the muffler is a really quiet one, like the stocker, nothing upstream of it makes a difference.
Old 11-26-2008, 02:37 PM   #8
H-Dtech
Member#: 139430
08 FSXT 5mt
WRB 1 of 300
b4r has a header and hfc listed for the 06-07 2.5I
H-Dtech is offline   Reply With Quote
Old 11-26-2008, 02:55 PM   #9
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I thought maybe I missed it, so I checked again. No, they don't have a header for HFC to fit the 06-07s without converting entirely to a 05- exhaust or custom work.
Old 11-26-2008, 07:53 PM   #10
akbibeau
Member#: 183454
2007 Impreza 2.5i
Urban Grey Metallic
Has anyone else heard the spt axleback it sounds good but it want it to be a little bit louder ive also noticed its alot louder when its cold out and thanx williaty for clarifying the backpressure i was worried about . i was also wondering has anyone set up an exhaust systems with header hfc stock mid pipe and an axle back ????? if so any difference
Old 11-26-2008, 10:14 PM   #11
piker28
Member#: 22664
Question is what spt axleback do you have on there, the one from the older rs or the one from the wrx
that will determin the midpipe you would want. Also it is not real loud because its designed that way, change it out for a stromung axleback and it will be prob more to your wishes
piker28 is offline   Reply With Quote
Old 11-27-2008, 09:16 PM   #12
akbibeau
Member#: 183454
2007 Impreza 2.5i
Urban Grey Metallic
the spt exhause i bought was made for the 2006 impreza 2.5i but i got it modified to fit on mine what they had to do was take te flange and twist it 90 degrees definatly look better than the stock muffler that put on
Old 11-27-2008, 09:18 PM   #13
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Haha, most definitely. I don't know why Subaru gave the 2.5i's pea shooter exhausts.
chazly413 is offline   Reply With Quote
Old 11-27-2008, 09:22 PM   #14
piker28
Member#: 22664
Then it sounds like it was not made for the 06 but instead for the older rs
Important thing to find out is if they modified the axleback or your midpipe to make the spt fit because that will determine what you will need to buy
Old 11-27-2008, 10:57 PM   #15
akbibeau
Member#: 183454
2007 Impreza 2.5i
Urban Grey Metallic
yea i havent actually looked under my car for awhile now but i will get on that before i buy this pipe
WTT: Invidia N1 Race mid pipe for Street mid pipe 22psiSTI SCIC Private Classifieds 2 05-27-2010 12:47 PM
WTT/FS: Invidia N1 Race 3" Mid Pipe for Resonated Mid Pipe Suby_06_STI RMIC Private Classifieds 2 12-12-2008 11:50 AM
Turboxs Exhaust Mid Pipe and Race Pipe cat delete pipe Ricowrx Private 'For Sale' Classifieds 3 04-15-2005 11:34 AM
sti down pipe, cat pipe , mid pipe 949 Private 'For Sale' Classifieds 2 02-01-2005 04:34 PM
TurboXS Down Pipe, Cat Pipe, and Mid Pipe rideboarderferg Private 'Wanted' Classifieds 0 11-06-2003 09:15 PM
