Old 11-25-2008, 11:41 PM   #1
dilzy82
Member#: 170037
2004 WRX V-Limited
WRB JDM
Thumbs up +35 offset what do i need ?
Ok I have a JDM WRX V-Limited with STI suspension. What do I have to do to make +35 18x9 Rota G Force fit ? No one is doing this here in Ireland. Heres pics that might help. Thanks in advance
dilzy82 is offline   Reply With Quote
Old 11-25-2008, 11:45 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
a fender stretcher
a BIG fender stretcher
your car is nice....dont screw it up trying to fit the wrong wheels
Old 11-26-2008, 12:37 AM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
+35 offset is fail.
Old 11-26-2008, 12:59 AM   #4
Øbey
Member#: 195643
+30 Ftw.
Øbey is offline   Reply With Quote
Old 11-26-2008, 01:03 AM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Originally Posted by Øbey View Post
+30 Ftw.
+30 is even worse. To make a 9" wheel fit while doing the least damage to your suspension geometry, the math says you need to be pretty much at +40.
Old 11-26-2008, 01:28 AM   #6
CHAWWSSS
Member#: 195639
Originally Posted by williaty View Post
+35 offset is fail.
finally someone on here who absolutley knows what they are talking about
CHAWWSSS is offline   Reply With Quote
Old 11-26-2008, 01:33 AM   #7
HYPHYmoment
Member#: 178234
Fail POS 5x100
WFC #035
roll your fenders and your done.... enough said.
HYPHYmoment is offline   Reply With Quote
Old 11-26-2008, 02:14 AM   #8
subaru3169
Member#: 55252
* pullup bar *
geezus that is a nice ride
subaru3169 is offline   Reply With Quote
Old 11-26-2008, 10:14 AM   #9
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
you will had to get coilovers, camber plates, roll the front fender, roll the rear fender and pull them as well. you will have to run -2.3-.5 camber so you don't rub at all.
And you will kill your wheel bearings
Old 11-26-2008, 12:11 PM   #10
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
Remember that Subaru set our stock offset at +53. Slight variations are acceptable, but going with extreme offsets will require extreme suspension and fender modifications.
p.s. Tire size and tire life will be DRAMATICALLY decreased.
cpunlamd is offline   Reply With Quote
Old 11-26-2008, 12:58 PM   #11
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
While I agree with your math, it's nothing more than a slight sacrifice for the sake of the look. I run my +30 for 3/4 of the year and while I love the crisp turn-in of a 50 offset wheel, the look of a wide ass +30 (or +35 in this case) is well worth it to me. Street racing is a federal offense, so I really don't miss the one percent of performance that I lose.
Please Juan, don't spread misinformation.
First off, his STi doesn't have a rear fender lip like a WRX. Second, there are many cases of aggressive offset cars without wheel bearing issues. Hell, I've taken my own car to the track while running a low 42 offset, and put thousands of miles on my current +30 wheels.
Tire life is going to be determined by what alignment specs you run. If one does the right modifications, one CAN run a good alignment for the street.
steve is offline   Reply With Quote
Old 11-26-2008, 01:06 PM   #12
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
The key to running the wide wheels with low offset, is to either limit the amount of suspension travel you have, or make room in the fenderwell. Your best bet is a little of both.
I ran some Ohlins with RCE springs, and found that there was too much movement. Off came the Ohlins, and on went the RCE Tarmac II's and voila, I was able to stiffen the suspension.
That' step one.
Step two is to decide if you want to run aggressive alignment settings, like 3 degrees of rear camber, or if you prefer to cut the rear fender lip.
For reference, you can see that the 911 is already factory rolled for aggressive fitment.
If Porsche is doing it, and has been for years, why are we so scared as Subie enthusiasts?
Back to it, you get a good idea of how a +30 will stick out, and the amount of trimming I had to do to make it all fit.
It's not really a lot of work, but you do have to take the time to cut, and then seal everything up back there.
When I did it, there were few references, and I spent a lot of time perfecting the cuts, welding things back up, etc. Now, a simple search will yield a recipe to fit anything. That's how I realized I worked harder than I needed to.
Old 11-26-2008, 03:55 PM   #13
dilzy82
Member#: 170037
2004 WRX V-Limited
WRB JDM
Thanks for the comments lads. Keep them coming
Old 11-26-2008, 05:45 PM   #14
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
True to a certain extent. The wheel in question is 18x9 +35 being installed on a GD Impreza. If you use the "correct" camber for the street, you will require a thin tire and will be running the stretch tire mod (ghetto mod in my professional opinion). With a good sized tire + the wheel in question, it will require ALOT to make it fit (which includes retarded negative camber).
Old 11-26-2008, 05:57 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
clarity of thought, here
quite refreshing
Old 11-26-2008, 08:04 PM   #16
juanmedina
Member#: 133146
I didn't notice he didn't had a WRX but for WRXs I am correct on the setting need it to fit those kind of wheels, and you did see the sarcastic smily beside the wheel bearing issues
Old 11-26-2008, 09:27 PM   #17
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
quite refreshing
Always here to help the challenged.
Old 11-27-2008, 11:08 AM   #18
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
Are you kidding me?
I run a 245 on my setup. My buddy runs a 255.
I've done both rear fender modifications to make them fit, AND we're both running realistic camber settings. In fact, I run +30 offset, 245 series RT615 tires, and less than 2 degrees of rear camber, while he's running even more aggressive +29.
For those who question my knowledge, and therefore my advice, here are some of my past projects. I've done over 30 rolls in the last year, and numerous "trims" to help people fit these wheels.
Notice the cars are sitting on an alignment rack?
Now, I'm not saying the offset isn't without it's sacrifices. Some of these guys are running 225's on a 9.5" wheel, and even I don't like that.
But at +35, there isn't much to worry about other than doing some minor modifications.
Old 11-27-2008, 11:33 AM   #19
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
Are you kidding me?
Im not kidding. Its not impossible to "MAKE" those wheels fit. Key word "make". They are not going on with out a list of mods. And you will most likely have to sacrifice a good sized tire to get the "RIGHT" camber.
Old 11-27-2008, 11:54 AM   #20
Daishi00
Member#: 78952
2005 WRX
CGM
Yeah, somehow I don't consider "simple modification" that includes the word "weld" in it's description. I had to roll my rears to keep my 235 on a +42 from rubbing. Granted, it's a wide running 235 but still.
Daishi00 is offline   Reply With Quote
Old 11-27-2008, 12:31 PM   #21
subaru3169
Member#: 55252
* pullup bar *
http://www.youtube.com/watch?v=DDTK9IjKIYU
i hope none of the flush ppl think about fender modding like this lol
Old 11-27-2008, 01:19 PM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
and the heart of all 'rice' is fitting parts that DONT, regardless of the issues that they may cause.....just to be koo and be part if the 'IN' crowd(of like minded idiots).
glad I grew out of it...sometime right around highschool graduation
Old 11-27-2008, 01:21 PM   #23
Daishi00
Member#: 78952
2005 WRX
CGM
If it's for a motorsport application it's a bit different, but just for looks I agree with you there.
Old 11-27-2008, 01:30 PM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
motorsports application???
these wankers wouldnt know a motorsport if it bit them in the ass
Old 11-27-2008, 01:34 PM   #25
Daishi00
Member#: 78952
2005 WRX
CGM
Oh, I completely agree, but I was just doing some clarification
I’m flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
What do I need to do so I won't need a cosigner? pjloyd Off-Topic 45 04-26-2008 01:17 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
What do I need to fit 35/65 center diff? bugeyes Transmission (AT/MT) & Driveline 12 02-01-2005 09:37 PM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
