Old 11-26-2008, 05:13 PM   #1
omeskcus
Member#: 134657
Default valve cover torque specs?
Anyone know what the valve cover torque specs are for a 93 Impreza 1.8L? And I dont have a torque wrench that goes that low. How would you do it by feel any suggestions??
Thanks
omeskcus is offline   Reply With Quote
Old 11-26-2008, 05:58 PM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
I used a small 1/4 drive ratchet and did about 1/2 turn past finger tight. IIRC it's not even 10 ft/lbs for those things. (I want to say 8 but not 100% sure).
rougeben83 is offline   Reply With Quote
Old 11-26-2008, 09:04 PM   #3
EdHilario
Member#: 137398
2004 Impreza
I just did hand tight and quarter turn past that.
EdHilario is offline   Reply With Quote
valve cover torque specs Chino1 Service & Maintenance 5 11-16-2015 05:39 PM
torque specs on valve cover 2.5ReallySexy Built Motor Discussion 7 05-22-2008 11:28 PM
looking for torque specs for valve cover, spark plugs and coil packs Tobey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-13-2005 04:35 PM
exedy clutch cover torque specs Heeven Transmission (AT/MT) & Driveline 0 04-23-2004 02:08 PM
valve cover bolts torque specs nkodemus82 Service & Maintenance 9 03-03-2004 07:46 PM
