Old 11-26-2008, 07:00 PM   #1
vhalin
Member#: 21445
08 STI
Default What Subarus would have the same oil cap with a '90 legacy?
If you have a Perrin FMIC on an '08+ STI the intercooler piping prevents you from taking off the oil filler cap. The '90 Legacy oil filler cap is very thin and solves this problem. A friend of mine has one on his FMIC'd '08 STI and it worked. So does anyone know what year/model Subarus share the oil cap with a 1990 Legacy?
vhalin is offline   Reply With Quote
Old 11-26-2008, 09:28 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I have seen basically all the same ones go onto the N/A models between 90-98. All my oil filler caps are the same on all my cars. One is black the others are yellow, so take your pick for colors.
~Josh~
Old 11-26-2008, 11:27 PM   #3
vhalin
Member#: 21445
08 STI
~Josh~
so the one from my 98 forester L is the same?
Old 11-27-2008, 03:12 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Are you talking about the filler CAP, or the filler NECK (the cap screws into the neck).
When I swapped in SOHC EJ25 heads, the filler neck is alot shorter than the ones used on EJ22 heads, you might try that also, if it will bolt up to your heads, which it should.
~Josh~
Old 11-29-2008, 07:25 AM   #5
vhalin
Member#: 21445
08 STI
~Josh~
I'll try that if the one from my forester L doesnt work... shiiiit... putting 08 STI oil filler cap on Forester = pimpin da fozzy!!
Old 11-29-2008, 12:54 PM   #6
Old School Scooby
Member#: 64128
86 Lifted,
Lowered 96
the oil cap's are all the same on any EJ engine.
Old School Scooby is offline   Reply With Quote
Old 11-29-2008, 10:17 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Check out www.outbackmotors.com for some trick billet shorty filler necks. Might as well look at the other eyecandy they can build too......
Jay
EJ20TT swap into a 97 Legacy GT, would it have the same difficulty as swapping in RS Deucalion Legacy Forum 2 11-09-2009 02:25 AM
ej20tt swap into a 97 Legacy GT, would it have the same difficultys as swapping in RS Deucalion Subaru Conversions 1 11-09-2009 01:19 AM
Does the NA Block Have the Same Oil Gallery Plugs as the Turbo Block? williaty Normally Aspirated Powertrain 14 05-21-2009 12:08 PM
What other brand cars have the same wheel specs? chimchimm5 Tire & Wheel 3 09-22-2007 09:10 PM
What other cars have the same tranny? Rickyh Transmission (AT/MT) & Driveline 0 11-29-2003 11:41 AM
