Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 11-26-2008, 07:06 PM   #1
mbaker
Member#: 188614
2004 WRB WRX wagon
VF-37 twin scroll on E85!
Default size issues with wagons?
hi i am in the process of looking for new rims for my 04 wrx wagon, and i have found some good rota g-forces that are 17x8 and i just want to make sure they will fit fine. i just got off the phone with jlb motorsports and they said they might rub in the back. can someone help me out with what i would have to do or if they will be ok?
thanks
mike
mbaker is offline   Reply With Quote
Old 11-26-2008, 08:00 PM   #2
wrxskier18
Member#: 88005
2002 WRX + NSX
Silver + Green
It will completely depend on your offset, tire size and alignment specs. If you have a normal setup (+48 and 225 width tires) there is a chance that you will rub in the rear. You would have to take out the plastic liner on the lip of the fender and at most roll the fender a tiny bit. It would probably be fine, but there's only 1 way of telling.
wrxskier18 is offline   Reply With Quote
Old 11-26-2008, 08:36 PM   #3
mbaker
Member#: 188614
2004 WRB WRX wagon
ok so even if there is a rub i can easily fix that right?
thanks
mike
Old 11-27-2008, 10:02 AM   #4
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
If you remove the trim and roll the fenders well, you'll gain 8mm of clearance in the rear.
dbrier is offline   Reply With Quote
Old 11-29-2008, 04:38 AM   #5
mbaker
Member#: 188614
2004 WRB WRX wagon
sweet is there a write up on how to do this?
thanks a lot
mike
Old 11-29-2008, 08:10 AM   #6
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
thanks a lot
mike
Yes there is:
http://www.rollyourfender.com
Rolling the rear fenders is pretty easy. Just make sure your take your time and use plenty of heat.
thorongil is offline   Reply With Quote
Small/Major issue with wagon FSB...PICS jsalassi Brakes, Steering & Suspension 14 08-31-2007 10:20 AM
URGENT! 06 STi turbo-back exhaust fitment issues with an 03 Wagon???? mr_yellow General Community 11 06-27-2006 05:57 PM
Fitment issues with 02 WRX Wheels on 00 Outback Wagon? Lou Tire & Wheel 6 09-03-2005 07:52 PM
What is the issue with STI splitters on wagons? Chris91se Interior & Exterior Modification 2 04-01-2005 11:06 AM
Anybody have rubbing issues with stock sized RE-730's? 2.5GT Brakes, Steering & Suspension 2 01-08-2002 01:54 PM
