Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 11-26-2008, 08:20 PM   #1
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Default P0440
Okay I've searched but no specific solution found,
During the last couple of days in MA the weather was 20 F.
Fill up tank 87 octane rating (I always used this) if it matters
I did noticed a little fuel smell from filling it up maybe
drove it until a quarter tank
Now MY99 LGT throws a P0440 EVAP system malfunction
from the front there's an odor that I can't describe like burnt plastic or something
I was wondering if anyone has delt with this kind of problem and point me in the right direction
hangman is offline   Reply With Quote
Old 12-04-2008, 12:21 PM   #2
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Okay finally broke down to get new filler tube and the vent valve that attaches to it and new gas cap premier subaru was the cheapest for me.
Well my question
the smaller hose that attached to the vent valve can those be replaced with any well "silicone hose" because I have a whole bunch of them as only vacuum passes through it correct me if I'm wrong.
Old 12-11-2008, 11:59 AM   #3
tdeuce82
Member#: 197219
i'm having a P0440 problem, too. i havn't figured out the source yet but as far as the tubing goes, as long as it matches up well with the origina ltubing it should be fine. just like u said its vacuum tubing
tdeuce82 is offline   Reply With Quote
Old 12-11-2008, 08:09 PM   #4
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Well replaced the filler tube and holy **** this has been mcgyvered the last owner took out the valve that attaches on the side of the filler tube and just covered it with a rubber hose and clamps all over the place, The valves operates when the gas nozzle enters the filler tube this explained why I can't fill up my tank without pumping slowly. This thing has 2 vacuum valve that connects the 2 fume tube (excuse my vocabularies), the last owner just put a bypass hose between the 2 hose not using the valve. well glad I've changed it and yes the silicon tube was used to replace the old one. I then reset the computer and no codes back yet...
I will take pictures of the old tube this weekend.
Old 12-14-2008, 12:44 PM   #5
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
The new does not look like that.
or that as you can see there's no well guard thingy.
Rot as hell!!
I can't believe I drove around like this for 10 months and it didn't throw a code until now.
Old 01-22-2009, 01:26 AM   #6
Udolauch
Member#: 169090
2003 WRX Wagon
'Bumble Bee' sonic yellow
Oh man that looks terrible! My filler neck looks almost brand new so I don't know if that's my problem.
Udolauch is offline   Reply With Quote
Old 01-22-2009, 12:01 PM   #7
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
The problem with the filler neck was I think it was causing the CEL and the problem with the slow pumping gas was the vent valve.
Help! P0440 dandbest Normally Aspirated Powertrain 2 05-26-2004 10:52 AM
P0440, P0420 the CEL's that stay T33 Engine Management & Tuning 19 02-13-2004 01:52 PM
Keep getting a P0440, what's the deal? RebelINS Normally Aspirated Powertrain 2 12-31-2003 11:10 AM
Need some help-- code P0440 dandbest Tri-State Area Forum 10 12-17-2003 02:33 PM
cel code P0440 my2000rs Service & Maintenance 5 03-02-2003 09:06 PM
