Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 11-26-2008, 11:22 PM   #1
STIfever09
Member#: 188630
2009 STI
Spark Silver
Default reflash or real time
With the AP2 I have reflashed my car three times. First with ACN91 1.01. Second, back to stock for dealer oil change. Third, back to ACN91 1.02. How do I know if I flashed real time or the permanent re flash ? Somewhere I remember seeing that one provides all the potential and the other less. Also, by disconnecting the batt you lose the program ? Sorry about the stupid questions. . .I can already feel the heat from the BBQ
STIfever09 is offline   Reply With Quote
Old 12-01-2008, 10:32 PM   #2
wadester
Member#: 188054
05 STi Cosworth LB
FP Green 375whp
When you have the AP connected to the car, you can scroll through the menu and find the one that says "Show Maps". Click that and you can see your current Base and Realtime Maps.
Also, a difference between the two is that the reflash takes significantly longer to upload to the car than the Realtime flash.
In regards to your comment about map potential, from cobb's manual:
"Things like CELs and some important Throttle tables and Closed Loop tables are not
changed with Realtime maps. This is why we highly recommend you running the Stage
Base Map that best matches your car's modification. Running the Stock Mode Base Map
with a Stage Realtime map over it will get you some of the improvements but no where
NEAR what you would get if you were to run the proper Stage Base map."
-COBB
You only lose your realtime map when you disconnect the battery. The car then then reverts to the base map.
wadester is offline   Reply With Quote
Old 12-01-2008, 11:37 PM   #3
pete1122
Member#: 152862
2005 WRX
So.....I flashed my WRX with the standard stage 2 base map, a few months later I did a realtime flash with the HWG Stage 2 map to see if it improved my boost. Is this a problem?
pete1122 is offline   Reply With Quote
Old 12-02-2008, 01:42 PM   #4
lando
Member#: 149637
2010 STI SE
no, just do a reflash. It just takes a few minutes and will probably improve things, as stated earlier with the exact same question.
lando is offline   Reply With Quote
Old 12-02-2008, 05:02 PM   #5
STIfever09
Member#: 188630
2009 STI
Spark Silver
-COBB
Thanks for the answer, I actually did exactly what you said and figured it out a while back. .
NY times article about real time access to ECU Suladed Engine Management & Tuning 1 03-12-2010 05:39 PM
Real-Time Traffic Reporting, on Time AVANTI R5 Non-Subaru News & Rumors 0 09-19-2009 07:34 AM
real time vs. reflash 073/800 AccessPort 11 05-03-2008 09:27 AM
Pro Tuner Map (.ptm) is it a Base or Real Time map ? Bad Noodle Newbies & FAQs 1 03-26-2008 03:55 PM
...either real sad or real freaking pissed off. DISCOPOPE Off-Topic 25 04-21-2004 12:25 AM
